Tensioner or idler pully sound?? - Nissan Titan Forum
post #1 of 16 (permalink) Old 10-25-2010, 02:19 PM Thread Starter
Guest
iTrader Score: 0 reviews
Hi guys, when its about 35 degrees or below, what sounds like a squeeking sound from the belt area exists. chirping sound. I have 28,000 on my 2004. Could the tensioner or other pully be shot?
thanks
Chris
xxxxxxxxxPAtitan56 is offline
Advertisement
post #2 of 16 (permalink) Old 10-25-2010, 02:25 PM
Location: Boston - Yes we're all wound pretty tight up here.
iTrader Score: 1 reviews
Re: Tensioner or idler pully sound??
Good chance it's going. Mine went at 40k. I started hearing a squeak and at times I would hear a slight noise like two metal parts grinding against each other.
I took the belt off and noticed a bit of play in the pulley/bearing. Replaced the tensioner assembly and the noise went away. I beleive there is a TSB on this.
OH, the new tensioner had way more tension than the original one.
SSNOS is offline
post #3 of 16 (permalink) Old 10-25-2010, 06:02 PM
sudden urge's Avatar
iTrader Score: 4 reviews
thanks
Chris
It might be the serpentine belt. To check, lightly spray some water on the bottom side of the belt while it is making the noise. If the noise disappears immediately, replace the belt.
Chicago area 05 KC SE 4x2 FFV, smoke, 2.94 gearing. Mods: Hypertech Max Energy, JBA catback, Airaid 4" MXP CAI, Hellwig HD traction springs, 08 rear shackles, Nasta nerf bars, Kenwood KSC-SW1 powered sub. Best full street trim (5120#) 1/4 mile track time of 14.632 running Bully Dog 87+2 and S&B CAI. 1/8 mile 9.30@74.49 with a 2.11 60'.
sudden urge is offline
post #4 of 16 (permalink) Old 10-25-2010, 06:32 PM
Carbeaux's Avatar
iTrader Score: 12 reviews
I'm guessing the belt. Try what sudden suggests and I bet it quiets right up.
Hook 'Em!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
“Please, don't torture me with cliches. If you're going to try to intimidate me, have the courtesy to go away for a while, acquire a better education, improve your vocabulary, and come back with some fresh metaphors.”
― Dean Koontz
2016 Super Crew, Platinum, 4WD FX4 Bought by me on 01/05/16
Carbeaux is offline
post #5 of 16 (permalink) Old 10-25-2010, 07:05 PM
honda250xtitan's Avatar
Garage
iTrader Score: 9 reviews
is it a pain to replace that belt? do you gotta take off the grille and bumper?
2011 White CC Pro4x
STOCK AF
Partout Thread\/\/\/
DIRT KING FABRICATION, FOX, TOYO, FUEL, PRG, GIBSON, BORA, AIRAIDhttp://www.titantalk.com/forums/buy-...od-prices.html
Traded In: 06 KingCab 4x4
honda250xtitan is offline
post #6 of 16 (permalink) Old 10-25-2010, 07:07 PM
Carbeaux's Avatar
No, you don't have to remove anything but the old belt. It's a very easy swap.
Hook 'Em!
― Dean Koontz
Carbeaux is offline
The Following User Says Thank You to Carbeaux For This Useful Post:
honda250xtitan (10-25-2010)
post #7 of 16 (permalink) Old 10-25-2010, 07:58 PM
SATXTITAN's Avatar
iTrader Score: 21 reviews
You don't have to remove anything, just make sure you draw a diagram of how the belt is run before you remove it. I would replace the belt first to see if that remedies the noise.
SATXTITAN is offline
The Following User Says Thank You to SATXTITAN For This Useful Post:
post #8 of 16 (permalink) Old 10-25-2010, 09:07 PM
Carbeaux's Avatar
Belt diagram:
Hook 'Em!
― Dean Koontz
Carbeaux is offline
post #9 of 16 (permalink) Old 10-25-2010, 09:08 PM
Carbeaux's Avatar
The one around the AC compressor was the hardest one for me, but you can go at it from underneath.
Hook 'Em!
― Dean Koontz
Carbeaux is offline
post #10 of 16 (permalink) Old 10-28-2010, 07:58 AM Thread Starter
Guest
Hey thanks guys. I am going to replace the belt first. it seems that is the best thing to do and see if there is play in the tensioner at that time.
Now, here is the question. should I get a gates belt or a goodyear gatorback belt? if you guys have any part #'s, maybe I can order one one-line and save a little.
Thanks
Chris
post #11 of 16 (permalink) Old 10-28-2010, 08:07 AM
Carbeaux's Avatar
Can't give you any feedback on those, but I can tell you that the OEM belt only runs about $20 bucks. Send a PM to BigBruno over on Club Titan if you're interested. He doesn't frequent this site as much as that one.
Hook 'Em!
― Dean Koontz
Carbeaux is offline
post #12 of 16 (permalink) Old 10-28-2010, 08:22 AM
Thanks
Chris
It only takes a few seconds to do the water spray test, but if you insist on replacing the belt, I recommend using the Goodyear Gatorback part# 4070975. I paid $25 for it a few years ago.
post #13 of 16 (permalink) Old 10-28-2010, 11:47 AM
Originally Posted by Carbeaux View Post
Belt diagram:
I love the Warning....You know that some moron tried it.
jeez is offline
post #14 of 16 (permalink) Old 10-28-2010, 11:54 AM
Carbeaux's Avatar
Some moron still will.
Hook 'Em!
― Dean Koontz
Carbeaux is offline
post #15 of 16 (permalink) Old 10-28-2010, 01:11 PM
Pops's Avatar
FWIW, I've also had excellent results with the Goodyear Gatorback on other vehicles... It's definitely top on my list...
2005 Armada LE 4x4
Pops is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Need to Replace the Drive Belt and Tensioner bleacht Titan Problems & Dealer Service 4 12-20-2009 02:14 PM
chirping in engine when cold- tensioner? xxxxxxxxxPAtitan56 Titan Problems & Dealer Service 11 02-18-2009 09:33 AM
Help with crazy sound @ 1300RPMS (sound clip) trogers Titan General Discussion 9 05-07-2008 05:10 PM
Bad serpentine belt or tensioner? sudden urge Titan Problems & Dealer Service 6 01-16-2007 01:50 PM
cam chain tensioner cold start noise oneidatitan Titan Engine, Transmission & Drivetrain 0 08-11-2006 03:31 PM
You may post new threads
You may post replies
