Strange Cabin Noise - Nissan Titan Forum
post #1 of 16 (permalink) Old 04-06-2012, 08:06 PM Thread Starter
Catfish787's Avatar
iTrader Score: 0 reviews
Strange Cabin Noise
Watch the video I posted. Below is description and video of the problem.
The problem I am experiencing can best be explained by the video I will be attaching with this post. The best way I can describe the sound is that it sounds like someone is tapping a hammer underneath my dash. This happens every time I shut off my vehicle and it happens approximately 2 minutes after the vehicle is shut off. The sound has been present for around 6 months now and does not appear that it will go away on its own. I'm not sure if this is a characteristic of the vehicle or a common problem. The one thing that I can recall before the sound started was that the vehicle made a sound similar to a valve turning off or something of that nature. This was a smooth and methodical sound, this is something much different. I hope this information helps.
Video Here:
If anyone has any idea what this might be, please let me know!
2005 Nissan Titan LE
Catfish787 is offline
Advertisement
post #2 of 16 (permalink) Old 04-06-2012, 08:31 PM
iTrader Score: 5 reviews
Re: Strange Cabin Noise
a gremlin under your dash with a hammer?
I have never heard that noise before. I first thought it was the actuator in the heater that was making the noise until I watched your video
2014 Silver Ram Laramie 4x4 w/ leather and Alpine sound
2008 Red Brawn Titan SE 4x4 Popular package
ArmyAviation is offline
The Following 2 Users Say Thank You to ArmyAviation For This Useful Post:
Catfish787 (04-07-2012), gweasel77 (04-07-2012)
post #3 of 16 (permalink) Old 04-06-2012, 09:21 PM
iTrader Score: 4 reviews
Does the heat work?
bestatchess is offline
The Following 3 Users Say Thank You to bestatchess For This Useful Post:
Catfish787 (04-07-2012), DRTYAZN (04-07-2012), gweasel77 (04-07-2012)
post #4 of 16 (permalink) Old 04-07-2012, 04:30 AM Thread Starter
Catfish787's Avatar
The heat and A/C works fine. No strange sounds when it is operating. This problem only happens when after the vehicle has been turned off, as described above.
post #5 of 16 (permalink) Old 04-07-2012, 08:47 AM
wabulldogger's Avatar
iTrader Score: 1 reviews
mine is making that noise as well after shut off and it does it sometime when i turn the heat or air on any setting other then defrost
Volant cold air, Gibson Metal Mulisha exhaust. Cajun catless pipes. Stillen LongTube headers, Uprev custom Tuned!!!
EXTERIOR:
pro comp 6 inch.37IN NITTO Trail Grappler MT on 20 inch Fuel Hostages. custom grill. RADFLOS w external RES on the front, PRG Upper control arms, Prg sway bar end links, bush wackers custom painted. deaver c30 leafs in the rear, radflo pigy backs in the rear and PRG offroad traction bars
INTERIOR:
Kenwood 8120 double din. Hertz High energy 6 1/2 componets all around, 2 JL Audio 13-TW5 Shallow Mount Subs
in custom box. Alpine pdx 4.150 for doors. pdx 1.1000 for subs
wabulldogger is offline
The Following User Says Thank You to wabulldogger For This Useful Post:
post #6 of 16 (permalink) Old 04-07-2012, 09:11 AM
MayhemMOORE's Avatar
iTrader Score: 2 reviews
If it is happening after you shut the truck off my bet is it has something to do with the recirc door or actuator. I believe it closes after a certain amount of time once the truck is shut off. I can hear mine, but as you stated, it is a smooth sound like a valve.
LousyLuckWhore™
2010 Pro-4X CC Galaxy Black
100K mile club on 10/1/15
MayhemMOORE is offline
The Following User Says Thank You to MayhemMOORE For This Useful Post:
post #7 of 16 (permalink) Old 04-07-2012, 10:46 AM
05beast's Avatar
Mine started doing it also about a year ago!
Mod #1 - Plasti dipped emblems
Mod #2 - Painted Engine Cover
Mod #3 - PD'd bumper
Mod #4 - VHT black taillights
Mod #5 - PD'd front bumper and grille
Mod #6 - PD'd wheels
Mod #7 - 5% tint all the way around
Mod #8 - Dynomax race bullet muffler dumped under rear passenger door.
Mod #9 - All Aluminum Performance Radiator
Mod #10 - Expanded Steel Mesh Grill
05beast is offline
post #8 of 16 (permalink) Old 04-07-2012, 11:58 AM
Shane06fl's Avatar
Originally Posted by bestatchess View Post
Obviously that A-hole has an ax to grind with Nissan. (first video) That is the first one where I seen than arm get broke.
2005 Titan KC SE ***Sold 9/6/14***
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
2013 Chevy Silverado LT Z71 CC short bed
5.3L LC9 engine
Heavy duty tow package/cooling
4wd
loaded to the gills
mirrors sucks (for now)
2004 Keystone 24RS
Shane06fl is offline
post #9 of 16 (permalink) Old 04-07-2012, 12:02 PM
Shane06fl's Avatar
Video Here: 2005 Nissan Titan Cabin Noise - YouTube
How To: Fix annoying clicking heater/ac actuator under dash (w/pics)
The actuators move when the truck is shut off. With the truck on turn your controls to defrost then back to Max air. If you get the clicking it is the actuator in the above post. read the entire post and follow the links.
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
5.3L LC9 engine
4wd
loaded to the gills
2004 Keystone 24RS
The Following User Says Thank You to Shane06fl For This Useful Post:
post #10 of 16 (permalink) Old 04-07-2012, 12:30 PM Thread Starter
Catfish787's Avatar
Ok, this must be the problem because when I change it from defrost to max a/c it makes the clicking sound.
So, according to your instructions, I just get in there, remove, and replace it, right?
Also...that part is for 09-10 Titan, I have an 05, will it still work?
post #11 of 16 (permalink) Old 04-07-2012, 06:03 PM
iTrader Score: 6 reviews
I just completed my repair of the same actuator and had the exact problem you did. The part number you need is 27743-ZP00A. I have an 05 as well and be aware that if you have the rockford fosgate system, the amp mounting bracket is directly in the way. It is a pain to get to. Took me 2 hours but only cost me around $40!
shawn474 is offline
The Following User Says Thank You to shawn474 For This Useful Post:
post #12 of 16 (permalink) Old 04-07-2012, 07:51 PM
DRTYAZN's Avatar
iTrader Score: 12 reviews
My T makes the ten second ticking after merely turning my ignition on... It's coming from the center right side of the dash... My Climate and vent controls are still fully operational though... One of these days, I'll go hunting for the ticking gremlin under there...
DrtyAzn
Slightly Modified 4X4 '06 Titan CC
DRTYAZN is offline
post #13 of 16 (permalink) Old 04-07-2012, 08:41 PM Thread Starter
Catfish787's Avatar
I just got mine out. Holy #$&*!, that was hard as well to get out. With my big hands, it was not easy. I can't imagine how I'm going to get it back together though. Also, I do have the rockford fosgate system, so that didn't help. Anyways, I appreciate your input, as well as everyone who helped. Lets see if I can't get this back together.
P.S. I would assume this would cost probably $400 or more at the dealership for repair. After doing it myself though, I would probably just shell out the money, if your willing to spend it. The part is very hard to get to, at least on my year model. Everything is in the way and some parts cannot be removed that are in the way because they are welded to the frame. You need to have a good set of tools to get to it as well, so if you don't have those, your going to have to spend 50-100$ on those alone. Finally, it kills your back, being in a position that long. Luckily, I'm only 21, but I could never imagine my dad getting in their and fixing it himself without having serious back pain for weeks to come.
The Following User Says Thank You to Catfish787 For This Useful Post:
post #14 of 16 (permalink) Old 04-08-2012, 05:44 AM
Shane06fl's Avatar
The part Number I listed for my 2005. The entire job took about an hour and half I think. What got me was that I couldn't find anything wrong the old actuator so I wonder if the moving parts of the vent go out of whack and they went back together after I installed the new actuator.
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
5.3L LC9 engine
4wd
loaded to the gills
2004 Keystone 24RS
post #15 of 16 (permalink) Old 04-15-2012, 06:23 AM
I know that clicking well. Damn cheap *** actuators.
06 XE Lund shield, grillcraft, tow package, magnaflow
core2 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Strange noise.....help phugoid Titan Problems & Dealer Service 14 12-11-2009 06:42 PM
strange noise ak2030 Titan General Discussion 1 06-30-2008 05:40 PM
Drone noise in cabin zapad Titan General Discussion 9 09-08-2007 05:31 PM
Strange Noise? grizzowner Titan Problems & Dealer Service 3 07-17-2006 04:47 PM
Strange Noise smiley Titan Problems & Dealer Service 4 10-07-2005 10:40 AM
You may post new threads
You may post replies
