Steering Wheel buttons for Radioo and Bluetooth not working - Nissan Titan Forum
post #1 of 10 (permalink) Old 02-22-2011, 07:41 AM Thread Starter
iTrader Score: 0 reviews
Question Steering Wheel buttons for Radioo and Bluetooth not working
I have a 2008 Pro 4x and the buttons on the left side of the steering wheel stopped working (volume, channel selector, mode and voice command). Any suggestions on where to begin troubleshooting?
Lucashugo7 is offline
Advertisement
post #2 of 10 (permalink) Old 02-22-2011, 10:30 AM
iTrader Score: 3 reviews
Re: Steering Wheel buttons for Radioo and Bluetooth not working
I would start with the fuses. And then the stereo.
mextitan is offline
post #3 of 10 (permalink) Old 08-03-2012, 02:59 PM
I have the same exact problem with my 2008 Titan LE. Problem started yesterday. The only thing that I did was lift the tilt wheel and bring it back to normal. Other research points to a "Clock Spring" or wiring short. Stock stereo, never messed with any internal wiring. Stereo works fine, bluetooth is fine, cruise control on the right side is fine. All controls on the left side are In-Op.
Looks like I might have to go to the dealer and start shelling out the big $$$ unless anyone knows of a fix!
Thanks!
cstotz is offline
post #4 of 10 (permalink) Old 07-31-2013, 08:55 PM
Thanks!
Was anyone able to figure this out??? My volume control, mode, presets, and Bluetooth will only work when the wheel is turned 1/4 turn to the right or left, and does not work while the wheel is straight. I have read all the posts about the spiral cord/clock spring, and I don't think this is the case since everything else works. Cstotz, if you figured it out, please let me know!!!
Thanks
KoloheTitan is offline
post #5 of 10 (permalink) Old 09-17-2013, 09:00 AM
Looking for a solution myself. Seems there are a few threads with others having same issue (even on other Nissan vehicle forums), but no post of resolution. My cruise and horn work fine, all the time, but I can't get any of the switches on the left side for audio and bluetooth to work. I have ordered and tried new switches and that didn't work. I've checked connections to the switches and to the clockspring as well as to the stereo. No luck. I guess the next thing is to replace the clockspring, but I figured if that was going bad, I would have some kind of issue with cruise... Anyway, before I TRY the clockspring, I sure would like to know if anyone else has found resolution......
kingb is offline
post #6 of 10 (permalink) Old 09-19-2013, 08:05 PM
Wagoner 726's Avatar
iTrader Score: 1 reviews
Probably a wiring issue in the steering column. I would open it up and see if any wires are messed up such as unintentional grounding.
2007 Titan SE 2wd CC
Suspension: 5100's/08+ 4x4 springs, 1" rear blocks
Tires: Cooper A/T3 275/70/18
Engine: Airraid, BDGT
Wagoner 726 is offline
post #7 of 10 (permalink) Old 09-19-2013, 08:26 PM
FloppyKnockers's Avatar
If it's an aftermarket HU, try having the modulator reprogrammed. Stock HU, I would look more toward the clock spring or the controls themselves.
Beer makes me smarterer
2009 CC long bed, extra napkins in glove box, ejector seat, 2* timing advance, a couple pens and paper along with a flashlight and candy in center console, Justin Bieber needs to die, I turn the wipers on when it rains, cabin air filters, headlights are good at night, junk mail gets thrown in back seat, forward launching napalm, washing machine parts and tow strap in rear door pocket, flux capacitor, & a full tank of gas.
Recently added: Herpes all over stereo bezel, spider nest in flux capacitor, really bad fart/vomit smell once windows are touched...door handles are where I keep my booger collection.
FloppyKnockers is offline
post #8 of 10 (permalink) Old 09-25-2013, 11:48 AM
I got mine figured out. It was the clockspring! I plugged and unplugged everything in back of the radio and in the steering wheel with no luck. Replaced the clockspring this afternoon and I have full functionality of all buttons.
kingb is offline
post #9 of 10 (permalink) Old 10-26-2013, 08:02 PM
What is the clock spring
MD123 is offline
post #10 of 10 (permalink) Old 10-26-2013, 08:03 PM
And how much was it
MD123 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
working with the 2010 Bluetooth factory system Topcat59 Titan Visual & Audio Discussion 6 02-17-2011 06:59 AM
Door lock buttons not working firestream Titan Problems & Dealer Service 1 03-31-2010 06:38 PM
Steering Wheel Audio Control Buttons, MODE Button 15007875 Titan Interior Discussion 12 05-02-2006 06:56 PM
Should I wax my steering wheel? Bayou Titan Titan General Discussion 1 04-02-2004 08:10 PM
You may post new threads
You may post replies
