What's An Easy Way To Remove A 2004 Titan Fan? - Nissan Titan Forum
post #1 of 8 (permalink) Old 08-26-2010, 07:32 PM Thread Starter
iTrader Score: 0 reviews
I am replacing my radiator and I got everything loose and got down to removing the fan. I will damage the coils unless I remove the fan. The fan has four nuts. I saw another post that said the nuts take a 10mm wrench. No 10mm wrench I have will fit. I tried a 10mm, 9mm, 11mm, and none will work. I even tried standard 3/8, 7/16, etc. I got a crescent wrench on it and got it to fit the nuts. But, the pully spins. I guess I will have to get a pipe wrench or a pair of channel locks to hold the pully while I remove the nuts. To make a long story short this really has me pissed. My truck is down untill I remove these four nuts!!!! Nissan really screwed us on these radiators!!!
Hot Rod is offline
Advertisement
post #2 of 8 (permalink) Old 08-27-2010, 10:37 AM
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: What's An Easy Way To Remove A 2004 Titan Fan?
Good thread
http://www.titantalk.com/forums/tita...step-step.html
What's An Easy Way To Remove A 2004 Titan Fan?-fan.jpg   What's An Easy Way To Remove A 2004 Titan Fan?-fan2.jpg
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #3 of 8 (permalink) Old 11-03-2013, 10:27 AM
mannyfreshcastillo's Avatar
Get your 10mm wrench and a hammer place wrench in nuts and tap with your hammer.
mannyfreshcastillo is offline
post #4 of 8 (permalink) Old 11-03-2013, 10:41 AM
GENMAX's Avatar
This is what worked for me
2008 SE KCLB -- Before and After Dyno Chart
Banks CAI & ME -- Video of Dyno Run w/ Banks
WTB: Utili Track Rails
GENMAX is offline
post #5 of 8 (permalink) Old 11-03-2013, 01:52 PM
Im tired of changing radiators on my t.
post #6 of 8 (permalink) Old 11-03-2013, 02:16 PM
mcginkleschmidt's Avatar
I used a straight 10mm ratcheting wrench, no offset, to loosen and tighten my fan nuts. To keep the fan from spinning during the process, I inserted the blunt end of a cedar shim between the belt and one of the pulleys. For both the removal and installing the fan nuts, I accessed two of the nuts from the top and the remaining two nuts from under the truck. I had to remove the cedar shim to the opposite side of the pulley for re-installing and tightening the fan nuts. Everything worked like a charm. Just make sure you remove the shim before starting the engine.
mcginkleschmidt is offline
post #7 of 8 (permalink) Old 11-03-2013, 08:48 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
I sprayed mine with PBlaster a few minutes beforehand. There were tight, but they came off without any issues. My engine compartment stays very clean so maybe that and only 60,000 miles kept them from being a problem.
I have leftover nuts and studs from the mechanical fan if anyone needs replacements. Free as along as I can get them in a regular envelope and a first class stamp.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
Jim aka Bionic Whore™
HRTKD is offline
post #8 of 8 (permalink) Old 11-03-2013, 09:18 PM
Walrus's Avatar
iTrader Score: 20 reviews
IIRC, TitanFan was removed with a Ban Hammer. Anybody remember that?
WoooooHooooooooooooooo
BaldWhore
Starfishwhore
Red is a good color for Christmas.
Fuzzy green also makes me happy.
You know you had a great night last night when you have blessed the crowd with your love and prayers .
It's not the zombies you have to watch out for. It's the stupid people.
Walrus is offline
The Following User Says Thank You to Walrus For This Useful Post:
TA CC TX (11-04-2013)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
2004 AC fan speed control knob broken... MTiger92 Titan General Discussion 1 10-11-2008 03:57 PM
2004 cc Titan Vs 2004 Ford F350 Diesel w/chip x2thez Titan Engine, Transmission & Drivetrain 4 12-01-2006 10:17 AM
Can anyone recommend a easy remove Camper Shell?? jedi7001 Titan Parts & Accessories 3 12-14-2005 08:27 AM
Remove PFG In June 2004???? Takideezy Titan General Discussion 7 06-17-2004 03:40 PM
You may post new threads
You may post replies
