Battery Drain? - Nissan Titan Forum
post #1 of 15 (permalink) Old 10-20-2011, 08:57 PM Thread Starter
CVTitan05's Avatar
iTrader Score: 5 reviews
Battery Drain?
Hey everybody, i have a 84 month Nissan battery that every once in a while will die randomly when i try and crank it over.
I have my stereo system and an aftermarket alarm, but the stereo system draws no power when off, and the alarm does almost nothing.
Me and my dad were doing test on it, we would start the truck, and take the neg off, and the truck didnt hesitate at all, so the alternator is fine.
Battery is full with the water, and we have a "gravity tester" which showed the battery was perfectly okay.
But we turn the truck to ACC, so things come on, but the motor was off, and we played the stereo with the headlights/highbeams on. And the battery died within 30 sec. After 30 sec, the stereo would power off, then come back on, and the motor wouldn't turn at all, just CLICK CLICK CLICK.
So the battery is holding a charge, enough for it to sit for a few hours, and sometimes overnight, but it drains VERY quickly with external power.
Is the battery bad? I was thinking about going with a Duralast Gold from AutoZone for $112 w/ 3 year replacement warranty.
What else could it be?
2005 Titan KC XE 2wd. Dirt King Mid Travel SOLD
2008 Titan CC XE 2WD. Stock. For now...
2005 Titan CC SE 4x4 6" Procomp Stage 2 Lift
CVTitan05 is offline
Advertisement
post #2 of 15 (permalink) Old 10-20-2011, 09:02 PM
vipzach's Avatar
iTrader Score: 6 reviews
Re: Battery Drain?
Your OEM battery has lasted along time. Many don't make it 84 months!
Sure sounds like a battery that is on it's last leg.
The Duralast battery should be just fine.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Zlacher whore™
vipzach is offline
post #3 of 15 (permalink) Old 10-20-2011, 09:03 PM Thread Starter
CVTitan05's Avatar
Re: Battery Drain?
Well it was replaced by the dealer when i bought it April of 2010. So it hasn't been very long.
post #4 of 15 (permalink) Old 10-20-2011, 09:07 PM
vipzach's Avatar
Re: Battery Drain?
Sorry, I misread your first sentence. I thought it said 84 months old.
Take the battery to autozone and have it load tested.
It still sounds like you have a battery with a weak cell.
Zlacher whore™
vipzach is offline
post #5 of 15 (permalink) Old 10-20-2011, 09:11 PM Thread Starter
CVTitan05's Avatar
Re: Battery Drain?
Ok, ill do that tomorrow, for now itll be on the battery charger over night. And if it comes up bad, ill get the new battery at autozone while im there.
post #6 of 15 (permalink) Old 10-20-2011, 09:27 PM
Walrus's Avatar
iTrader Score: 19 reviews
Re: Battery Drain?
Your battery has a bad cell.
Load test will prove it.
BaldWhore
Starfishwhore
Red meat is not bad for you.
Fuzzy green meat is bad for you.
You know you had a great night last night when you make it home the next day missing more than half your clothes.
It's not the zombies you have to watch out for. It's the stupid people.
Walrus is offline
post #7 of 15 (permalink) Old 10-20-2011, 09:34 PM Thread Starter
CVTitan05's Avatar
Re: Battery Drain?
Well if its an 84 month battery, could i take it to nissan and they would trade it out for a new one?
post #8 of 15 (permalink) Old 10-20-2011, 09:35 PM
Walrus's Avatar
Re: Battery Drain?
Probably.
There has got to be some kind of warranty.
It is not uncommon for a cell to go bad and when it does, it does exactly what you described.
BaldWhore
Starfishwhore
Walrus is offline
post #9 of 15 (permalink) Old 10-20-2011, 09:37 PM Thread Starter
CVTitan05's Avatar
Re: Battery Drain?
Ok, i guess ill do that first and save myself the $112
post #10 of 15 (permalink) Old 10-20-2011, 09:41 PM
dubyam's Avatar
iTrader Score: 0 reviews
Re: Battery Drain?
walleeme is dead on. You've got a bad cell. Funny thing is, batteries with bad cells will gravity just fine, but they discharge ultra quick. Sometimes, you can put one on to charge, and charge it well through past when it should be fully charged, and the bad cell will clear. Not totally positive why, but I think bad cells are oxidized lead plates, and when you overcharge the battery, it will finally break through the oxidation and end up cleaning off the plate, rendering the cell workable. That might be totally off base, though. If you decide to overcharge the battery, be sure it's well ventilated, and the caps are off, so it won't explode.
If the battery is "new" from Nissan (and not a pull out or a second/blem) you should be good on a warranty. Don't read too much into my concern about seconds/blems, as most dealers wouldn't do that without notifying you. It did happen to a friend of mine once, though, and he got shafted on the warranty in that deal. Of course, he doesn't do business with those folks anymore, and neither do a lot of the rest of us, so what comes around goes around.
dubyam is offline
post #11 of 15 (permalink) Old 10-20-2011, 09:45 PM Thread Starter
CVTitan05's Avatar
Re: Battery Drain?
Yeah, its just a battery tender so its charging at 2 amps. But the charger says its already fully charged, im just leaving it on just in case. If it clears the oxidation, then great, but this will be the second time ive charged it overnight.
And when i bought the truck, it was from a Honda dealer but its got a sticker 04/10 which is the date they installed it. So i believe its an original battery. The honda and nissan dealers are right next door too
post #12 of 15 (permalink) Old 10-20-2011, 10:04 PM
NBhunter80's Avatar
Re: Battery Drain?
Bad battery... replace and it will be good. Once you have completely discharged a conventional battery, it is usually done for.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, 33x12.50r17LT Hercules Trail Digger tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #13 of 15 (permalink) Old 10-20-2011, 10:09 PM
Re: Battery Drain?
Been there done that. My battery tested perfect, the store even put a load tester on it repeatedly and everything supposedly checked out ok. Problem solved with a new one.
cowhead is offline
post #14 of 15 (permalink) Old 10-21-2011, 08:21 AM
Mo-Titan's Avatar
iTrader Score: 24 reviews
Re: Battery Drain?
Same exact boat here man, she'll click click or roo roo start everytime. Getting a new battery on my lunch break today.
Titan Sold - 3-06-2012, Plan Z = '96 BMW Z3 - Traded 7-13-12 (Friday the 13th)
Mo-Titan is offline
post #15 of 15 (permalink) Old 10-21-2011, 10:06 PM Thread Starter
CVTitan05's Avatar
Re: Battery Drain?
They replaced the battery no questions asked brand new 12 cell battery, instead of my old 6 cell battery that was in it, then i went and picked up my new LG Thrill 4g. Todays been a good day!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
battery drain HELP? gqsap Titan Problems & Dealer Service 10 11-06-2011 10:02 PM
parasitic drain on battery! no fear titan Titan Problems & Dealer Service 6 11-14-2010 05:32 PM
will cortex upload drain battery fl9452 Titan Performance Modifications 3 01-12-2010 10:43 PM
Where is oil pan and drain plug? BlackTitan08 Titan General Discussion 13 11-23-2007 09:14 PM
Fram Sure Drain?? silverbeast Titan Engine, Transmission & Drivetrain 31 10-18-2007 09:37 PM
You may post new threads
You may post replies
