blown motor yeehawww - Nissan Titan Forum
Old 04-07-2012, 08:24 AM   #1 (permalink)
iTrader Score: 0 reviews
will any other mototrs bolt to my tranny ? 06 titan le?
titanman06 is offline   Reply With Quote
Advertisement
Old 04-07-2012, 08:34 AM   #2 (permalink)
4mula1fan's Avatar
iTrader Score: 2 reviews
Re: blown motor yeehawww
Yep, another 5.6 Titan engine will bolt right up.
TrainingWheelsWhore™
08 Pro4X
Click here for mods
My Pics
"You're short on ears, and long on mouth!"
John Wayne
R.I.P. Mickey
4mula1fan is offline   Reply With Quote
Old 04-07-2012, 09:54 AM   #3 (permalink)
nyc2005armada's Avatar
iTrader Score: 1 reviews
Sorry to hear that you blew your motor, but make you get the same type of motor, if it is flex fuel, make sure you get a flex fuel motor, and vice versa.
Performance mods: DT Long tube headers, hi-flow Magnaflow cats, Injen intake, 07 style exhaust pipes, 22 inch magnaflow muffler (12588) Cross drilled/slotted front rotors, Bilstein 5100 front shocks.
Exterior Mods: Stock LE rims, painted Nissan Galaxy black with Nismo center stickers, 5000k headlights and 6000k fogs
Interior mods: All red led instrument cluster, 12 in JL sub, 250W mono sub.
nyc2005armada is offline   Reply With Quote
Old 04-07-2012, 11:41 AM   #4 (permalink)
titantriper06's Avatar
How exactly does one blow a VK56? I ran NOS for 25 seconds and froze my solenoids open and dumped nos into my engine at idle for nearly a full bottle!!! still didnt blow it.
MODS- INJEN CAI, JBA Shorties, 2.5 to 3 in glasspac, Transgo, Level 10 trans upgrade, LP mod, Zex 125+ nitrous, snow performance stage 3 mpg MAX water meth, Detroit TRUTRAC, UPREV tuned
330RWHP
426TQ
Sig pic removed/size violation
titantriper06 is offline   Reply With Quote
The Following User Says Thank You to titantriper06 For This Useful Post:
gweasel77 (04-22-2012)
Old 04-11-2012, 06:25 PM   #5 (permalink)
jdubslopro's Avatar
From what I've read, you have to stick with 04-06 (if it's gas) or 05-06 (if it's Flex Fuel). I am curious to know what might be involved as far as retrofitting an 07+ motor into 04-06...what might be required as far as wiring/sensors is concerned.
jdubslopro is offline   Reply With Quote
Old 04-11-2012, 06:58 PM   #6 (permalink)
GalaxyTitan22's Avatar
Dare to be Diffrent. I have not heard of an engine swap on a Titan.
You could be the first! DO IT!
My guess is hydrolock killed ur engine. A lil too deep in the water maybe?
2010 Titan CC 4x4 Silver - 2" lift Front and Back, 20x9 HD Hoss on 295/60/20 Nitto Trail Grappler MT, Superchips Programmer
2006 Titan CC Black - SOLD
GalaxyTitan22 is offline   Reply With Quote
Old 04-11-2012, 07:18 PM   #7 (permalink)
beason's Avatar
iTrader Score: 9 reviews
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
oh oh!! LS swap!! do it! do it!!
Ever growing mod list here
WhinyWhore™
Originally Posted by The Urinator™
before flapping your feed trap use your think blob
beason is offline   Reply With Quote
The Following 2 Users Say Thank You to beason For This Useful Post:
OFELIPE (04-11-2012), rogarey27 (04-11-2012)
Old 04-11-2012, 07:22 PM   #8 (permalink)
OFELIPE's Avatar
iTrader Score: 3 reviews
Thers has been a custom cummins swap///
StarvinMarvinWhore™
~ UPREV Tuned ~ JBA Headers ~ Banks Exhaust ~ Volant CAI ~
~ DDM 6k HID's Lows and Fogs ~
~ 2 American Bass XFL 10's ~ Soundstream Rubicon 2500D Mono Block ~ 2/0g Wiring ~ 4g Grounding Kit ~ Custom FF Ported Box ~
~ SD_Titan 2in Seat Lift ~
~ Spring Tech Lowering Shackles ~ Blacked-Out Foose Spank 6 22's ~ 305/40/22 Nitto 420's ~
~ SD_Titan Headlight Mod ~ Grill Mod ~ JB LED Reverse Lights ~
OFELIPE is offline   Reply With Quote
The Following User Says Thank You to OFELIPE For This Useful Post:
Old 04-11-2012, 08:51 PM   #9 (permalink)
Yeah, that ^^^. If you can't get a 5.6 from a boneyard pretty cheap, might as well go the LS swap route. If you do, put a bowtie in the grill.
http://imageshack.us/photo/my-images/811/picture013vx.jpg/
2006 CC Titan XE 4x4
Mods so far: Bully Dog Power Pup Tuned, 2.5" Leveling Kit, airbox mod, Spec-D projector headlights, smoked altezza tail lights, soft tonneau, nerf bars, Plasti-Dipped bumpers and grille insert, bedlinered wheels.
Parts waiting for a home: Front window tint, custom exhaust, trailer hitch, some leftover bedliner I might throw on the...BED?
Stuff to do later? MXP, HID lows.
Evillseed is offline   Reply With Quote
Old 04-11-2012, 09:11 PM   #10 (permalink)
08pro4x2486's Avatar
I'm also curious as to how you blew your engine.
2008 Pro4x KC Smoke Best 1/4 mile 14.4739@93.61mph 2.0581 60ft in 2499DA. 354.8rwhp 418.1lb/ft on 87 octane tune (hub dyno)
Thrust: Airaid MXP 4" Intake, FT90mmFTW, Stillen (CSF) radiator, Stillen LT headers, Berk B-pipes, Nismo Catback, E-lock mod, Burn Out Mod, and Uprev.
Suspension:PRG UCA's, Ext. length SAWs, Swaybar removed, PRG camber bolt kit, Deaver C30, Radflo 2.0 remote reservoirs, PRG shackles, and N-Fab Traction Bars. Radflo air bumps waiting to be installed.
Exterior: Lots of DIY stuff, custom prerunner bumper w/4 Hella 500 HID's, 35X12.50 General Grabber AT2's, XD Diesel's powder coated flat black, VIAIR on board air compressor w/tank.
RIP TINA
08pro4x2486 is offline   Reply With Quote
Old 04-12-2012, 03:03 AM   #11 (permalink)
jdubslopro's Avatar
I'm in the same boat right now, my motor ran fine but kept blowing up radiators. Thought it was head gasket so I started to take the heads off-cracked block. Cheapest I've been seeing motors is $1600. Check car-part.com it checks salvage listings throughout the US.
Old 04-12-2012, 10:48 AM   #12 (permalink)
yes yes explain ...how did u blow ur engine...did it run hot from an blown out radiator. And wher is it crack, Block and head can be fix.
Mark Kline is offline   Reply With Quote
Old 04-13-2012, 08:39 AM   #13 (permalink)
jdubslopro's Avatar
The block isn't repairable, it's a hairline crack in the very front of the block under the right cylinder head. I have no idea how far the crack extends inside, but I'm fairly certain the heads are ok. I've never run the truck hot or dry. The first radiator had a small crack in the lower plastic section, so I replaced it. Two weeks later the new radiator exploded, covering everything in coolant. I figured it had to be head gasket, forcing compression into the water jacket, so I started to take the motor apart. Removed the timing cover and found the crack.
Old 04-16-2012, 05:13 PM   #14 (permalink)
Man that sucks,sorry to hear that. Kindy having save problem with my truck , dont know whats crack or broke yet . good luck and let us know wher u find a block or engine at.
Old 04-17-2012, 03:38 AM   #15 (permalink)
jdubslopro's Avatar
Actually I took the motor out and got the heads off, and upon closer inspection what I thought was a crack is actually just a casting mark from when they removed the block from the mold. So I got lucky there! But I still ended up picking up another motor for $1500. They're going for about $2000 everywhere I'm looking. One of the head gaskets just lost a seal between two cylinders, so it was forcing compression into the water jacket and into the radiator...I'm going to sell the complete motor for $1000, or put it all back together and sell it for $1500. I already have brand new head gaskets and intake manifold gasket set, because I was originally just going to do the head gaskets. If anyone's interested there's pics in my for sale post.
Advertisement
blown motor titanman06 Titan Engine, Transmission & Drivetrain 1 04-07-2012 09:47 AM
Where could one find a Titan with a blown motor? djruss335 Titan General Discussion 6 12-15-2011 05:30 PM
Is my diff blown, or near blown? StormTroopin Titan Problems & Dealer Service 14 10-26-2011 09:45 PM
blown away garwood War Stories 6 01-20-2006 12:26 PM
Blown Hemi motor at 6,200 miles! pluckyew Titan General Discussion 9 01-27-2004 05:22 PM
SEO by vBSEO 3.3.2
