LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 05-10-2005, 06:20 PM   #31 (permalink)
Banned
Squid's Avatar
Just wanted some of the new members to see this.
Squid is offline   Reply With Quote
Old 05-14-2005, 02:01 PM   #32 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Question Tailgate problems...........
Hey Squid......how about solutions for tailgate problems???????
Tailgate hitting bed
Not sure how to pick through it though!!!!!!!!
Peace-TomFixed Tailgates
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac, Mag-Hytek Honeypot, HK Rear Axle Vent Mod.
ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-3rd set, Nitrogen in tires, Frozen Rotors/Hawk Pads, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
JFK http://www.youtube.com/watch?v=J8dLHZ6jKFc
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
Old 06-22-2005, 06:33 AM   #33 (permalink)
Clancy's Avatar
Originally Posted by Squid
This an attempt to consolidate all the known solutions to problems in one place. If you know of, or run across a thread not listed on this first post let me know and I'll edit this post accordingly with the link to the thread. This should after a while help out not only the new owners/members but also the long time members with bad memories.
REMEMBER KEYWORD, Solutions.
Audio.
1.)Aftermarket Stereo Installation Knowledge Base.
(Suggested by Bestatchess, Contributed by Boucoup Audio Gurus )
Installing Aftermarket Radio Tonight...
2.) Audio Install with Pics.
(Contibuted by M95roadster)
Audio Install...the beginning w/Pics
3.) Bezel/faceplate and door panel removal.
(Contributed by Bestatchess Post #4)
Stereo installation
4.) Low Audio level through Aux Input Solution.
(Contributed by Sammy Sandbag)
Hardwired MP3 Player
5.) Airhorn for the Titan.
(Contributed by Juma post #6)
http://www.titantalk.com/forums/show...361#post329361
Brakes.
1.) Brake Recall Info. Warrenty extension document for 04/05 brakes.
(Contributed By Slurppie)
Brake Recall Info
2.) Stillen aftermarket Big Brake Kit.
(Contributed by gr8titan )
They're here: Stillen Big Brakes
Cab
1.) Microfilter replacement/Installation (Great How To, for trucks with no filter from the factory. All trucks do have the filter Box)
( Contributed by VW1972bugs post #21)
Microfilter- King Cab
2.) Check Engine Light, toolless code retrieval.
(Contributed by Titanparts1 post #16)
Service Engine Soon Light
3.) Low Tire Pressure Warning System FAQ.
(Contributed by Austin Post#14 and others.)
Low Tire Pressure Indicator
4.) Popping sound when closing the door.
(Contributed by HavockWK and Friends. Post #4 of this thread.)
5.) Windows creaking in the up position.
(Suggested/Solution by ctuck13 post # 12 of TITANTALK link, Solution by adjmcloon Post #6 and #10 of CLUBARMADA link)
drivers side faint rattle
http://www.clubarmada.com/showthread.php?t=465
6.) Air bag sensor light reset procedure.
(Suggested by Sammy Sandbag, Solution by smoketitan)
Dash Air Bag Sensor Reset
7.) Keyfob ID setup
(Suggested by BLwedge09)
http://www.titantalk.com/forums/atta...achmentid=9665
Differentials .
1.) Photos of 05 aluminum rear diff cover install/Info.
(Contributed by gr8titan)
Photos of 05 aluminum diff cover install
2.) Low differential fluid discovery.
(Contributed by JETTECH)
Everyone PLEASE READ!!!
3.) Checking/Draining the Front Differential.
(Contributed by BigJoe Titan, Post #32)
Differential lube check screw-locktite??
4.) Checking/draining the rear Differential.
(Contributed by Bestatchess Post 2# and #4)
Rear Diff fluid question...HELP!!
5.) Differential drain plug torque/sealant.
(Contributed by Bayou Titan Post #2 and Bestatchess Post#3)
Checking Rear Differential
6.) Rear Differential fluid change Pictures.
(Contributed by Admorris)
Rear diff. fluid change pics
7.) E-Lock locked in 2WD, 4HI & 4LO Modification
( Contributed by Austin)
Electrical
1.) Optima battery and grounding upgrade.
(Contributed by 1BADTITAN)
Pic of my Optima Battery and Grounding Set
2.) Wire colors and purpose
(Contributed by Wareagle)
http://www.titantalk.com/forums/show...272#post328272
3.) Wiring 101 for dummies.
(Contributed by Bestatchess and Juma)
Hard Wire Help
Engine.
1.) How to:ECU Reset,Throttle & Accelerator Position Learning
(Contributed by ROCKYMTNTITAN)
http://www.titantalk.com/forums/show...027#post316027
2.)Nissan Titan V8 engine development SAE white paper.(VK56DE INFO)
(Contributed by ARMADA)
http://www.titantalk.com/forums/atta...tid=9430&stc=1
3.) Oil Analysis.
(Contributed by JetTech)
Titan loves Mobil 1 0W-40
4.) Oil Pressure Fluctuation as seen on the gauge.
(Contributed by BLWEDGE09, Post#2)
Oil pressure guage
5.) Air Conditioning Drain Tube Extension.
(Suggested by Cajunguy, Contributed by Vshortt, Instructions by 37L1 Post #60 and Friends)
Another Water Problem
6.) Blackstone labs (oil Analysis) $20,00
http://www.blackstone-labs.com/
Free Kit form.
http://www.blackstone-labs.com/free_test_kit.html
Exterior Safety Items
1.) Windshield wiper skipping/replacement blades
(Contributed by everyone in the following threads.)
wipers squeaking and skipping
windshield wipers
Noisy Windshield Wipers
2.) Removal/ Installation of Big Tow Mirrors
(Contributed by BigRedTitan)
Big Tow mirror problem
3.) Oily film on windshield removal.
(Contributed by all involved)
Oily film on windshield.
4.) Changing wheels/Tire rotation/Lug nut Torque.
(Suggested by Wrenrj1)
http://www.titantalk.com/forums/atta...achmentid=9666
5.) Spare tire remote air up/check Mod.
(Contributed by RDfeatherstone)
Valve Extension Hose?
Lighting
1.) Replacment procedure for Headlights/turn signals/parking/sidemarker.
(Contributed by RRUMANER Post #9)
Bulb Size
2.) Headlight Adjustment.
(Contributed by Stitch)
Check Your Aim
3.) Solution for inadvertant shutting off of headlights.
(Contributed by honeykeeper, solution by carpentry1@optonline)
Cure for accidentally turning off lights 63¢!
4.) Solution for Intermittent dash/enviromental control knobs lighting.
(Suggested by Fluxcubby, solution by me post#3)
Electrical Gremlins
Service.
1.) Service Department Advice.
(Contributed by Wrenrj1 )
Dealing with Dealer Service Depts.
2.) Downloadable Service Manual FAQ.
(Suggested by Bestatchess, Contributed By Many.)
Downloadable Service Manual Question
3.) Nissan Free Downloadable Owners Manual(Contributed by me)
http://www.nissan-techinfo.com/nissa...id=&dept_id=30
4.) TSB Website
(Contributed by me.)
http://www.nissanhelp.com/Bulletins/Model.htm
5.) TSB's (in .PDF format)
(Contributed by Z23Fan)
Suspension
1.) Axle Wrap. (Explanation and Solution)
http://www.titantalk.com/forums/show...6&postcount=31
2.) Squeaky Suspension.
(Contributed by Mike H Post #18)
Squeaky suspension
Ticks/Rattles/Bumps
1.) Fix for tick on passenger side area.
(Contributed by arkman0, Post#7)
Fix for tick on passenger side area?
2.) Bump sound from bed when slowing to a stop.
(Suggested by Optimist, Member who first found solution unknown)
THings that go bump in the night......(problem)
Tansmission
1.) Transmission fluid change.
(Contributed by Juma)
sunday transmission fluid change - the easy juma way
Towing
1.) Towing FAQ.
http://www.titantalk.com/forums/show...061#post279061
2.) Trailer light relay P/N and Installation.
(Contributed by KYdeepwater and Pagerdaddy)
Trailer Wiring
3.) 4X4 drop hitch drop length discussion.
4X4 drop hitch "drop" length????
This is a worthwhile and very valuable post - if it's not already, it should be a sticky! (Opps - I see it is. Nevermind!)
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
Clancy is offline   Reply With Quote
Old 06-24-2006, 06:11 AM   #34 (permalink)
blkbelt65's Avatar
Re: Solutions to Known Problems.
Squid. #5 under audio is a dead link. Also the axle wrap by jettech doesn't show the pics....
'06 4x4 LE Titan CrewCab - Radiant Silver.
MODS .... Inifnity QX56 Wheels~ MagnaFlow Custom Exhaust~ Tinted Front windows~ Vent visors~ Bug deflector~ Chrome Nerf Bars~ 4x4 Decals~ Under seat storage unit~ Volant GEN. 3 CAI~ AVT Competition Pedals~ Stubby 9" Flame Etched Antenna~ SS Bull Bar~ Square BullBar Fogs~ Stebl Air Horn~
"Ping shi duo chu han, zhan shi shao liu xue".
Beating a Dodge is like banging a fat chick - Everyone can do it but who wants to brag about it?
blkbelt65 is offline   Reply With Quote
Old 06-28-2006, 07:03 PM   #35 (permalink)
mjw357's Avatar
Rear KC door latch sticks
OK for you King Cab owners, you know how the little latch that prevents the rear door from opening while the front door is closed, sticks? And you have to fiddle with the handle a couple of times to get it to open? Mine was doing that, here's what I found.
Inside the mechanism is a small spring that is supposed to flip that lever out when the front door is opened, allowing the rear door to then be opened. There was a light coat of rust on the spring on the drivers side of mine. A couple of drops of light oil got it working smoothly. I did the pass. side just to be thorough.
Just remove the two philips head screws and carefully pull that whole latch assembly out of the door. It has a soft, gummy rubber seal on the back of it that will make it seem like it's not coming off, some careful prying will get it started and it will come off without damaging anything.
Note that you should use some kind of oil (a drop of motor oil will work fine) that will not wash away easily with water, and not something like WD-40 that evaporates and really doesn't leave any lubricating qualities after it's dry.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 09-25-2006, 12:48 PM   #36 (permalink)
ucf_motorcycle's Avatar
How about something on how to fix the rear axle seals? Mine is leaking and its out of warranty. I know that most of you have the luxury of getting free repairs at the dealership but I'll do most anything I can before I spend several hundred dollars to pay a dealer to fix a seal.
ucf_motorcycle is offline   Reply With Quote
Old 11-27-2006, 05:57 PM   #37 (permalink)
Leprechaun's Avatar
Just got my truck a few weeks ago, 07 titan cc le. Everything's worked fine with it so far until I was walking out to my truck this evening and the keyless entry fob thing didn't work. I tried to manually reset it using that procedure on the front page, but I don't see the hazard thing flash at all to tell me it's in registration mode.
Anyone had this situation before?
Leprechaun is offline   Reply With Quote
Old 01-07-2007, 08:28 PM   #38 (permalink)
Cmando4Life's Avatar
Send a message via AIM to Cmando4Life
the rubber sills around my window seem to be a little bit off. so for one when i drive it sounds like my driver door is a little open and sometimes it might leak some water every now and then. The warranty should take care of that right?
Cmando4Life is offline   Reply With Quote
Old 01-07-2007, 08:32 PM   #39 (permalink)
37L1's Avatar
Yes they will. I had that problem with mine the first week I owned it and took it back. They had to order a new seal and replaced with no further problems all under warranty.
2004 Titan Smoke LE CC
Born 11/18/03
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
Old 06-20-2007, 03:15 PM   #40 (permalink)
has anyone had a problem with the heat sheild on the front down pipes.
HoodTitan is offline   Reply With Quote
Old 10-05-2007, 05:56 PM   #41 (permalink)
04 titan wont start acts like it wants to but never stays running, somebody help
emibri21@yahoo.com is offline   Reply With Quote
Old 10-05-2007, 08:12 PM   #42 (permalink)
Quartz's Avatar
Best thread ever!!! Many thanks Squid.
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Old 10-05-2007, 08:26 PM   #43 (permalink)
aldaman's Avatar
Thanks for the info...You made searching for solutions very convenient
'04 Titan Crew Cab 4x4-Off Road Package / Big Tow
Add-Ons:
-2.5" Leveling Kit
-Husky Floor liners
-Drop in K&N Air Filter
-JBA Cat Back exhaust
-7" Head Rest DVD Monitors
-BFG KM2s (305/65/17) Tires
"My old Ride"
aldaman is offline   Reply With Quote
Old 10-13-2007, 09:09 AM   #44 (permalink)
$partacus's Avatar
Leprechaun,
I have an '07 cc xe 4x4 and since I bought it used, the key fobs have never worked. I've also tried the reprogramming trick with no luck. I took it to the Ford dealership where I bought the truck and they tried the trick as well to no avail. They told me to take it to their Nissan dealership, but they want to keep the truck overnight to look it over. Does anyone have a solution for this?
$partacus is offline   Reply With Quote
Old 01-25-2009, 09:57 PM   #45 (permalink)
Rear Sonar problem. I did a write up on a 20 min fix for under $5 here:
Rear Sonar - Fix yourself in 20mins for $5.00 !!
good work with the know problems page!!
WiskiRedz is offline   Reply With Quote
