Hey folks, a couple of weeks ago I was in the Nissan dealership to talk to their technicians and they looked into the problem. Their answer is what it was something to do with the brain of the truck. So it is not a defect or a problem.
After they explained how to work the window I have not had a problem. You won't have a problem with the window going down it's only coming up. If you were like me I just quickly lifted and let go. The driver window would come up but not the passanger window. So you sit there and keep lifting up and nothing happens. Wait a while and whala, your window goes up.
Solution, according to Nissan, was to hold the up buttons for a split second longer when rolling them up. IT WORKS. If you still do it too quick then wait 10 seconds for the computer brain to reset itself and then you can roll up the window. Why they would set the brain up that way is beyond me. Hope that helps you.
