Help..truck seem to have mutiple issues at same time! - Nissan Titan Forum
Old 09-08-2010, 09:16 AM   #1 (permalink)
iTrader Score: 0 reviews
Go to start truck today at lunch time, nothing. No cranky. I got some weird clicking noises behind the dash on and off, and the gauge needles were bouncing back and forth slightly. No headlights at all, but the dash warning lights are nice and bright.
im thinking maybe the dreaded IDPM or the ECU relay (btw, im having trouble finding the fog light relay to switch it with, my fuse box cover does not show a fog light relay being listed)
No power windows or door locks either. so maybe its a dead battery....truck is 4.5 years old though and has low miles.
I may try to jump start it later, but now for the really strange part......my key will not come out of the ignition switch. It just wont pull out. it will rotate the switch, but wont come out. also, i can not shift out of park, even with foot on the brake and key forward, and the steering wheel wont lock if i turn it with key in off position.
WTF!!!
anybody seen this before?
titan14 is offline   Reply With Quote
Advertisement
Old 09-08-2010, 09:18 AM   #2 (permalink)
sudden urge's Avatar
iTrader Score: 4 reviews
Re: Help..truck seem to have mutiple issues at same time!
Your battery took a dump.
Chicago area 05 KC SE 4x2 FFV, smoke, 2.94 gearing. Mods: Hypertech Max Energy, JBA catback, Airaid 4" MXP CAI, Hellwig HD traction springs, 08 rear shackles, Nasta nerf bars, Kenwood KSC-SW1 powered sub. Best full street trim (5120#) 1/4 mile track time of 14.632 running Bully Dog 87+2 and S&B CAI. 1/8 mile 9.30@74.49 with a 2.11 60'.
sudden urge is online now   Reply With Quote
Old 09-08-2010, 09:21 AM   #3 (permalink)
baseballfanz's Avatar
iTrader Score: 1 reviews
You have a bad battery. There is not enough juice for the safety solenoid to release your key.
There is a little emergency flip switch to let you get your key out.
Put your truck in N( if not in P), set emergency brake.
Reach up under the dash toward the key cylinder area, there's a flip switch
that need to be flip to get the key out.
Picture show switch with panels removed but I was able to do it without any panels removed
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
The Following 3 Users Say Thank You to baseballfanz For This Useful Post:
Energizer (09-08-2010), gweasel77 (09-08-2010), sudden urge (09-08-2010)
Old 09-08-2010, 09:21 AM   #4 (permalink)
but why cant i get the key out of the igniton swith?
Old 09-08-2010, 09:23 AM   #5 (permalink)
theres a relay to release the key? where the emergency flip switch located? thanks
Old 09-08-2010, 09:24 AM   #6 (permalink)
Update post above with picture.
Old 09-08-2010, 09:25 AM   #7 (permalink)
Irish125's Avatar
As baseballfanz stated, the battery is too dead to even activate the key release or the park lock solenoid which is why you cant shift it either. Throw a new battery in it and you will be g2g.
LousyLuckWhore™
2010 Pro-4X CC Galaxy Black
E-Lock MOD
Irish125 is offline   Reply With Quote
Old 09-08-2010, 09:29 AM   #8 (permalink)
so i take it this has happened to you as well? I have another car and an extra set of keys, so maybe ill just go buy a new battery and swap it out instead of trying to find the lock release (how did u discover that btw?). i assume all will function normal with new battery
Old 09-08-2010, 09:32 AM   #9 (permalink)
Once you get a new battery in there everything will be good.
I had the battery died on me before yes.
The key release thing I saw in the service manual.
Old 09-08-2010, 09:36 AM   #10 (permalink)
Irish125's Avatar
To get the key out, reach up under the drivers side area and toward where the lock cylinder would be.
There is an emergency release button for the key. Might have to look around, but it should be there.
LousyLuckWhore™
E-Lock MOD
Old 09-08-2010, 09:43 AM   #11 (permalink)
you guys rock, thanks
Old 09-08-2010, 02:24 PM   #12 (permalink)
New battery did the trick.
worth noting, even after new battery, key still would not release. I had to manually re-set the button underneath the dash.
Advertisement
New Truck -Transmission Issues? iodonnell16 Titan Engine, Transmission & Drivetrain 29 10-05-2011 12:29 PM
Some Mechanical issues with my truck -Incred- Titan Performance Modifications 2 11-29-2009 02:05 PM
List of 3 issues, time to make an appt with the dealer. Whee! Yahooligan Titan Problems & Dealer Service 5 01-25-2007 01:19 AM
Got my truck today & issues already jeremyw Titan General Discussion 25 03-28-2005 06:04 AM
I need a list of Feb truck issues. HELP!! Bolt Titan Problems & Dealer Service 4 01-16-2005 03:35 PM
SEO by vBSEO 3.3.2
