Just a quick comparison between my Xterra's repair history with my Titan's repair history.
A side note, while my service guys are expecting a new permanent brake fix for the judder, they really don't know what to expect as for what the TSB will call for and when it be available. The service guys were speculating that it would call for larger rotors and calipers, but they can't verify. They recommended for me to have the brake judder corrected under the current TSB until the new TSB is out. I guess they are really seeing this brake judder problem now. They said most of the problems are on the Armadas.
Here's my comparison.
2000 Xterra SE 4X4 (First model year)
1) Roof wind deflector rubbing on paint. Rubber lip was wearing groove into paint. Fixed by using 3M tape following TSB. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
2) Bumper needed adjustment. Left side was not level with right side. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
3) Hatch door was leaking, hatch area was flooded. Took a couple times to fix correctly. This was a headache and I wasn’t happy.
4) Rear back of seat bent and carpet came detached. Plastic pins broke and metal badly bent from moderately light cargo. Seat back was replaced. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
5) Steering stops need lubrication constantly. Had to lube every other oil change to keep stops from popping at a full turn. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
6) Rear seat latches rattle badly. Play in latch made truck sound as if a can was being thrown around. This was a major headache as the rattle was a loud metallic thrashing. This was a bad design as if you folded down rear seats a lot, the thin plastic latch cover wore and allowed a lot of play. After numerous repairs with no correction, wrapping the latch heavily with cloth electrical tape finally took up play between striker and latch. Finally FIXED!
7) Replaced front hubs. ~ 50K Rare hub cracks. Had to repair immediately, no problem, no headache.
8) Front Brakes replaced at 30K & 65K. Rear brakes never needed replacing. Replaced front brakes when they were thin. Fixed during Oil change service call. No headache in fixing. Repair was simple and quick.
9) Had constant brake judder starting around 10K. It was very minor and mirrored my exact brake judder problem in the Titan. Brake judder always returned after each brake job after 6K miles.
10) Various squeaks and rattles that were repaired several times, most were stopped, but some others weren’t cured while new ones came. Not really a rattle trap, but not dead quiet either.
*EDIT* ADDED 11) Fan Switch went out at 68,000 miles. Never fixed, traded it in with the problem.
2004 Titan XE 4X4 with preferred package and OR package (First model year)
1) Radio replaced following TSB. Problem started when brand new. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
2) Rear sliding window resealed. No leak problem but stripping was distorted, started when brand new. Was repaired only out of concern. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
3) Window switches replaced following TSB. Auto up confusion problem started when brand new. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
4) Rear headrest replaced. Problem started when brand new, on back order for 6 months! No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
5) Brake rotors turned because of judder that started @ 7.5K .Temporary fix following current TSB until new brake TSB is established. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
6) Differential fluid changed to Synthetic following TSB. No problem, but changed at 7.5K due to Nissan recommendation to use sythetic. No headache in fixing. Repair was simple and quick. Fixed during Oil change service call.
7) NO RATTLES, NO REPAIRS. Truck is dead quiet.
For both the Xterra and the Titan, all oil changes and repairs were done while dealership provided me with a very nice FREE loaner car.
These are my 2 most reliable vehicles I've ever owned. I've had many, MANY more problems in fewer miles than the Titan with my Plymouth Duster, Dodge Neon, and Chevy Camaro. The repairs on the Nissans have usually been done quickly and correctly the first time. The number of problems I've had on either is far less than with the American name plates. Of course, I'm picky so I want my car as perfect as possible. This requires me to nit-pik everything.
Have a good one.
