Right Rear Rattle, still in 05's - Nissan Titan Forum
Old 01-02-2005, 11:48 AM   #1 (permalink)
iTrader Score: 0 reviews
Thumbs up Right Rear Rattle, still in 05's
More like a tapping, or single tick, on rough road. Had the interior trim off to run my XM antenna to the rear. Found a screw lying loose under the right rear step plate(have no idea where the screw should go). Didn't find anything else, except the seatbelt tensiouner makes a rattle if tapped. Put things back together. Rattle still there, no change.
So, I've seen the posts regarding the body to frame mount in the right rear. I took out the bolt in the back right corner. There was a pop when I loosened it, like some stress or pre-tension in the mounting. I lubed the big washer, where it contacts the bushing, and the bolt. Checked 3 other mounting bolts. None of them had the pre-tension pop. Also, the washer on the other 3 weren’t warn near as much. Lubed and re-locktited all 4. That was it, rattle is gone!!!
Much thanks to the person who found this fix. Based on the sound I was hearing, I would have never thought to lube the body mount bolts. I was also surprised this is still an issue with the 05's. But, hey it's fixed. I’m Happy.
As a side note. In addition to the extra screw, I also have missing fasteners to the back carpet, and a missing screw on the inner fender (right rear). Undercoating on the right side isn’t so even either. I think the right side line workers need a vacation, or at least start pumping some oxygen through their ventilation system
Great Forum
05' CrewCab Smoke -- All Stock (for now)
04' Ducati Multistrada
03' Honda CBR 954
02' Honda VTX 1800c
JohnC is offline   Reply With Quote
Advertisement
Old 01-02-2005, 07:13 PM   #2 (permalink)
TruckNitz's Avatar
You would have thought at least one Nissan engineer would have read this thread by now. C'mon ya lazy mofo's!!!
2004 CC LE BT OR, DeepH20
TruckNitz is offline   Reply With Quote
Old 01-02-2005, 07:15 PM   #3 (permalink)
Are you talking about the cab mounting bolts or the Bed?
Thanks for the heads up, I have not noticed a rattle on my 05 yet but it's only got 400mi on it so far, I'll check ALL the bolts anyway.
Turbodog is offline   Reply With Quote
Old 01-02-2005, 07:27 PM   #4 (permalink)
garo1's Avatar
I hate to say this, because I own one, but Nissan's quality sucks. There's no reason these same problems should be lingering for the '05's.
2004 Nissan Titan King Cab SE 4WD
Born: 5/4/2004
Pearl White Ext - Gray/Blk Int
Popular Pkg. w/Bench
Off-Road Package w/E-Locker
Utility Bed Package
Factory Step Rails
Factory Hood Protector
Drop-In K&N
PRG Leveling Kit
garo1 is offline   Reply With Quote
Old 01-02-2005, 07:55 PM   #5 (permalink)
Banned
jhromy's Avatar
I dont have that rattle...the only rattle in my 04 is in the drivers door other than that my Titan is quiet...man i love this truck
jhromy is offline   Reply With Quote
Old 01-02-2005, 09:51 PM   #6 (permalink)
I have a rattle that seems to be emanating from my front passenger dash speaker. I'm due for an oil change so I'll have them look at it when I take it in.
MercedTitan is offline   Reply With Quote
Old 01-03-2005, 05:25 AM   #7 (permalink)
Cab mounting. I pulled/lubed 3 on the passenger side, and the back left corner, but from the feel/sound I think the Right Rear is the only one that needed the stress releif.
Like I said before, I would have never thought to look there if it wasn't for reading about it on this forum. It would have driven me nuts over time, not because it was that loud or annoying. It wasn't. It's because I wouldn't have found it
03' Honda CBR 954
02' Honda VTX 1800c
Old 01-03-2005, 09:20 AM   #8 (permalink)
casique's Avatar
iTrader Score: 1 reviews
Talking
I have no rattles either!
2004 Radiant Silver Titan CC LE 4X4, DVD/NAV, big tow, no-offroad, Volant, tinted windows, utili-bed extender, Retrax Bed Cover, Zoomer Exhaust, Westin Bull Bar w/PIAA driving lights, Silverstars hi/low/fog, bug guard, Nissan Aluminum Diff Cover, smoke chrome grill cover and sun roof visor.
casique is offline   Reply With Quote
Old 01-03-2005, 11:52 AM   #9 (permalink)
TallTexan's Avatar
I had a rattle comming from the radio area. I pulled the panel off and found the 2 big wiring harness that left the panel went into the dash with no support. I put a couple of cable ties on them and shabang, no rattle.
Robert Louis Stevenson
Old 01-06-2005, 08:56 AM   #10 (permalink)
John, thanks. I have a LE/CC with I think the same rattle. Since I'm challenged, would you please be more discriptive on exactly where the right rear bolt is located.
thanks Mark
bouak is offline   Reply With Quote
Old 01-06-2005, 09:21 AM   #11 (permalink)
logicjunky's Avatar
Send a message via AIM to logicjunky
I like your enthusiasm and understand the frustration but I think a rattle is probably about last on the list given the brake issue and other operative issues that have arisen with any vehicle not just our Titans. I think as the other things get worked out they will get to knocking out all of the rattles, clanks, clunks, tinks, thunks, ticks and knocks...
~Radiant Silver K/C 4x4 SE~
~Big Tow, Off-Road Pkg, Utility Bed~
~Born 08/04~
~Adopted 09/04~
-I don't have the answers, I'm just a guy who likes to think and share his ideas...
logicjunky is offline   Reply With Quote
Old 01-06-2005, 12:30 PM   #12 (permalink)
Send a message via ICQ to Brons2 Send a message via AIM to Brons2 Send a message via MSN to Brons2 Send a message via Yahoo to Brons2
thanks Mark
I concur with this poster.
Also, what color Loctite did you use?
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
Brons2 is offline   Reply With Quote
Old 01-06-2005, 01:51 PM   #13 (permalink)
jdm
Lay on the ground and slide under your truck, basically under the jack. There will be a bracket with one large bolt and 2 smaller bolts next to it. The large one is the culprit and it is 17mm. It must be loosened & retightened to make the noise go away. You will need 1/2" drive ratchet and maybe a cheaterpipe.
jdm is offline   Reply With Quote
Old 01-06-2005, 01:54 PM   #14 (permalink)
MemTitan's Avatar
I've had my '05 XE for 4 days and I think I may have the same problem. How is this prevalent with so many of these? Is it a manufacturing robot calibration problem?
MemTitan is offline   Reply With Quote
Old 01-06-2005, 07:23 PM   #15 (permalink)
Banned
jhromy's Avatar
after i said i didn't have this rattle...I now do...i guess i should've knocked on wood tomorrow after work im gonna crawl under there and check things out...hopefully ill get it loosened and retighten it...is it hard to loosen this sucka?
Advertisement
SEO by vBSEO 3.3.2
