Old 07-02-2004, 09:50 AM   #1 (permalink)
dooboy2112's Avatar
Truck won't Start
I Just installed the K&N Aircharger and now the truck won't start. Has anyone seen this problem. or knows how to fix it.
Here is a link to the install I did
http://www.cardomain.com/memberpage/629486/6
dooboy2112 is offline   Reply With Quote
Old 07-02-2004, 10:36 AM   #2 (permalink)
A couple of thoughts:
1. Is there a sensor or something that got disconnected?
2. Did you leave the doors open while doing the install and drain the battery through the interior lights?
Old 07-02-2004, 10:50 AM   #3 (permalink)
dooboy2112's Avatar
I disconnected the mass air sensor, But re-connected it after the install, The battery is good. The truck will start for about 10 sec than die.
Old 07-02-2004, 10:51 AM   #4 (permalink)
Sammy Sandbag's Avatar
Try disconnecting the battery for at least a couple hours then reconnect it and try to start again.
-Counsel Yourself
Old 07-02-2004, 10:52 AM   #5 (permalink)
IMADOGMAN's Avatar
dooboy, Someone posted that they had put their mass air sensor in backwards...just a thought...you might check it.
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 07-02-2004, 10:54 AM   #6 (permalink)
IMADOGMAN's Avatar
Also, double check that you don't have anything obstructing the intake...plastic? paper?
IMADOGMAN
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 07-02-2004, 12:44 PM   #7 (permalink)
Austin's Avatar
Dooboy - as suggested above, you've likely either installed your MAF sensor backwards or dropped/broken the sensor.
A shutdown 10 seconds after startup is caused by a faulty MAF sensor. The MAF sensor is the main input to the fuel delivery determination - No MAF, no fuel.
MY04 SE King Cab 4X4 SOLD!
Old 07-02-2004, 12:45 PM   #8 (permalink)
EWA Titan's Avatar
The MAF determines the amount of fuel delivered to the engine. The vehicle will start on the starting circuit, but when that is complete if the MAF is not senseing airflow it does not trigger the fuel pump. The MAF is like the reohstat we use in our homes to control the lighting. The more you turn it up, the more current is sent to the light.
MAF= Mass Airflow Sensor
2004 Titan CC BT/OR E locker
Radiant Silver
Factory Neoprene Seat Covers
Bed Extender
Bug Shield
AW Floor mats
Truxedo Bed Cover
Vent Visors
Custom Bed Mat and Floor Cover
Ignorance is Bliss
http://members.cardomain.com/ewatitan
EWA Titan is offline   Reply With Quote
Old 07-02-2004, 01:21 PM   #9 (permalink)
If you have confirmed that the air meter is installed correctly, then check the ground wire that is installed under the mid-bracket. I'm not sure about the titan's ecu but the ford 5.0 will run without the mass air connected(in limp mode) he he he said limp
good luck
dandy is offline   Reply With Quote
Old 07-02-2004, 02:15 PM   #10 (permalink)
dooboy2112's Avatar
I will check the MAF sensor when I get home. To see if it is working or install backwards.
Old 07-02-2004, 07:02 PM   #11 (permalink)
dooboy2112's Avatar
That was it, I turned the MAF sensor around and now she starts. Thanks for the help
Old 07-02-2004, 09:03 PM   #12 (permalink)
IMADOGMAN's Avatar
I would be celebrating...glad it was a simple fix for you!
IMADOGMAN
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 07-02-2004, 09:42 PM   #13 (permalink)
avroflyer's Avatar
Uhhhh... huh huh.... limp mode.
I have seen people talking about disconnecting the battery overnight to clear the ECM, but there is a quicker way (I think). I use the Frontier method of disconnecting the negative, turning the key all the way to start for 10 seconds then off, then connect the negative terminal. No negative effects so I assume it works.
As for the MAF, I saw that mine had two white stripes which I assume meant "this side up" (actually, I just got lucky and noticed them before removing the MAF).
How did the install on the Air Charger go anyhow? Better guidance than the Volant I assume?
_________________________
Jim Reeves
Canteen (its not for everybody!!!) King Cab SE 4X2
Off-Road, Big-Tow, RF power-captain
Mods:
PRG Front Level
Magnaflow single 3" in dual 2.5" out exhaust
K&N Series 77 Intake
ARE LSII Hard Tonneau
MAAP Challenger Tube Steps
Carriage Works Billet Grille
American Racing Burst Wheels
Aluminum Dash Accents
Aluminum Pedals
avroflyer is offline   Reply With Quote
