Old 12-08-2004, 08:10 AM   #1 (permalink)
Rocket67's Avatar
Temp gauge moving with tachometer
I noticed a couple of mornings ago that my temp gauge is moving with my tachometer especially when the engine is cold. When I start the motor it goes a bit over mid-way. When I accelerate it pegs at the hot side and when the engine shifts it goes down with engine RPM. Once the engine heats up a bit it doesn't do it as bad but will still do it. If I put the truck in neutral it does the exact same thing. It sounds like the circuit board on the back of the gauge panel has a short but I don't know for sure and would hate to have that pulled out and replaced with only 300 miles on the truck.
-Scott
Rocket67 is offline   Reply With Quote
Old 12-08-2004, 08:25 AM   #2 (permalink)
Sammy Sandbag's Avatar
Que? You sure you aren't looking at your engine oil pressure gauge? If not, then I'd say you definately have a problem.
-Counsel Yourself
Old 12-08-2004, 09:04 AM   #3 (permalink)
Rocket67's Avatar
Oil pressure gauge? Uhhhh.....let me get back to you on that one.
-Scott
Old 12-08-2004, 10:07 AM   #4 (permalink)
MikeDeuce's Avatar
Yeah it does sound like the oil pressure guage. Are you looking at the dial on the bottom of the right side of the cluster? Water temp is the one on top.
Oil pressure and engine idle are higher at startup/cold motor. And revving your motor will increase oil pressure.
WHITE '05 4x4 CC BIG TOW
MikeDeuce is offline   Reply With Quote
Old 12-08-2004, 10:15 AM   #5 (permalink)
Huey130's Avatar
Send a message via AIM to Huey130
Oil pressure gauge goes from L to H (low to high) while the temp gauges go from C to H (cold to hot).
(o o)=(o o)=(o o)=(o o)=(o o)=(o o)=(o o)=(o o)
Craig "Huey" Stewart
Just some guy with a wrench
(who also used to have a funnier signature )
Huey130 is offline   Reply With Quote
Old 12-08-2004, 10:52 AM   #6 (permalink)
Rocket67's Avatar
Thanks for your input and I can now consider myself a flipping idiot. Yeah, it was the L--H gauge on the bottom. I forgot this thing had an oil pressure gauge in it.
Oh well, looks like I need to be
But I will settle for a after work!!
-Scott
Old 12-08-2004, 11:07 AM   #7 (permalink)
Huey130's Avatar
I was gonna make a post earlier about reading some of the other Titan boards and how "ours" seems to be more real world and not so full of "where do i put my blinker fluid" type questions.
Way to blow the curve Scott!!!
J/K!! Hahahahaha
Old 12-08-2004, 11:27 AM   #8 (permalink)
Rocket67's Avatar
J/K!! Hahahahaha
...and I am not from OU or USC either. he he he, yeah I saw that post.
-Scott
