IPDM - ECU relay problems, symptoms and solution. - Page 4 - Nissan Titan Forum
LinkBack Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
post #46 of 373 (permalink) Old 12-09-2010, 08:56 AM
Titanistic's Avatar
iTrader Score: 1 reviews
Re: IPDM - ECU relay problems, symptoms and solution.
Why do you have to return the truck to "original tune" as stated in a previous how-to post?
Titanistic is offline
Advertisement
post #47 of 373 (permalink) Old 12-09-2010, 09:33 AM
iTrader Score: 0 reviews
i understand that the ecm relay is on recall. but do you know if the ecm relay damaged the ipdm board will nissan also cover the ipdm cost and labor? just asking Thanks for all your great info with part # etc. 05 titan
roberthg is offline
post #48 of 373 (permalink) Old 12-09-2010, 05:56 PM
m8o8r8e8n8a8z8o's Avatar
New IPDM
This sucks got some relays and they where used , so i got the new and inproved IPDM and it only lasted 2 days and failed
Had to do the fog light swap on it to get it to run
Hopefully with new relays ill be ok for a while...
m8o8r8e8n8a8z8o is offline
post #49 of 373 (permalink) Old 12-09-2010, 07:40 PM
krh2's Avatar
iTrader Score: 2 reviews
That was me. Just a precaution. Dont know if you really need to tune it back to stock but I wasnt taking any chances.
krh2 is offline
post #50 of 373 (permalink) Old 12-10-2010, 02:11 PM
Titanistic's Avatar
Thank you krh2.
post #51 of 373 (permalink) Old 01-01-2011, 11:17 AM
Exclamation Re: IPDM - ECU relay problems, symptoms and solution.
ifeel so frustrated with this POS truck i got a new IPDM 2 days and it went bad , i got new relays (3) and 1 lasted 1 day
this morning when I need my truck for work it wont start got another new spare relay in and still wont start
The For Sale sign is on the truck but how am i going to sell it if it dont run???
My wife told me need some matches???
post #52 of 373 (permalink) Old 01-01-2011, 12:19 PM
TitanBlue's Avatar
iTrader Score: 3 reviews
Get some help for a deeper diagnosis, no need to sell the truck. You may simply have a loose pin in one connector. I swapped an IPDM for someone, and it would not crank, simply because 1 pin got pushed out somewhere when we were disconnecting it. Easily pushed back in and pin locked in place. been good for almost a year now. So many problems are just connections, not expensive modules. FYI for all: The new ECU Relays are only $3 at the dealer.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
TitanBlue is offline
post #53 of 373 (permalink) Old 01-05-2011, 11:47 PM
Ok so far so good got it running
Had to jump it with my 1999 durango cuz i drained the battery
Here is what i did wrong: checking for loose conections I unhooked the ECM so I lost Ethanol Mixture Ratio Adaptation , and other computer adaptations , also lost comunication w/ BCM and ECM so they had to be paired again
post #54 of 373 (permalink) Old 01-12-2011, 02:08 PM
LD5050's Avatar
iTrader Score: 8 reviews
My T's 3 hours away at a dealership in Dallas with this problem right now. Took it in with all the symptoms, they did the ECU relay recall swap, didn't fix the problem. Had to leave it there. >.<
They called me yesterday and told me it was in "failsafe" mode and the only problem was the cats were bad. I asked him which ones, he said the 2 closest to the engine. Quoted me $1500 for 2 cats! Later I realized he probably meant $1500 for the two cats AND the stock manifolds they're welded to. At least, I hope that's what he meant.
I called them back later and let them know it's likely the IDPM (after I researched on here lol). They haven't gotten back to me yet.
I do have a question for those more knowledgeable than me: Is it possible the IDPM malfunction caused unburnt fuel to pass through my exhaust system? I think I saw that on another forum, and my buddy said he saw liquid coming out my pipe when we did the block around the dealership. That would definitely fry my cats, right?
Current ~ black '12 GT500 SVTPP, white '11 GLK350
Past ~ white '11 F250 w/ 12" lift, black '12 F250 w/ 8" lift, gray '14 Impala LTZ, black '04 Focus SVT procharged, smoke '06 Titan CC 4x
LD5050 is offline
post #55 of 373 (permalink) Old 01-13-2011, 08:44 AM
LD5050's Avatar
Today Brian from Cooley called me, and I told him to go ahead and replace the IPDM board. $260 installed and programmed. A bill more than is really fair, but it is a dealership. Told them to throw a spare ECU relay in the glove box for me.
Hopefully this gets my truck running so I can bring her home and get the next phase started!
LD5050 is offline
post #56 of 373 (permalink) Old 01-13-2011, 09:01 AM
krickett's Avatar
I'm confused, shouldn't this be covered under the IPDM recall that just came out? Also, what is the "programming" they are talking about? There's no programming of the IPDM involved that i know of. I replaced mine a year ago when the original one failed. Picked it up from the dealer and installed it myself at the cost of parts. I didn't program sh**...
Sounds like you might be getting some smoke blown up your a**. I'm just looking out for ya, maybe you have other circumstances, but definitely check on that.
-Ryan
2006 Nissan Titan LE Crew Cab 4x4
Big Tow Package - Doug Thorley Long Tube Headers - JBA Cat-back Exhaust - Uprev Tuned
- PML Transmission Pan - PML Rear Differential Cover
Goodyear Wrangler Silent Armor Pro Grade LT275-70-R18 -
- Air Box Mod - '08 Rear Shackles
Mobile 1 Synthetic Motor Oil, Mobile 1 ATF, Royal Purple Gear Oils
Record Tow: 11,000 lbs Seattle to Michigan and back.
krickett is offline
post #57 of 373 (permalink) Old 01-13-2011, 02:27 PM
LD5050's Avatar
I completely agree. But I've got it sitting at this dealership 3 hours away from my home town, and wanted to give them [I]something[I]since they definitely won't be getting the $1500 for new manifolds.
Plus, I'm really hoping that the IPDM replacement will fix the sputtering (truck won't get over 45mph) and I can bring her home on her own, and not on a trailer.
>.< Programming a fuse box, lol.
LD5050 is offline
post #58 of 373 (permalink) Old 01-16-2011, 11:22 AM
krickett's Avatar
I'd be an absolute di*k to them and demand everything be free since that's what Nissan's warranty states. You have every right to. Telling me i have to pony up $1500 for new manifolds without even checking what the problem really was would piss me off. "Oh, our bad, turns out it was only a $250 IPDM, that's already been recalled, but we still want you to pay for that too"
Are you under 80,000 miles?
I get so sick of dealerships and their bull sh**. It's ridiculous that WE have to remind THEM of their warranty on the emissions system. I wonder how many people, going off what the dealer told them, paid for new manifolds when they should have got them free. I'd be pissed!
Good luck man and hopefully it all works out for ya. Definitely frustrating.
-Ryan
krickett is offline
post #59 of 373 (permalink) Old 01-19-2011, 01:28 AM
This whole thread is a great read. I hope that I can get some info from someone on here:
A-if my T falls under the recall? I won't get a letter, as I am not the original owner.
B-can I really do this myself? Please send me a link where I can buy one of these.
C-I am moving from CA to TX right after I get back from Iraq, so I don't have the time or patience to mess around with some jerk at a stealership... Help!!
Thanks guys.
SoCal C4S is offline
post #60 of 373 (permalink) Old 01-24-2011, 11:15 AM
LD5050's Avatar
UPDATE:
IPDM replacement did not fix issue, truck is still in failsafe mode. Dealership said it was bad cats (because of cracked manifolds). So, once I replace all of that in a week or so I'll let you guys know.
LD5050 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
Linear Mode Linear Mode
ECU Relay Source - The TitanBlue $7 Solution TitanBlue Titan FAQ & How to Area 255 08-29-2016 06:11 PM
Another IPDM / ECU relay victim - fixed! But questions remain.... BigHeadDennis Titan Problems & Dealer Service 22 10-06-2013 04:10 PM
IPDM Problems ???? Blackstriper Titan Engine, Transmission & Drivetrain 1 07-17-2010 07:14 AM
*******UPDATED ECU Relay Source******* rowdyr Titan FAQ & How to Area 0 03-03-2010 11:25 AM
symptoms of ipdm failure? cdcrowell Titan Problems & Dealer Service 0 02-28-2010 11:57 AM
You may post new threads
You may post replies
