Old 11-08-2004, 02:57 PM   #1 (permalink)
Problems...please help
I recently had a flat on my front passenger side wheel. I replaced with the spare and have fully checked on all four wheel and keep it at 38 psi. however, the system low tire pressure lite is still on. I talk to the service dept and they told me to drive around without the flat tire on my truck (since the computer is still sensing the flat) and see if it will turn off. but it doesnt.
So i called another dealer, they told me that it cost $55 dollars to reset the system. they also told me that the computer needs to sense that all 4 tires are in the orignal position.
so i were to rotate the tires, or purchase a new set of tires, i will need to pay $55 for them to reset the system since the wheel are not in the orginal position. is this true?
Have any one of you rotated the tires and you have no problems with the stupid low pressure tire light? or can i just reset the system myself?
BIGGERSTUFF is offline   Reply With Quote
Old 11-08-2004, 03:02 PM   #2 (permalink)
vector6's Avatar
that sounds like BS to me..
try un hooking the battery overnight...
2006 jeep RUBICON so long titan...
No News with Combat Crews
vector6 is offline   Reply With Quote
Old 11-08-2004, 03:12 PM   #3 (permalink)
VShortt's Avatar
That is total B/S. Read my post in the link below. This exact same thing happened to me and the post explains how I fixed it.
Tire monitor display
New List of Mods Coming soon
Old 11-08-2004, 03:18 PM   #4 (permalink)
smoothTitan's Avatar
i had a flat on the right rear, put the spare on and it still said i had a flat. if you notice the spare doesnt have the metal valve stem that detects air pressure, i went and got my spare tire put back on the wheel that had the flat, then took the flat tire plugged the hole and put it on the spare wheel. it started working after that.
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
Old 11-10-2004, 09:35 AM   #5 (permalink)
My low tire pressure warning light has come on the past two mornings in temps near freezing. After driving for a while the tires warm up and the warning disappears. The system does seem to track psi pretty well. I watched each tire pressure gradually increase. Keepin' my fingers crossed that the system keeps working like this.
2004 Titan LE 4X4 Crew Cab, Galaxy Black, Power Sunroof, Side Air Bags, Big Tow Package, Nav/DVD System, ARE LS-II Lid, SIRIUS Radio w/SIGMA in-cabin antenna
New Transmission, Power Steering Rack, Nav CD Player @ 3k miles
Brake Judder Repaired @ 8k miles & 13k miles
VaTitanOwner is offline   Reply With Quote
Old 11-10-2004, 11:10 AM   #6 (permalink)
Your tires don't have to be in the original position. I have have rotated my tires twice with no problems. I did have the low pressure light come on once. That was because I had low pressure in one of the tires. I put more air in and the light turned off within a mile or less.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Old 11-10-2004, 12:36 PM   #7 (permalink)
TNT TITAN's Avatar
[quote=BIGGERSTUFF]I recently had a flat on my front passenger side wheel. I replaced with the spare and have fully checked on all four wheel and keep it at 38 psi. however, the system low tire pressure lite is still on. I talk to the service dept and they told me to drive around without the flat tire on my truck (since the computer is still sensing the flat) and see if it will turn off. but it doesnt.
Have any one of you rotated the tires and you have no problems with the stupid low pressure tire light? or can i just reset the system myself?[/QUOTE
Maybe just BS, what happened to me is the same that happened to you, as long as the tire with the air sensor is used as a spare tire (not on ground revolving like the other three) the light will stay on, when I put back the original tire and rim the light went off in about 20 miles or so. The tire tech said it works in conjunction with your radio????????????
TITAN SE 4X2 CC: OFF ROAD PACKAGE, TOW PACKAGE,ROCKFORD FOSGATE,MAGNAFLOW DUAL EXHAUST, AIR BOX MOD WITH K&N DROP IN, PRERUNNERS LEVELING KIT, AIRRAID THROTTLE BODY SPACER
TNT TITAN is offline   Reply With Quote
Old 11-10-2004, 12:46 PM   #8 (permalink)
IMADOGMAN's Avatar
According to the Service Manual, the sensors work above 20 mph, therefore, they have to be rotating to scan the sensor code into the receiver. So, if the sensor is on the spare, it won't work. I just rotated my tires, and I don't have any problems with the warning light. I don't have the nav system.
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 11-10-2004, 03:31 PM   #9 (permalink)
keiffers's Avatar
Send a message via MSN to keiffers Send a message via Yahoo to keiffers
mine did that last week to me - was on for a day or two, and I monitored the psi - when I saw it on, it had gotten down to around 40 (yeah COLD for central texas LOL) and the psi on all 4 tires was around 25psi. Anyway, was on for 2 days and chimed only 2 seperate times (1st when it originally detected and 2nd two mornings later). It was going to go in for service the following monday so I left it alone for them to do, since it was a safe assumption they'd do a tire check. Well as luck had it, the sensor turned off on Saturday. Guess it was the temperature affecting it and driving around, cause psi was back up around normal a few days later.
Keith
2004 Titan SE KC 4x2 - Smoke
"Chester"
SE Popular w/bench
SE Utility Bed Package
Drop-In K&N Air Filter
Delphi Roady 2 XM Radio
Sylvania SilverStars
Nissan wind/bug deflector
Nissan fog light kit
(good riddance Goodyear!!)
Born On Date - 03/19/04
Adopted On Date - 06/28/04
Maxwell Town North Nissan - Austin, TX
keiffers is offline   Reply With Quote
