Originally Posted by love1u0
The carpet is soaked
The water won't hurt the carpet much, but if you don't get the water out of it, and dry it out, you will have a mildew problem, and that stinks. You might want to get a wet/dry vac and pull out as much water as you can, so that if it does give you trouble, it appears that you made an effort to prevent it. If you have a secure place to park it with the windows down, that will certainly help...especially if you can park it in the sun, or blow some fans through.
Just some thoughts....But the leak should be fixed by the installer, and backed by the dealer...
Good luck
