Heater not working - Nissan Titan Forum
post #1 of 4 (permalink) Old 10-22-2012, 10:48 PM Thread Starter
deetsmx's Avatar
iTrader Score: 0 reviews
Heater not working
I've been looking through threads about all the heater problems and I'm stumped. I noticed on a recent trip that my heater was no longer blowing warm air. I don't know how long it's been this way since it's the first time in months I've had to use it. I've checked the control valve (the one by the battery that lets the coolant through) and it's working fine (I even took out the plastic piece and turned it by hand) and the outgoing hose is hot as well. I attempted a flush of the cooling system but I'm not sure if it was successful, I ran the truck for about 3 minutes with the radiator cap off. Earlier this year I also replaced the variable blower control motor (fan was stuck on high) and I also had another stereo installed this summer. I don't know if the heater was broken prior to either one of those events. Any ideas? Thanks in advance.
2006 2wd Crew Cab XE, 2.5" PRG Spacer, 315/70-17 Hankook Dynapro MT, 4" CST Spindle, 2" blocks in rear
deetsmx is offline
Advertisement
post #2 of 4 (permalink) Old 11-07-2012, 09:04 AM
Re: Heater not working
I had similar symptoms in my Armada, and inbound hose to valve was hot, outbound through bulkhead into passenger compartment was warmish and could be mistaken for hot unless you reach right into bulkhead to feel.
Went to use heat in the cooler months and no hot air, wasn't sure when it stopped working.
Turned out it was airlock somewhere in cooling system. There is probably a documented fix for clearing airlocks from Nissan if you can hunt it down.
To fix for myself, I opened overflow when cold, removed Rad cap, turned inside air controls to full hot, and ran truck.
Added water until overflow bottle was overflowing - in doing so, every now and then the fluid would surge out of main rad cap hole, I just kept going and squeezing top rad hose till overflow was full.
I then caped radiator and let it all come fully up to temp, continued to squeeze hose for a while and checked inside till it blew hot - whole thing took nearly 10 mins.
Once it was blowing hot, I carefully took Rad cap back off and reved gently a few times to expel fluid until overflow dropped back to fill level, sealed everything off with the caps and carefully hosed down all spilt fluid in engine bay.
It didn't take a huge amount of water, and I'm in FL - if you are up north you probably want to pay closer attention to antifreeze level or even top off with pure antifreeze ?
Hope this helps - I was looking at dash strip down and wasn't looking forward to it - Stealership indicated valve was likely the issue ($150 plus labor), but I didn't buy into that as I had previously removed the internal cog and turned manually to no avail, I'm sure they would have been stripping out the dash and printing the invoices for me for a while before they flushed and said they had found it - just my opinion, but they are not called stealership for nothing ;-)
Good Luck !
Lorak is offline
post #3 of 4 (permalink) Old 11-07-2012, 11:22 AM
is the vehicle warming up to normal operating temperature? is it blowing air from the vents and its just not warm? does the air coming from the vents get warmer when you hold the vehicle at a higher rpm for a minute or so?
Nissantech72 is offline
post #4 of 4 (permalink) Old 11-21-2012, 01:09 AM
silvertitan04's Avatar
I also had the same problem with my 04 titan se and I found a little crack on bottom of rad replaced the rad and it works fine now. Crack started out small enough to where I didn't notice a leak but got worse.
Sent from my iPhone using AutoGuide.com Free App
2004 Nissan Titan
-flowmaster super 10
-6 inch rough country lift
-bilstien 5100s
-full one piece billet upper and lower
-Volant CAI
-Custom Motor Cover
-5k hids head lights and fogs
-blue led bulbs for high beam (longshot lighting)
-more to come
silvertitan04 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Heater not working? w8tnonu22 Titan General Discussion 3 08-10-2012 12:07 AM
Heater not working like it used to after CAI install...HELP!! RadiantSilver Titan Problems & Dealer Service 24 12-30-2011 12:13 PM
Heater dial not working properly nucleargary Titan Problems & Dealer Service 2 03-29-2010 10:24 PM
Heater not working abrahamseven Titan Problems & Dealer Service 1 10-31-2008 12:05 PM
Heater stopped working. . .WTF?! SeanVree Titan Engine, Transmission & Drivetrain 3 11-07-2007 09:51 PM
You may post new threads
You may post replies
