Old 07-19-2004, 08:01 PM   #1 (permalink)
TSB on Brake Judder and Service Issue
Well, my first unfun experience with the Service Department has just started. Scheduled my 7500 mile service last Friday and noted to the Service Writer that there was a TSB out on Brake Judder (thanks to this website), which he said he would have to research.
I decided to solve his "research" and printed off a copy and took it in with me this morning. Just got my truck back, brought the receipt home and started looking and found that all it notes they did was turn the rotors. Yet the TSB says specifically that they must follow the entire procedure, which includes replacing the brake pads and burnishing them.
So this begs the question of why did I take the time to provide them the document if they aren't going to follow it? Now I have called the head man still at the dealer and faxed him a copy of the TSB. He said he will take it up with the Service Manager tomorrow.
This is beyond frustrating!!! More to follow as this develops.........
SE Crew Cab Born on 03/04
Big Tow, Popular, and Utility Bed Packages. OEM Hood Protector, Seat Covers, and Fog Lamps
Fram Air Hog Filter, Chrome Nerf Bars, RollBak Tonneau, Husky floor liners
Birdhunter is offline   Reply With Quote
Old 07-20-2004, 05:06 AM   #2 (permalink)
You did the right thing by contacting the Head huncho. Sometime you will just encounter a person with a busted lamp in the head. Good luck.
Jericho9mm is offline   Reply With Quote
Old 08-02-2004, 01:55 PM   #3 (permalink)
ozzy150's Avatar
Send a message via AIM to ozzy150
Did your wheel pull to either side when you braked because of this problem. And to solve the problem, all you did was take the print out in and have them fix it under warrenty correct? Poor titan, i can't wait till all my problems are solved.
Titan SE 4x2 DeepWater
K&N CAI
jaSceN
ozzy150 is offline   Reply With Quote
Old 08-02-2004, 02:35 PM   #4 (permalink)
caltitan's Avatar
I'm taking my Titan in for service tomorrow to address the brake judder and radio FM problem. I have ~1200 miles on the truck and experienced the brake judder about 3 times over the last couple of weeks when braking for red lights downhill at highway speeds (55 mph zone) while going straight. It has been a different feel than the ABS pulsing and the tail end of the truck (unloaded) acted like it wanted to fishtail during one of the episodes. It has happened while braking steadily, not hard or emergency braking. The judder feels like it is coming from the front wheels only. There has been no strong brake odors after this happened. My brake feel has been steadily decreasing with the pedal becoming more mushy. I hope they aren't going to tell me they can't duplicate it so they won't work on it. The service guy did tell me on the phone that they know there is a problem with the brakes on some Titans.
2004 Titan SE KC 2WD
Flowmaster 70 Series Muffler, Magnaflow Resonators, AEM Dryflow Intake, Airaid TBS, Uprev Osiris Flash, ECO-3, Big Tow Package, ActiveTuning Grounding Kit, Crown Performance SS/Kevlar Brake Lines, PRG Leveling Kit & Rear Blocks, Nitto Terra Grappler 285-60-18 Tires, Truxedo Lo Pro Tonneau
caltitan is offline   Reply With Quote
Old 08-03-2004, 04:24 PM   #5 (permalink)
caltitan's Avatar
As planned. Nissan worked on the brakes today and at 1,304 miles the front rotors were starting to warp. They did not replace the rotors but did resurface them. Pads were also replaced. As I understood it, the service rep was telling me that there is a design flaw that can cause the calipers to overheat which result in a misalignment of the pads against the rotor and over time warps the rotor. This flaw is especially prone to any type of braking that causes extra heat build up (i.e., hard braking, emergency stops, downhill braking). Although there is a TSB out, they were told by Nissan that engineers are still working on the brakes to find a better fix. They told me to bring it in again if the brake judder returns or the pedal becomes mushy again (like I needed to be told that).
Old 08-03-2004, 06:07 PM   #6 (permalink)
zpylot's Avatar
Nissan is trying to compete in the American Truck Market. They are just duplicating the service the big 3 give. If it's any comfort Acura service was/is the same way.
"Dogs love trucks."
2004 Nissan Titan SE KC 4x2 Build 04/03/2004, VIN# 540061, Purchased 4/21/04 - Popular with Captains, bedliner, splashguards. Kenwood DDX7015 HU, Westin Oval Tube Steps
2004 Nissan 350Z Roadster Delivered 8/14/03
zpylot is offline   Reply With Quote
Old 08-03-2004, 06:35 PM   #7 (permalink)
I followed juma's lead and ordered the speed bleeders so I can bleed the brakes without assistance. I am thinking that hey, if they aren't filling the differentials, they might not be bleeding the brakes either.
Old 08-03-2004, 07:37 PM   #8 (permalink)
FLfinfan's Avatar
good point!
FLfinfan is offline   Reply With Quote
