Aux Input noise on Rockford Fosgate
Attention Titan owners with Rockford Fosgate system with Aux:
Need your help. I had recently taken in my truck to the dealer due to noise when AUX mode is selected. They claim this is normal which I have to completely disagree as this just started to occur a couple of weeks back. Here's how to duplicate this test...mind you that it must be duplicated excalty as described.
-Turn up the volume (10 shoudl be good)
-Set the radio to AUX mode...(all speakers should be silent at this point)
-Now, turn on your headlights
-If the dimmer switch is set to MAX, you will not hear the noise
-Now dim the lights and you should immedialtl begin to hear noise as if there is some type of interference.
If you have this problem, please confirm as Nissan states this is normal
2005 Titan SE Crew Cab
Popular pkg w/ Rockford Fosgate - Captain Chair - Traction - Big Tow - Utility Bed pkgs
Performance Mods:
Banks exhaust - Injen Technology intake
Exterior Mods:
TREX 1pc billet upper grill w/ bumper insert - OEM yellow fog lights - H.I.D. 6000k low beams
Silverstars high beams
Suspension Mods: (PRG'd by Greg)
CST 4" spindle - Sway-A-Way Racerunner 2.5 coilovers - Total Chaos upper control arms
PRG Traction bars - CST carrier bearing kit - Deaver 2" mini leaf spring pack
Bilstein 5125 12" shocks - 2" blocks
Tires:
OEM wheels w/ 35/12.50R18 Kumho Road Venture MT KL71
OEM Mods:
Hood deflector - Steps - Rubber mats
