Truck having problems starting - Nissan Titan Forum
Old 11-07-2010, 01:41 PM   #1 (permalink)
iTrader Score: 0 reviews
We have a 2005 Nissan Titan V8 and never had any problems. Went out Friday afternoon to start it and it would turn over but wouldn't start. After a few tries, it finally started and drove home just fine. Tried to start it Saturday morning, same issue. Thinking it may be the battery, we charged the battery and still wouldn't start. This morning called the mechanic but he is closed today so we tried to start it again but this time gave it some gas, which we normally don't do. It started....... however only ran for about 5 minutes and then shut down as well as there was a heavy fume smell coming out of the exhaust which isn't normal.
Can anyone offer any advice.
cholee is offline   Reply With Quote
Advertisement
Old 11-07-2010, 02:06 PM   #2 (permalink)
RobKar's Avatar
iTrader Score: 24 reviews
Re: Truck having problems starting
Try this thread:
IPDM - ECU relay problems, symptoms and solution.
AKA TrollopInTraining™ AKA chinawhore™
2005 BT CC LE
100,000 Miles 6/10/2010
150,000 Miles 11/24/2012
160,000 Miles 4/13/2013
423TQ & 324HP 2/2/2013
UpRev Tuned, JBA Shorties, Airaid CAI
The early bird might get the worm, but the second mouse gets the cheese.
RobKar is offline   Reply With Quote
Old 11-07-2010, 02:08 PM   #3 (permalink)
LAZIEGUY247's Avatar
iTrader Score: 10 reviews
Mine is doing the same thing. Except I know it is my battery damn peace of crap Duralast! If i leave the door open for more than 30 seconds battery drains and the truck won't start!
2005 Nissan Titan KC Blizzard white.. AEM Brute Force CAI, JBA Cat-Back exhaust, BDGT 91 tune, 4*timing advance, Headlight Mod, DDM Tuning H.I.D. Kit 8k, VHT Tail lights, Debaged,Black Armada air dam, Black Armada 20's, 2 kicker L7's in a ported box
SoCal IRC VK56 Racing Member
Best 1/8 mile
9.481@ 72.88 MPH with BDPP.
LAZIEGUY247 is offline   Reply With Quote
Old 11-07-2010, 02:30 PM   #4 (permalink)
TitanBlue's Avatar
iTrader Score: 3 reviews
Has the charging system has been verified to be functioning properly? Batteries naturally fail more often, but some forget to check the Alt and cables first. Duralast has a good rep.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
MD Chapter Director
TitanBlue is online now   Reply With Quote
Old 11-07-2010, 05:05 PM   #5 (permalink)
Thank you soooooooooooooooooooooooooo much, it worked. Looks like some new parts are in order
Old 11-07-2010, 05:16 PM   #6 (permalink)
RobKar's Avatar
What worked?
2005 BT CC LE
Old 11-08-2010, 12:21 AM   #7 (permalink)
I cleaned the terminals they were corroded a bit, then I check to make sure the cables were tight which they were. And why I look at the voltage on my BDGT it stays between 12-13 volts most of the time. So you think it can still be the alty?
Best 1/8 mile
Old 11-08-2010, 09:12 AM   #8 (permalink)
RobKar's Avatar
When the truck is running you are only getting 12-13 VDC . It should be 13.5 - 14.5. I would check the ground connection and go from there.
Also get a volt meter and check at the battery
2005 BT CC LE
The Following User Says Thank You to RobKar For This Useful Post:
LAZIEGUY247 (11-08-2010)
Old 11-08-2010, 11:12 AM   #9 (permalink)
I'm gonna go to autozone today to get it checked out.
Best 1/8 mile
Old 11-08-2010, 11:51 AM   #10 (permalink)
1blktitan's Avatar
I have a Duralast Gold and its a POS IMO. I will be getting an Optima Yellow top this winter. As far as the starting issue goes I am experiencing the same and I believe that the IPDM is going out. I did however read a post today about an IPDM recall for the Titan i am going to call dealer up today and check into it.
Performance Mods thus far-Uprev/ JBA cat back/ Borla pro xs/ Stillen LT headers/ 2.5" B-pipes/ NO cats/ Transgo shift kit/ S&B cold air with 4" ram air mod
Exterior mods-Painted to match pocket flairs/ Procomp stage II lift/ Pro comp off-road traction bars/ 20" KMC XD badlands wrapped in 35" Mickey Thompson baja atz tires/ Custom Punisher gloss black grill/ Tinted tails and headlights/ CCFL halo Projecter head lights and fogs/ Bull bar/ Westen step bars/ Stainless rocker panels/ AVS bug guard and rain gaurds/ 20% tint all round/ 50% tinted windshield/ Truxedo Lo pro/ LED third brake/ Custom hitch cover/
1blktitan is offline   Reply With Quote
Old 11-08-2010, 12:21 PM   #11 (permalink)
1blktitan's Avatar
Called the dealer and they have yet to hear anything about the recall but I actually found a news report for the recall here Nissan recalls 2 million vehicles worldwide - Yahoo! News
Old 11-08-2010, 12:43 PM   #12 (permalink)
Nightstalker 6's Avatar
The wifes' 05 pathy did the same thing, my vote is the IPDM. swap out a non essential relay like the low beam, rear window defroster, or fog lamp, with the ECM relay and see if it starts.
The very existence of flamethowers proves that sometime, somewhere, someone said to themselves: "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done."
2006 Galaxy Black CC 4X2, PRG 2.5/1.0 mini lift, Bilstein 5100 struts on front and 5100 shocks on rear, headlight mod, airbox mod, BDGT, Axle Vent Mod, VHT Tails & 3rd Brakelight, GPS Speed Sensor Mod, Royal Purple Oil, Tranny Fluid, Power Steering Fluid, and Purple Ice in the Dual Core All Aluminum CST Radiator.
Nightstalker 6 is offline   Reply With Quote
Old 11-08-2010, 01:18 PM   #13 (permalink)
RobKar's Avatar
The OP is ordering the relay from me so ... it was the relay
2005 BT CC LE
Old 11-08-2010, 02:32 PM   #14 (permalink)
Ok well I just got back from autozone and they said the battery is good.. So I bought some battery cleaner and cleaned out the positive and negative cables, oh and I also changed out the IPDM that I bought from Robkar at the last TITan meet. So far it starts right up but I will give about another hour before I go back out and check if it will start again.
Best 1/8 mile
Advertisement
problems starting my truck! 05smokecc Titan Problems & Dealer Service 3 01-10-2010 09:56 AM
Truck not starting, starting, and weird gauges MSrockyblue Titan Problems & Dealer Service 19 07-20-2009 05:43 AM
Problems Starting tdibble81 Titan Problems & Dealer Service 3 12-15-2008 09:02 AM
Sentra SE-R Starting Problems grnTitan04 Off-Topic Discussion 7 09-28-2007 09:03 AM
problems starting motorcycle. titanmike Off-Topic Discussion 9 02-11-2007 06:41 PM
SEO by vBSEO 3.3.2
