ABS and SLIP light - Nissan Titan Forum
post #1 of 39 (permalink) Old 03-03-2011, 03:05 PM Thread Starter
dktitan's Avatar
iTrader Score: 0 reviews
Exclamation ABS and SLIP light
I was driving home today when i stop at one of the stop sign the roads were bare and dry, i stopped gently. The abs kicked on and the ABS and SLIP lights came on. I stopped and cycled the key on and off a few times. The lights went out, then the next time i hit the brakes the abs kicked on again for no reason and the lights came back on. This the first time anything like this happened. I'm thinking about going and getting the codes read if there is any. Any suggestions on this would be greatly appriacted. Thanks
07 KC SE 4x4----- Gone but Definately Not forgotten
Performance: aFe stage 2 intake, Walker B-pipes, CB Vortex, BDPP...
Exterior: Black halo headlights, Black LED tails, Bedliner'd wheels, Bilstein HD front, ICON rear, PRG Mini-lift, Other stuff..
dktitan is offline
Advertisement
post #2 of 39 (permalink) Old 03-03-2011, 03:26 PM
RCHGVR's Avatar
iTrader Score: 7 reviews
Re: ABS and SLIP light
Check your brake fluid
RCHGVR is offline
post #3 of 39 (permalink) Old 03-03-2011, 05:32 PM Thread Starter
dktitan's Avatar
I just checked the brake fluid. It's slightly below the MAX mark on the side of the brake fluid reservior.
dktitan is offline
post #4 of 39 (permalink) Old 03-03-2011, 06:01 PM
4mula1fan's Avatar
Garage
iTrader Score: 3 reviews
Fill it up!!!!
TrainingWheelsWhore™
08 Pro4X
Wife's ride '12 Maxima S Limited Edition
2013 Coachmen Catalina 252RLS Santara Series
Click here for mods
My Pics
4mula1fan is offline
post #5 of 39 (permalink) Old 03-03-2011, 06:16 PM Thread Starter
dktitan's Avatar
Tomorrow i'll go get some brake fluid and fill 'er to the full mark. If indeed it being an ounce or two below full, yet still well above add would cause the two lights to come on and abs to act starnge, i'll be surprised. Yet, Im not a nissan tech. Merely a diesel mechanic..
dktitan is offline
post #6 of 39 (permalink) Old 03-03-2011, 06:22 PM
4mula1fan's Avatar
Garage
Me too. It sound goofy I know. Look at the threads at the bottom of this page...
08 Pro4X
Click here for mods
My Pics
post #7 of 39 (permalink) Old 03-03-2011, 06:33 PM Thread Starter
dktitan's Avatar
Well i looked at the threads and it seems like its a possible cause. I will add some fluid and hopefully it solves the problem. I can't stand lights, even ones that have little importance(Low tire or low washer fluid) lit up on my dash.
dktitan is offline
post #8 of 39 (permalink) Old 03-03-2011, 06:57 PM
4mula1fan's Avatar
Garage
I know what you're saying.
08 Pro4X
Click here for mods
My Pics
post #9 of 39 (permalink) Old 03-05-2011, 08:47 AM Thread Starter
dktitan's Avatar
Well I stopped by advance auto yesterday and had the abs codes read, There was none. So i bought some brake fluid and topped it off, the lights went off for about a minute then driving down the road came back on. The lights will go off once i turn it off and let it set then come back on when i hit my brakes the next time i drive it, then last night they never came on at all. Starting to think it's a loose connector someplace.
dktitan is offline
post #10 of 39 (permalink) Old 03-05-2011, 08:50 AM
4mula1fan's Avatar
Garage
They could need bleeding, maybe...
08 Pro4X
Click here for mods
My Pics
post #11 of 39 (permalink) Old 03-09-2011, 04:52 PM Thread Starter
dktitan's Avatar
Update, i took it to the dealer, they replaced the RF wheel bearing/speed sensor assembly. I suppose the speed sensor failed in it, no more lights and 4 wheel drive works again. However now there is a very slight grinding/rubbing noise, I'm unsure of what it is though, gotta check it out tomorrow.
dktitan is offline
post #12 of 39 (permalink) Old 03-11-2011, 08:59 AM
Im having this same problem right now too, SLIP ABS lights on and my 4x4 wont engage. how much was it for you to get it repaired?
JDub05titan is offline
post #13 of 39 (permalink) Old 03-12-2011, 10:22 AM Thread Starter
dktitan's Avatar
$367 for parts and labor, I could have replaced the wheel bearing myself but i don't have access to a ABS code scanner, so i wasn't 100% sure that was the problem.
dktitan is offline
post #14 of 39 (permalink) Old 03-14-2011, 02:08 PM
Ya brought my truck to the dealer today and they told me I need a RF wheel bearing/ speed sensor too. total cost for me was $456.00 canadian. sucks but could have been alot worse and atleast my 4x4 works now and im not getting stuck everywhere I go/
post #15 of 39 (permalink) Old 03-14-2011, 02:22 PM
DeadRiver's Avatar
iTrader Score: 4 reviews
Send a message via AIM to DeadRiver
the sensor is a $12 part...... you can unbolt it from the back of the brake backing plate and install it without taking the wheel off. The front is a little more cumbersome.
that's all fine and dandy as long as your e-brake shoes didn't delaminate and cause all the ruckus to begin with:
2004 Sedona Titan LE CC 4wd
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
PA Chapter Director
Link to MVP Titans Facebook Page
I should stop having my suit dry cleaned, it seems to kill people.
I'm not worried, I have a Titan with 4wd and a pair of balls.
You can lead a moron to knowledge but you cannot make him think.
I should probably buy more bullets.
The darkest hour is before the dawn.
The Urinator™
DeadRiver is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
SLIP LIGHT> ABS LIGHT> Check Engine Light????? Cricket7 Titan General Discussion 25 05-07-2016 07:44 AM
Slip light and brake light on TitanSnelly Titan Engine, Transmission & Drivetrain 9 12-06-2010 02:43 PM
ANOTHER slip light / brake light thread Tjsteve Titan Problems & Dealer Service 18 02-11-2010 12:56 AM
4x4 engage problem, slip light and brake light on firemountain Titan Problems & Dealer Service 3 12-19-2007 09:10 AM
Lift installed, now i got Slip light, and Brake light.... Robb Titan Suspension 3 08-14-2007 08:07 PM
You may post new threads
You may post replies
