Another Ticking Question - Nissan Titan Forum
Old 09-21-2004, 02:56 PM   #1 (permalink)
iTrader Score: 0 reviews
I started a new thread on this because I'm not sure if my ticking is the same as everyone elses (happens on acceleration or under load). I would describe it as sounding the same (metallic tick - passengerside dash) but it happens all the time from road vibrations.
I brought my truck in today to have the radio replaced and this looked at. I test drove it with what appeared to be a mechanic's assistant and he definitely heard the tick.
The service advisor just called to tell me the good news - they found the source of the tick - and the bad news - that the noise is a relay that is supposed to switch on and off and that the noise is normal. I told him to go drive to go drive it himself and tell me if he thinks it should be normal.
I guess my question is - does anyone else have the tick not under load or acceleration?
Thanks
Ticking Titan is offline   Reply With Quote
Advertisement
Old 09-22-2004, 12:11 PM   #2 (permalink)
SAENole's Avatar
Only when accelerating so far for me.
Copper LE CC 4X4
Off-Road & Big Tow Packages
Born 5/17/04
Severely wounded 12/4/04
SAENole is offline   Reply With Quote
Old 09-22-2004, 03:08 PM   #3 (permalink)
duffer18's Avatar
I have it both accelerating and over rough roads. The rough roads part occurs during braking, accelerating (worse then) and when at a constant speed.
If it truly is a relay. It sounds like it may have a week coil or spring to hold the contacts open or closed (read relay's normal postion while driving). If we knew the location we might be able to adjust the mount to lessen the noise or find a replacemnt with stronger springs/coil... Just my two cents and if you can get any extra info I would be willing to give things a try.
Smoke 04 Titan LE, Big Tow, Splash guards, Bed Extender, Leaf Spring Helpers, Hellwig Anti-Sway bar, Mobil 1, Xaino, Born on 04/26/2004
MB Quart front and back, Phoenix Gold R9.0.5, Custom iPod install
duffer18 is offline   Reply With Quote
Old 10-03-2004, 11:46 AM   #4 (permalink)
Mine does it too...
Almost sounds like a pencil or pen rolling around and hitting plactic/metal inside passenger-side dash. Kinda bothersome, but radio drowns out for now. Can definitely hear it when radio is off though. Would like to know if there's a fix.
coolbeans is offline   Reply With Quote
Old 10-03-2004, 02:52 PM   #5 (permalink)
iTrader Score: -1 reviews
Add me to the list. I took it in and they said it was bad gas..huh? To use prminum and lets see what happens. After a week, still ticking, I am taking it in later this week....
2004 Titan CC SE Silver
ben95m is offline   Reply With Quote
Old 10-03-2004, 04:21 PM   #6 (permalink)
After several trips to the dealership for this noise, it's still not fixed. The first time they didn't hear it, then I went with tech on a test drive and he heard it. After this, he found that a "heater valve that bolts to the cowl loose" and then removed and reseated the spark plugs to no avail. The dealership said they couldn't fix it and told me that before I picked it up from them and suggested that I call Nissan's customer care line, which seems to be my only alternative at this point. Has anyone else already done this and if so, what type of response did you receive from Nissan?
2005 Toyota Sequoia SR5 4X4
Traded:2004 Armada LE 4X4
Manufactured 10/2003
White w/ Sand Leather Interior
Sunroof Package
LE Upgrade Package
2nd Row Bench Seat
Factory Bug Deflector/ Mud Flaps
kc1711 is offline   Reply With Quote
Old 10-03-2004, 04:33 PM   #7 (permalink)
Truck41's Avatar
iTrader Score: 2 reviews
look at my thread on ticking culprit.
06 titan 4x2. LE. Granite.
zoomers exhaust tip.
factory chrome wheels.
hellwig swaybar.
carriage works grill.
armada spoiler.
trueflow intake
Goodyear eagle GTll
Truck41 is offline   Reply With Quote
Old 10-03-2004, 04:37 PM   #8 (permalink)
garo1's Avatar
I've got it too, please give us location info when you have it, maybe we can resolve it here.
2004 Nissan Titan King Cab SE 4WD
Born: 5/4/2004
Pearl White Ext - Gray/Blk Int
Popular Pkg. w/Bench
Off-Road Package w/E-Locker
Utility Bed Package
Factory Step Rails
Factory Hood Protector
Drop-In K&N
PRG Leveling Kit
garo1 is offline   Reply With Quote
Old 10-03-2004, 04:57 PM   #9 (permalink)
Truck41, I forgot to mention that I found the fuse puller loose too, a couple of months ago and taped it, but it wasn't the answer to my ticking problem. Thanks for the suggestion.
Sunroof Package
LE Upgrade Package
2nd Row Bench Seat
Advertisement
SEO by vBSEO 3.3.2
