E-Brake Parking Brake Failure 2008.5 Video - Nissan Titan Forum
post #1 of 54 (permalink) Old 02-03-2012, 09:12 AM Thread Starter
iTrader Score: 3 reviews
Inner brakes pads / shoes broke and caused some damage
59,000 miles 2008.5
Nick
2008.5 LE 4x4 CC
Goodyear Duratracs on Stock 20"
35W 5000 HIDs (for high beams)
22" Magnaflow & Vibrant UQ Resonator
Bullydog GT (reg. tune + 2*)
AirAid 4" MXP CAI
TruXedo Lo Pro QT Tonneau
Nick741 is offline
The Following 2 Users Say Thank You to Nick741 For This Useful Post:
gweasel77 (02-04-2012), sudden urge (02-03-2012)
Advertisement
post #2 of 54 (permalink) Old 02-03-2012, 09:27 AM
mcginkleschmidt's Avatar
iTrader Score: 0 reviews
Re: E-Brake Parking Brake Failure 2008.5 Video
Yipes, a damn expensive mess! It goes to show that just like the ol' bumper sticker reads, **** Happens.
It seems like you have the wherewithall to fix it yourself that will soften the financial blow somewhat.
mcginkleschmidt is offline
post #3 of 54 (permalink) Old 02-03-2012, 09:35 AM
TitanOscar's Avatar
iTrader Score: 1 reviews
How common is this failure? anyone know?
I said it before and I will say it again! NEXT YEAR IS HERE! Go CUBS Go!
TitanOscar is offline
post #4 of 54 (permalink) Old 02-03-2012, 11:22 AM Thread Starter
I'm not sure if this is common but I use my E-brake a lot when loading and unloading my boat at boat landings.
The gernaded part could have been avoided if I would have replaced the inner pads as soon as i heard the clicking but I put it off for a while and bam! on my way home from work my truck made a big thud and the rear tire locked up for a second. I thought I blew up the rear end but it was the bracket being broke off
Nick
2008.5 LE 4x4 CC
AirAid 4" MXP CAI
Nick741 is offline
post #5 of 54 (permalink) Old 02-03-2012, 08:34 PM Thread Starter
The red arrow shows the part that broke off. I hope that is part of the bracket I ordered today???
Looks like I'll need to pull the axle to get the new bracket in place
Nick
2008.5 LE 4x4 CC
AirAid 4" MXP CAI
Nick741 is offline
The Following User Says Thank You to Nick741 For This Useful Post:
post #6 of 54 (permalink) Old 02-03-2012, 08:52 PM
NBhunter80's Avatar
I had the same thing happen in december but mine took out the axle seal and the parking brake actuator when it went. Doh!
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #7 of 54 (permalink) Old 02-03-2012, 09:05 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
Nissan doesn't cover this under the 5/60 warranty? I can understand that it doesn't cover the e-brake pads but...
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
The Following User Says Thank You to HRTKD For This Useful Post:
post #8 of 54 (permalink) Old 02-03-2012, 10:33 PM
NBhunter80's Avatar
FYI that part that broke off on your truck is the bracket to mount the parking brake actuator and parking brake shoes. It seems like we had the exact same failure mechanism, except mine just bent the actuator in half instead of braking the bracket off. The actuator bending and falling off of its mount and into the teeth of the speed sensor wheel is likely what took out my axle seal.
The Following User Says Thank You to NBhunter80 For This Useful Post:
post #9 of 54 (permalink) Old 02-04-2012, 04:01 AM
gweasel77's Avatar
Garage
iTrader Score: 6 reviews
Its a pretty common problem from what i've seen. My parking brake doesn't work either...
2005 NISSAN TITAN SE KC
IRCVK56/TEAMVK56 Crew Chief
performance:
UP/REV (RB's TUNED)
4" Airaid MXP CAI w/ RC2 Black Hex Series Air Filter & GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF 2 Core Rad w/ Fumoto QuikValve / Nismo 170*F T-Stat / NGK Iridium IX Plugs / TruCool SR4588 / Nismo LT Header's / BerkTech B-Pipes w/ MF Hi-Flows / FlowMaster Y-Pipe / BORLA XR1 / Relentless RPM Gen2 Catch Can / Detriot TruTrac LSD / Grounding Kit / Burnout Mod / IAT "Reaper Mod" / LP Mod / MT ET Street P295/45R/17 DR's
exterior/suspension:
Ruff Racing R286 22"s w/ 305/45/22 Toyo Proxes ST2's / Slotted "Cryo" Frozen Rotors / Hawk LTS Pads / Gatorback Poly-V Serp Belt / Stillen Diff Cover / PRG Street Bars / Hellwig RSB / Bilstein 5100's & HD's / MOOG Springs / SpringTech Drop Shackles / PRG camber bolts / CF wrapped Interior / Morimoto XB 6K HID's / Full LED Retrofit / LED Cube Fogs / Diode Dynamics Tails, TRS Switchback Signals / Morimoto XB Reverse
PB 2014: 1/4- 13.55 @ 98.5MPH
Next Mods: CAJUN 2.5"-3" Y-Pipe Kit
gweasel77 is offline
post #10 of 54 (permalink) Old 02-04-2012, 05:03 AM
I had similar issue with my actuator bending and everything exploding as well
Sent from my iPhone using Autoguide
2005 galaxy cc 4wd, 2" prg leveling kit, prg sway bar links, bilstien hds, 6k HID, stillen front sway bar with prothane bushings, Pro comp 18s, windows 5% tint, 3" true duals w/flowmaster super 44, airaid mxp, superchips cortex, tinted tails, tru trac
crajas88 is offline
post #11 of 54 (permalink) Old 02-04-2012, 08:06 AM
HRTKD's Avatar
Garage
I guess I'm going to add parking brake pads to my preemptive replacement list. What source are you guys using for those parts?
HRTKD is offline
The Following 2 Users Say Thank You to HRTKD For This Useful Post:
gweasel77 (02-05-2012), Nick741 (02-10-2012)
post #12 of 54 (permalink) Old 02-04-2012, 09:13 PM Thread Starter
I'll ask my service guy about this???
Nick
2008.5 LE 4x4 CC
AirAid 4" MXP CAI
Nick741 is offline
post #13 of 54 (permalink) Old 02-17-2012, 08:41 AM Thread Starter
My dealer says the part # for a new bracket is not on the drivetrain warranty
I'm glad it was only $100. for a new one but I will need to pull the axle to replace it
After asking around I found out this happened on my bother in-laws Blazer and a friend from work said his brothers ford did the same (shoes falling off the backing plates).
Nick
2008.5 LE 4x4 CC
AirAid 4" MXP CAI
Nick741 is offline
gweasel77 (02-17-2012)
post #14 of 54 (permalink) Old 02-18-2012, 11:00 AM
AZPRO4X's Avatar
iTrader Score: 8 reviews
I'm thinking about just removing mine completely. I have use my parking brake maybe 4 times since I bought it.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
2016 XD Pro4X Gasser
AZPRO4X is offline
post #15 of 54 (permalink) Old 02-19-2012, 06:27 AM
nyc2005armada's Avatar
The parking brakes on these trucks are worthless, I have had to change to sets already on an Armada and Titan and they are pain in the rear. I know I will be replacing mine when I go and do my brakes within the next week or two.
Performance mods: DT Long tube headers, hi-flow Magnaflow cats, Injen intake, 07 style exhaust pipes, 22 inch magnaflow muffler (12588) Cross drilled/slotted front rotors, Bilstein 5100 front shocks.
Exterior Mods: Stock LE rims, painted Nissan Galaxy black with Nismo center stickers, 5000k headlights and 6000k fogs
Interior mods: All red led instrument cluster, 12 in JL sub, 250W mono sub.
nyc2005armada is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
video parking brake bypass? gadget74 Titan Visual & Audio Discussion 37 08-11-2012 01:14 AM
parking brake big bruce Titan General Discussion 8 12-01-2009 03:57 PM
DIY on parking brake fix? gr8titan Titan Wheels, Tires & Brakes 19 06-30-2009 05:19 PM
Parking Brake jterrell Titan Problems & Dealer Service 1 06-19-2007 02:56 PM
parking brake. amati5 Titan Problems & Dealer Service 9 04-19-2004 01:37 PM
You may post new threads
You may post replies
