LinkBack Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 06-18-2004, 06:17 AM   #1 (permalink)
korman100's Avatar
Defrost
It seems that when I turn the defrost on and then back to the normal setting that the AC stays on. By on I mean that even after I hit the AC button (which stays lit after you turn the knob from defrost to normal vents) to turn off the AC cold air continues to blow. I know it is AC air because you can hear the AC system still working to cool the air......it is not just the fan blowing fresh air from the outside. Does anybody else have this issue?
korman100 is offline   Reply With Quote
Old 06-18-2004, 06:33 AM   #2 (permalink)
NissanTech's Avatar
My Frontier did the same thing.It something Nissan does.If you turn defrost off a/c compressor will still cycle till you turn vehicle off.
NissanTech
07 Titan Crew Cab LE
Majestic Blue 4X2
Big Tow pkg
Nav
NissanTech is offline   Reply With Quote
Old 06-18-2004, 06:47 AM   #3 (permalink)
korman100's Avatar
I never noticed it on my 85 nissan 720, 1990 240sx, 1995 240sx, 1998 pathfinder.......
Old 06-18-2004, 07:50 AM   #4 (permalink)
Yep, found this same undocumented "feature" on my LE CC. Haven't checked it out yet on my son's SE KC, but I'm pretty sure I know the answer already. Thanks for posting a thread on this. Once I figured out what it was doing, I kinda forgot about it.
Jim in NH
Copper LE CC (mine)
Born 2/25/04. 4 WD, Big Tow, Nissan Hood Protector, Weatherflectors, Truxedo LoProfile, PIAA 1500 Backup Lights, CompuStar Remote Start, OEM Sirius & Sigma antenna, K&N drop-in.
Galaxy SE KC (son's)
Born 5/10/04. 4 WD, Big Tow, Popular Package w/captains, Utility Bed, Weatherflectors, Truxedo LoProfile, PIAA 1500 Backup Lights, CompuStar Remote Start, K&N drop-in.
jburson250 is offline   Reply With Quote
Old 06-18-2004, 08:35 AM   #5 (permalink)
I believe the reason A/C compressor runs is because there is a canister in the A/C line that removes moister from the air. It's a little weird, but I believe most cars work this way. The reason most of us think that it’s weird is because other manufactures don't light up the A/C light on the dash panel. They only light up the defrost light, but behind the seen everything is working the same.
'04 SE KC 4X4
Galaxy Black
Big Tow
Popular Package
Mods:
Tech Tubes step rails, Truxedo Lo-Profile, K&N CAI, Flowmaster catback exhaust
MB Motoring Express 20"X9", Nitto Terra Grapplers 305/50 - 20
Sylvania Silverstar hi & lows, OEM fog lights, Blacked out OEM Grill
Armada front air dam, 2* timing advance
meckman is offline   Reply With Quote
Old 06-18-2004, 11:33 AM   #6 (permalink)
Send a message via AIM to SPLATT
I have the same issue. Once I run in the defrost mode, no matter what setting I place the selector knob to, the damn compressor will not stop running. I can turn the fan knob to the off position and the compressor still runs. I have to actually turn the engine off to break the cycle the climate control system is stuck in. Yet another frustrating problem with my Titan.
SPLATT is offline   Reply With Quote
Old 06-18-2004, 11:47 AM   #7 (permalink)
The compressor turning on will help to defrost the windows sooner as it de-humidifies the air in the cab.
Slappy is offline   Reply With Quote
Old 06-18-2004, 07:16 PM   #8 (permalink)
homer's Avatar
Years ago I was having the AC serviced on my Firebird and the mechanic told me that the compressor would cycle with the defroster running on GM vehicles. He claimed that the compressor contained a small amount of lubricant that kept the rubber hose from drying out because it was forced to the top when the compressor was running. This was the source of many AC systems losing refridgerant, and by forcing the unit to cycle in cold months when you were running the defroster you kept the hose from drying out and cracking. Made sense to me at the time, don't know if it's bs or not, but I do know that my Camaro cycles when the defroster is running. Maybe the same logic applies to Nissan systems? It doesn't make sense to me that it would continue to run after switching the setting, though.
2004 Crew Cab LE 4WD
Deep Water Blue, Graphite/Titanium
Born 02/16/04
Big Tow, Off Road, Bed Extender, Floor Mats, Splashguards, Bed Mat,
OEM Hood Protector, Putco Stainless Steel Bed Rails
homer is offline   Reply With Quote
Old 06-18-2004, 08:50 PM   #9 (permalink)
love ya all but Ill just keep quit LOL
Titan1027 is offline   Reply With Quote
Old 06-28-2004, 10:14 AM   #10 (permalink)
korman100's Avatar
Just returned from my first 3750miles service. I brought up my defrost issue with the tech. He said the a/c is supposed to come on when you turn on the defrost. I almost punched him in the nose. He just like the service advisor failed to listen to me completly about the a/c compressor running and running no matter what setting you put the selector knob on after you turn off the defroster. Once I explained it I actually had to show him inside the truck. He told me to give him 5 minutes and he would look at it. 10 minutes later he said that is the way the defrost was supposed to work. It will work that way until the key is cycled through on, off, then on again.
Anyone heard the same explanation......or am I getting jerked around????
Old 06-28-2004, 12:39 PM   #11 (permalink)
IMADOGMAN's Avatar
Read your owner's manual (Section 4 page 14). It describes how your defrost "should" work. I would have copied it, but the icon's on the online Owner's Manual, wouldn't copy to the clipboard.
Old 07-01-2004, 12:10 PM   #12 (permalink)
I'm still working on the a/c problem. I'm taking my truck to another Nissan dealer today. I'll explain the problem to this set of techs and provide them a demonstration. I'll post their response, Standby...
I can't believe that each and every time the defrost mode is selected the truck has to be turned off and then restarted so that the a/c compressor will not cycle in modes other then the defrost mode. What the hell kind of engineering is that?
Old 07-02-2004, 12:04 AM   #13 (permalink)
The owners manual states, if you stay in defrost more than a minute the only way to turn off the a/c is to turn the truck off, something like that. It bugged the hell out of me, till I dug out the owners manual. Silly design.
2004 Titan LE King 2WD
Galaxy
Tow Pkg
Mr. Grill from E-bay
DOB: 02/02/2004
Purchased: 03/10/2004
AJfireman is offline   Reply With Quote
Old 07-02-2004, 09:20 AM   #14 (permalink)
Wow that is dumb. That could be beating down some peoples' MPG.
Old 07-02-2004, 02:05 PM   #15 (permalink)
mine doesnt do that, even after i use the defrost i can turn my a/c off and i know my compressor isnt running
04 Titan Crew Cab SE Smoke
68 PT Camaro
KHShapiro is offline   Reply With Quote
