hey guys, i have a question. when you guys drive down the highway, does your bed have alot of play? i was on the highway the other day and notice my bed in my mirrors really bouncing. is it normal? or should i have the dealer take a look at it? or should i tighten the bed bolts myself?
05' Nissan Titan SE CC 4x2
SE Popular Captains Package
Rockford Fosgate
NISMO CAI
JBA Catback Exhaust
DR Coilovers / PRG 1" Rear Lift Block
285/65/18 Nitto TerraGrapplers
305+HP and 379+lbs per ft of BALLS
Nope... no play. I really hope you have no play and no loose bolts. I would take it to the dealer and have them take a look at at since you may have a loose welded nut on your ladder frame. Cause as far as I know... the bed is bolted directly onto the ladder frame where nuts are welded into the frame.
2005 SE 4X2
- SE Popular w/ Captain Chair
- Big Tow
- Utility Bed
- Traction
MODs:
- Aries Black Nerf Bars CarDomain Site
Dude,
Guess I need a trip to the dealer to, mine does the same thing. The bed shaking is especially bad on dirt roards.
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
PC traction bars & lift
BFG 315/70/17 T/A KO's
PC Extream Alloy 1089 stealth black, 17-9 wheels
[/img]
-[/img]
It's better to have it and not need it, Than need it and not have it!"
you know, to be honest, i'm not going to worry about until the bed literally blows away. my buddy has a dodge quad cab and his does the same thing. i should steal my co-worker's bed bolts off his 2005 f-150.
Rockford Fosgate
NISMO CAI
JBA Catback Exhaust
My bed is also "seems" loose at high speeds. However considering that it's a totally seperate entity from the cab, I'm not suprised at all that it seems to move over ruts. From what I've seen, all pickups do this. I think most of these people who say theirs doesn't either haven't looked for it in the rear view or drive on ridiculously smooth roads!
-Cyrus
yeah when i'm on smooth roads, don't notice it. i only notice it when i'm on bounce highways.
Rockford Fosgate
NISMO CAI
JBA Catback Exhaust
It's frame flex and cab 'float'. The cab is rubber mounted and sits as a basically rigid unit on the frame, the bed is solidly bolted to the frame. The flex occurs relatively evenly along the frame but the only place we can see it is the crack between bed and cab. This is because we don’t perceive the slight flexing of the bed/aft section of the frame and the cab rides as [almost] a separate unit floating on the front section of the frame. Sounds bad but it's fine and if they eliminated it completely our trucks would weigh too much, be too slow and use too much gas. In truth our frames are amongst the stiffest in the 1/2ton segment.
If you go for a ride in a current, empty, 3/4 or 1 ton from Chevy or Dodge (the Ford chassis is very old and does flex a bit more than Chevy or Dodge) you'll see they do it to a much smaller degree. The frame of a one ton needs to be incredibly stiff in order to deal with the 4000+/-lbs payloads those trucks will handle in the bed. Our trucks don't have that kind of capacity and don't need that last bit of rigidity.
__________________ Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
my truck does the same thing.....05 CC may build. I was worried at first but then got a chance to drive behind one..........It did it too. I was worried because its very noticeable in the side mirrors. Dont sweat it.
