2004 fuel filter problems? - Nissan Titan Forum
post #1 of 11 (permalink) Old 10-17-2011, 02:21 PM Thread Starter
iTrader Score: 0 reviews
I have a 2004 Titan and when i'm driving it seems as though it isn't getting any gas. It just putts, almost like its giving out of gas even though I know there is plenty of gas in it. It only happens after I drive somewhat long distances( 2 hrs + ). But today it did it after only about 30 mins. It occurs when I speed up to either pass someone or go uphill. Also, it seems to do fine until I reach about 40 mph. Has this happened to anybody else? Please help. thanks!
tylerm1705 is offline
Advertisement
post #2 of 11 (permalink) Old 06-09-2013, 04:11 PM
Re: 2004 fuel filter problems?
I hear the filter is located in the gas tank. I feel my mileage is bad right now but still runs and pumps fine. What else shoul I chane to get better mileage? Spark plugs? Anything else? Has 150,000 miles on her looking for another 150,000
groffma is offline
post #3 of 11 (permalink) Old 06-09-2013, 07:49 PM
baseballfanz's Avatar
iTrader Score: 1 reviews
The filter is not really anything more than a mesh/sponge at the fuel pump. At 150K miles change the spark plugs, pcv valves.
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #4 of 11 (permalink) Old 06-09-2013, 08:02 PM
AZPRO4X's Avatar
iTrader Score: 8 reviews
Wouldn't hurt to replace the fuel pump either. That thing has ate through alot of fuel over 150k miles and might be getting week.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline
post #5 of 11 (permalink) Old 06-09-2013, 08:05 PM
sudden urge's Avatar
iTrader Score: 4 reviews
The fuel pump either works or not; no reason to change it till it fails.
Chicago area 05 KC SE 4x2 FFV, smoke, 2.94 gearing. Mods: Hypertech Max Energy, JBA catback, Airaid 4" MXP CAI, Hellwig HD traction springs, 08 rear shackles, Nasta nerf bars, Kenwood KSC-SW1 powered sub. Best full street trim (5120#) 1/4 mile track time of 14.632 running Bully Dog 87+2 and S&B CAI. 1/8 mile 9.30@74.49 with a 2.11 60'.
sudden urge is offline
post #6 of 11 (permalink) Old 06-09-2013, 10:31 PM
AZPRO4X's Avatar
In a perfect world yes, but pumps will get weak and start to lose there ability to put out the correct PSI which can lead to hesitation/starving for fuel. There is a port on the fuel injection rail for checking the PSI.
AZPRO4X is offline
post #7 of 11 (permalink) Old 06-10-2013, 07:18 AM
TitanZ04's Avatar
Have you tried any fuel additives such as, STP, Slick-50, Lucus etc.?
TitanZ04 is offline
post #8 of 11 (permalink) Old 06-10-2013, 08:20 AM
AZPRO4X's Avatar
I'm guessing you have a bigger issue going on and those things won't help. When has the last time have you had the truck in for a complete tune up ? I would do that first if it's been a long time and I would still have the fuel PSI I checked to make sure it's not the fuel pump going out.
AZPRO4X is offline
post #9 of 11 (permalink) Old 06-18-2013, 01:57 PM
ALtitan's Avatar
Fuel Pump is on the way out. Mine did the same thing and it only gets worse with time. It only would act up on a long drive or under a heavy load. Local auto parts store should have a pump for about $200. Get that tank as low as possible, a jack and a good friend, and its not a big job. Hope this helps
ALtitan is offline
post #10 of 11 (permalink) Old 06-18-2013, 02:01 PM
StormTroopin's Avatar
iTrader Score: 20 reviews
Would yours rev like normal, in neutral or park? I'm 99% sure my pump is going out, it only acts up above 2800-3000 rpms... Perfectly fine out of gear though.
Sent from AutoGuide.com App
MeatBeaterWhore™ TwinTwit #1 "The Big O" Maverick!
GO DUCKS!
StormTroopin is offline
post #11 of 11 (permalink) Old 06-19-2013, 05:34 PM
ALtitan's Avatar
Yea ItWould Rev Like Champ Until IT Was Under A Load... It Was Intermittent At First AndSlowly Just Got Worse And Worse...
New Pump And All Is Well
ALtitan is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
fuel filter buzzsilago Titan Engine, Transmission & Drivetrain 18 12-06-2011 10:09 PM
Fuel Filter Walrus Titan General Discussion 9 07-16-2011 07:14 AM
Fuel filter, water in fuel or transmission? JDos1 Titan Problems & Dealer Service 13 06-13-2010 09:05 PM
Where is my fuel filter! bb123 Titan General Discussion 11 09-14-2009 01:06 AM
oil filter found; fuel filter??? juma Titan General Discussion 2 04-18-2004 12:06 PM
You may post new threads
You may post replies
