Crank Sensor Po335 Problem- - Nissan Titan Forum
post #1 of 12 (permalink) Old 01-02-2013, 03:47 PM Thread Starter
iTrader Score: 0 reviews
Truck keeps throwing the po335 Code, ive replaced my crank sensor, checked my fly wheel and flex plate and its looks perfect, and have checked the wiring. Does any one else have any ideas to what this could be ? Also when you are at WOT the rpms seem to jump around yet the truck seems to pull smooth all the way through a shift. Any help or info will be apreciated!
Clay
Redtitan77474 is offline
Advertisement
post #2 of 12 (permalink) Old 01-02-2013, 03:54 PM
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: Crank Sensor Po335 Problem-
Make sure you get the correct part. There was a batch of camshaft sensor that got mis-labeled as crankshaft sensor.
This TSB has more info.
https://dl.dropbox.com/u/16959871/NTB08-088.pdf
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now
post #3 of 12 (permalink) Old 01-02-2013, 03:57 PM Thread Starter
i just got one from o rielly ? and ive swapped with a buddy of mine thats has a titan also. I forgot to add no matter if i clear the code on my BD it always comes back after driving a couple miles but when you go to WOT my SLIP light also comes on?
post #4 of 12 (permalink) Old 01-02-2013, 03:58 PM
If the sensor is good, some other cause
P0335 NISSAN - Crankshaft Position Sensor Circuit
Possible causes
- Faulty crankshaft position sensor
- Crankshaft position sensor harness is open or shorted
- Crankshaft position sensor circuit poor electrical connection
- Signal plate may be damage
- Starter motor may be faulty
- Starting system circuit
- Dead or weak battery
The Following User Says Thank You to baseballfanz For This Useful Post:
Redtitan77474 (01-02-2013)
post #5 of 12 (permalink) Old 01-02-2013, 04:08 PM Thread Starter
New battery and all wires look perfect all the way up to the ECM. Starter motor starts perfect and doesnt show any abnormal on the flywheel. I saw another guy on here had the EXACT some problem but never had an answer to what caused it or if it was fixed besides that he said everyone said the VKPRO fixed the p0335 code? Sooo idk im just tired of looking at the SES and SLIP light. Appreciate the help n knowledge tho.
post #6 of 12 (permalink) Old 01-02-2013, 04:15 PM
Found a few threads relating to this, unfortunately no one thread has a "magic" answer.
Slip light and Crank Shaft Pos Sensor Problem
Need help kinda quick with P0335! Have questions!
This one was solved with a new aftermarket sensor (but you got a new sensor so might not be your problems at all)
Read the friendly TSB's NISSAN!! P0335 OBDII code.
post #7 of 12 (permalink) Old 01-02-2013, 05:13 PM Thread Starter
The second one was the one I had read before and is identical to my issues. Guess its time to tear it apart and check all the wiring again. Thanks
post #8 of 12 (permalink) Old 01-02-2013, 07:22 PM
mrbubl's Avatar
Garage
iTrader Score: 10 reviews
If there is a crank POS sensor in the cam sensor position you will get EXACTLY what condition you have. NISSAN corp knows it, dealers don't and cannot read, just replace parts....
I would suggest a known good cam sensor and a known good crank sensor. If you set them side by side you are tested to know the difference.
mrbubl is offline
The Following User Says Thank You to mrbubl For This Useful Post:
post #9 of 12 (permalink) Old 01-02-2013, 08:52 PM Thread Starter
Yeah I'm on my second motor and the first thing I had to do with the new/usee motor was change out the cam Sensor with the one off the old motor and when I got to the crank sensor I realized they look the same just diffrent part # does that also work vice versa if there is a cam sensor in the crank sensor position? Cause it wouldnt be the first time the dumba** over the counter said he knew what I wanted n gave me the wrong part.
post #10 of 12 (permalink) Old 01-02-2013, 09:43 PM
Yes check your camshaft sensor to make sure it's actually a camshaft sensor. Might be a crankshaft sensor in there.lol
Sent from my 2005 Red Alert Titan via the Autoguide app on my ASUS Transformer.
post #11 of 12 (permalink) Old 01-02-2013, 09:53 PM Thread Starter
Do yall have the exact part # for each . The cam sensor should be right , but the crank idk all I did was tell the guy behind the counter what I needed lol
post #12 of 12 (permalink) Old 08-01-2013, 06:41 AM
eddie300's Avatar
Hey. .. clay did u ever slove your problem . With code po335. and what was the fix.
sent from my titan
eddie300 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Slip light and Crank Shaft Pos Sensor Problem SlyDawg Titan Engine, Transmission & Drivetrain 20 08-19-2013 03:50 PM
sensor problem LtownsFinest_Titan Titan Problems & Dealer Service 4 06-15-2012 06:02 PM
Help! ABS Sensor problem Deviantx Titan Wheels, Tires & Brakes 0 04-02-2011 10:26 PM
Crank Position Sensor LAFLOWERS04 Titan Problems & Dealer Service 10 12-15-2008 09:59 AM
what is: Crank Shaft Positioning Sensor? 56v8 Titan Problems & Dealer Service 4 10-31-2006 09:31 PM
You may post new threads
You may post replies
