Vehicle Immobilizer System - Nissan Titan Forum
post #1 of 8 (permalink) Old 03-12-2012, 07:45 PM Thread Starter
iTrader Score: 0 reviews
I bought a 2011 PRO 4X two weeks ago. I haven't had any issues until today. After getting home from the grocery store, turning off the truck and bringing in the groceries, I went back outside to activate the alarm. Nothing happened when I pressed the button on the key fob. Thinking the battery was dead, I grabbed the second fob with no luck. I then consulted the trusty, seemingly useless, owner's manual and found that the problem is probably the VIS. I followed the instructions on pages 2-26 and 2-27. Even repeated the process about 15 times and used a stopwatch to make sure I was getting the timing right. Nothing!
Any help is greatly appreciated. I have to be at work in the morning.
navyhamm is offline
Advertisement
post #2 of 8 (permalink) Old 03-12-2012, 07:54 PM
IGotLost's Avatar
Re: Vehicle Immobilizer System
If you just bought it two weeks ago, why not let the dealer take care of it?
Why is there never enough time to do it right the first time,
But always enough time to do it again?
IGotLost is offline
post #3 of 8 (permalink) Old 03-12-2012, 07:55 PM Thread Starter
I'd love to let the dealer take care of it. Problem is, I have to be at work tomorrow at 0700 and my family only has one vehicle. Thanks for the advice.
navyhamm is offline
post #4 of 8 (permalink) Old 03-12-2012, 09:00 PM
n2titan's Avatar
iTrader Score: 2 reviews
None of the buttons in the key fob works?
Are all the doors closed?
Can you get inside?
Can you start the truck?
Sorry just trying to brainstorm.
n2titan is offline
post #5 of 8 (permalink) Old 03-13-2012, 04:20 AM Thread Starter
No worries, N2TITAN. None of the buttons on either fob work, the doors are all closed but not locked and I can't start the truck. This thing is so "immobilized" that the interior lights won't even come one...
navyhamm is offline
post #6 of 8 (permalink) Old 03-13-2012, 04:36 AM
gweasel77's Avatar
Garage
iTrader Score: 6 reviews
I remember with my Infiniti J30 i had a small problem with the VIS & the horn would not stop honking sometimes. To disable it you had to close & lock the drivers door, then put the key in the door & turn it to unlock 3 times, then unlock or something very similar & it would reset it.
2005 NISSAN TITAN SE KC
IRCVK56/TEAMVK56 Crew Chief
performance:
UP/REV (RB's TUNED)
4" Airaid MXP CAI w/ RC2 Black Hex Series Air Filter & GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF 2 Core Rad w/ Fumoto QuikValve / Nismo 170*F T-Stat / NGK Iridium IX Plugs / TruCool SR4588 / Nismo LT Header's / BerkTech B-Pipes w/ MF Hi-Flows / FlowMaster Y-Pipe / BORLA XR1 / Relentless RPM Gen2 Catch Can / Detriot TruTrac LSD / Grounding Kit / Burnout Mod / IAT "Reaper Mod" / LP Mod / MT ET Street P295/45R/17 DR's
exterior/suspension:
Ruff Racing R286 22"s w/ 305/45/22 Toyo Proxes ST2's / Slotted "Cryo" Frozen Rotors / Hawk LTS Pads / Gatorback Poly-V Serp Belt / Stillen Diff Cover / PRG Street Bars / Hellwig RSB / Bilstein 5100's & HD's / MOOG Springs / SpringTech Drop Shackles / PRG camber bolts / CF wrapped Interior / Morimoto XB 6K HID's / Full LED Retrofit / LED Cube Fogs / Diode Dynamics Tails, TRS Switchback Signals / Morimoto XB Reverse
PB 2014: 1/4- 13.55 @ 98.5MPH
Next Mods: CAJUN 2.5"-3" Y-Pipe Kit
gweasel77 is offline
post #7 of 8 (permalink) Old 03-13-2012, 05:24 AM
n2titan's Avatar
Are you sure the battery is not dead?
Does the hazard button work, how about the brake lights?
Try disconnecting the battery for 15 minutes.
n2titan is offline
post #8 of 8 (permalink) Old 03-13-2012, 05:43 AM
n2titan's Avatar
Is your key on a key ring with other devices ie. Mobil speedpass?
I've read that sometimes that can screw with the VIS.
n2titan is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Emergency! Vehicle Immobilizer reset help needed ASAP! barelycontainedchaos Titan FAQ & How to Area 32 03-18-2014 04:41 AM
How to tell if I have the engine immobilizer iamdan Titan General Discussion 4 01-10-2011 10:13 AM
Need help now! Immobilizer, key locked in the ignition TheHun Titan General Discussion 33 03-05-2010 10:07 PM
Nav System - vehicle in motion dss90c Titan Visual & Audio Discussion 3 10-11-2005 07:50 PM
Vehicle Immobilizer System raskm Titan General Discussion 8 11-23-2004 11:08 AM
You may post new threads
You may post replies
