IPDM - ECU relay problems, symptoms and solution. - Page 7 - Nissan Titan Forum
LinkBack Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
post #91 of 373 (permalink) Old 03-21-2011, 07:32 PM
rickys2020's Avatar
iTrader Score: 0 reviews
Re: IPDM - ECU relay problems, symptoms and solution.
Well, got my recall done about 3 weeks ago and just this past saturday did not want to start at the first crank and after the second it went fine. So now what? take it back to dealer and check again to see if there is anything else besides the ipdm? or replace it myself? will they do a second run on the ecm for free? I will call tomorrow and see or if y'all have something different. battery is fine, replace it for an optima last summer. thanks for any other inputs you may have.
2004 LE CC SMOKE 4X2
rickys2020 is offline
Advertisement
post #92 of 373 (permalink) Old 04-07-2011, 03:46 PM
Does changing the relay fix the problem or do you really need to change the IPDM out?
gr82btnvol is offline
post #93 of 373 (permalink) Old 04-12-2011, 06:15 AM
My EGI Fuse keeps blowing.
It happens at random. No particular time more than another.
I thought it was possiably the Altanator but I had it and the battery tested and they checked out to be fine.
This is a serious problem because when the fuse blows I am driving and it shuts my engine down completely. Do you think it can be the same issue?
jobignel2 is offline
post #94 of 373 (permalink) Old 04-13-2011, 03:49 PM
El Mamito USMC's Avatar
iTrader Score: 8 reviews
-sputtering like it's not getting gas
-usually no SES codes but might have a combination of other lights flashing or on.
humm mine does this and my wifes is killing me, mine is an 04 CC 4x4. hopefully this is the problem im having.. ill get back to you guys...
Zorros Racing...
#123A Score Baja 500 FINISHER!!
This is not for woosies”
“Everybody play by the same rules, they all pay the same entry fees, I want to make sure that our hardcore, grassroots guys are always in Score, there’s a place for them”
-Sal Fish
Sponsors:
High end uniform
Suspension Specialist
Case savers, Chain Guides,
Supplements for endurance racing
Join the
travel to exotic lands, meet exciting unusual people and kill them..
El Mamito USMC is offline
post #95 of 373 (permalink) Old 06-09-2011, 07:22 PM
I have a 2008 LE Flex Fuel.... It died while accelerating from a red light then wouldn't start back up. It will crank and fire up, but once the RPM's fall back to idle, the truck sputters and dies. I already changed out the fuel pump to no change. I switched the ECU relay with the fog lamp relay and still no change. I haven't read on any site where a model over 06 had this problem. Part's.com said that I can't use the 284B6-ZC00A model IPDM that I need one that costs like $250. Do the IPDM's go bad in 08 titans? Does this sound familiar?
Mac119 is offline
post #96 of 373 (permalink) Old 06-19-2011, 04:23 PM Thread Starter
baseballfanz's Avatar
iTrader Score: 1 reviews
I have read of 08 with bad IPDM (rare but it does happen).
There's two listing for IPDM, the IPDM itself or the higher priced one which come with the covers and all that you don't need.
You can call the dealer cause the IPDM is recalled.
2014 Wrangler Unlimited Sahara
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #97 of 373 (permalink) Old 06-28-2011, 08:43 PM
I think I may be developing this problem. I left my shop this morning at about 10:30, I had driven there at 8 with no problem. 1-2 miles from the shop, my truck starts sputtering, wont take gas to accelerate. I am running about 40 mph. I pull over and turn the truck off. After a quick once over, finding no problems, I restart the truck. No problems whatsoever. Thoughts?
2004 Titan SE Crewcab 4x2
SilverStar Ultra Highs/Lows, Fog kit added, 05 Alum Diff cover, Armaden Interior LED's, Pulstar DG-1i plugs, PRG Shackles, Alpine Type-R SPR-60's rear, Alpine Type-R SPR-60C's front, 05+ Door badges, 2011 Pro-4x Rims, LT275/65/18 E LTX M/S2
Waiting to be installed:
Alpine M300 on doors, Alpine M500, Polk MM840 8" sub. Berk b-pipes
MarkD is offline
post #98 of 373 (permalink) Old 07-01-2011, 05:36 PM
man Thank You,Thank you!!!! I just got the ipdm-ecu change about 2 weeks ago had a recall on it ,now its runing like a champ..Thanks,..now I can go take my road trip instead of renting me a car.
2004 Titan modes:chrome handles,magnaflow exhaust system,chrome bug shield,spider grill,22" rims and tires,Roll Pan bumper,memphis speakers and sound system
.........Future modes:spray bed liner,fog lights,,H.I.D lights;Bed cover.
malawi is offline
post #99 of 373 (permalink) Old 09-01-2011, 10:20 AM
mrbubl's Avatar
Garage
iTrader Score: 10 reviews
Question Re: IPDM - ECU relay problems, symptoms and solution.
Still really never read a confirmation about what is in fact replaced, the IPDM relay? The IPDM assembly, The ECU relay?
If you replace the IPDM assembly, does it come with all the fuses and relays in place and ready to plug and play?
I bought several of the IPDM relays, they are cheap and can replace that but want to fix the issues.
Was the recall for the relay or for the assembly that contains both relays?
mrbubl is offline
post #100 of 373 (permalink) Old 09-01-2011, 10:29 AM
AcidJake75's Avatar
iTrader Score: 17 reviews
Send a message via AIM to AcidJake75 Send a message via Yahoo to AcidJake75
You cant replace the entire IPDM anymore unless you want to fork out 400+ dollars on the new one.. And you even have to pay for brackets to hold it in place..
So really you (and I) are stuck with just the relay and swap them out accordingly... Im going to look at junkyards to see if I can get a spare from an wrecked T..
04 KC Smoke Titan 4X4
PRG, Hypertech, 08 Brake Upgrade, Black Rhino 18x9 +12, 305/65/18, Bilstein 5100's, Pro4x Springs, AAL's, CSF Rad, 2º Advance, Debadged, GoGrounding, Radiator Bypass Cooler, AIRaid MXP Intake, Axle Vent Mod, DDM 5k Lows & 3k Fogs, Blacked out Head lights, Stillen LT, BALLER PRT PIPES (BECAUSE I DONT LIKE BUYING SHIET TWICE), JBA Exhaust, Magnaflow Glasspack, Vibrant, Tech12, Volant LED Tails..
AcidJake75 is offline
post #101 of 373 (permalink) Old 09-02-2011, 04:12 AM
mrbubl's Avatar
Garage
I bought the relays for both the IPDM and the ECU and they had the IPDM assembly ($232) @ Courtesy. i am having the battery checked today and if bad put in an Optima. Ordered the battery tray and new cables too just to round out the suite of goodies. Talked to someone about the exhaust and he said don't sell the farm just yet...he wants to look at the truck and find the problem, not just throw parts at it.
New bumper gets here today so things are looking up!
mrbubl is offline
post #102 of 373 (permalink) Old 09-20-2011, 09:30 AM
Had both my lock out relay fail on me (at the gas station) and the IPDM go out on me in Texas. The dealership had a hard time finding and receiving the IPDM due to the fact that Nissan had recalled all modules that were on the shelf at the time of my truck breaking down. Needless to say my truck was at the dealer in Texas and I was in Missouri calling Nissan daily to find out when I would get my truck back. 6 weeks later I received my truck. Both modules went out within 3000 miles of each other. Nissan corporation had their own engineers work on my truck and pretty much replaced all the electrical components ( September 2010)
The only good out of it all was that I received extended warranty for the electrical system and they delivered my truck to Missouri free of charge as well as put me into a rental vehicle for the entire time that I was without my truck.
willis2011 is offline
post #103 of 373 (permalink) Old 10-17-2011, 03:02 PM
scdude37's Avatar
I have a question. I have had the issues that are listed in the first listing, and i just took the truck in for the recall. My question is having the ecu relay replaced, does that solve all the problems or does having to have the whole ipdm replaced make it run??? I just want my truck back and running.
scdude37 is offline
post #104 of 373 (permalink) Old 10-19-2011, 05:59 PM
you will have no problem afterwards ,I had got my recall done,I didn't have a problem after that,running like a champ it is.
malawi is offline
The Following User Says Thank You to malawi For This Useful Post:
scdude37 (10-19-2011)
post #105 of 373 (permalink) Old 10-19-2011, 07:52 PM
hello i am having the same problem after replacing the ipdm to the new updated black ipdm, the truck sputters and shuts off. I can drive it at low rpm only. Any suggestings anyone?
tempest4153 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Currently Active Users Viewing This Thread: 23 (1 members and 22 guests)
Green Gator
Linear Mode Linear Mode
ECU Relay Source - The TitanBlue $7 Solution TitanBlue Titan FAQ & How to Area 255 08-29-2016 06:11 PM
Another IPDM / ECU relay victim - fixed! But questions remain.... BigHeadDennis Titan Problems & Dealer Service 22 10-06-2013 04:10 PM
IPDM Problems ???? Blackstriper Titan Engine, Transmission & Drivetrain 1 07-17-2010 07:14 AM
*******UPDATED ECU Relay Source******* rowdyr Titan FAQ & How to Area 0 03-03-2010 11:25 AM
symptoms of ipdm failure? cdcrowell Titan Problems & Dealer Service 0 02-28-2010 11:57 AM
You may post new threads
You may post replies
