Go Back   Nissan Titan Forums > Titan Discussion > Titan Problems & Dealer Service
User Name
Password
New Campain For All Nissan Trucks - being discussed at Nissan Titan Forums in the Titan Problems & Dealer Service section.
Old 09-24-2005, 12:04 PM   #1
SKINTAG
Its For All Nissan Trucks For Years 2004-2005. Has Do With Replacing The Bcm And/or Sub Harness. (for Trailer Wiring)
Has Anyone Heard Of It Yet?
SKINTAG is offline   Reply With Quote
Old 09-24-2005, 12:38 PM   #2
scr38
scr38's Avatar
Look at it here:
http://www.nissanhelp.com/Ownership/.../NTB05-086.htm
Old 09-24-2005, 01:36 PM   #3
HighlandTitan
Just tested mine and it is ok per the instructions - anybody find theirs is bad?
2005 SE Crew Cab
Aftermarket Tow
Prodigy Brake Control
HighlandTitan is offline   Reply With Quote
Old 09-24-2005, 02:48 PM   #4
SKINTAG
I Think You Will Still Need To Replace The Sub-harness? Right??
Old 09-24-2005, 09:05 PM   #5
milleniamarv
milleniamarv's Avatar
03/04 Build with BT & 7 pin connector, checks OK with no voltage at pin 2 & 5, key on.
KC LE 4X4 Built 03/04, Sedona, Big Tow, XM Radio, Remote start, Billet grille, Advance bed cover, Chrome tailgate cover, '05 finned diff. cover, Armada air dam
Utah Highway 12
http://www.byways.org/browse/byways/2020/
milleniamarv is offline   Reply With Quote
Old 09-24-2005, 09:16 PM   #6
rdfeatherstone
Thanks for the heads-up.
Ralph Featherstone
'05 Titan SE KC 4X2
rdfeatherstone is offline   Reply With Quote
Old 09-28-2005, 02:27 PM   #7
ptgarcia
ptgarcia's Avatar
Anybody have this done yet?
Pauly
Old 09-28-2005, 03:13 PM   #8
rjspitz
rjspitz's Avatar
Checked mine and no problems. But, according to the recall, the subharness still needs to be installed.
The subharness seems to be a couple of relays for each of the signal lights. Does anyone know?
Old 09-28-2005, 06:13 PM   #9
BigRedTitan
BigRedTitan's Avatar
Mine checks out OK too. It sounds like it may have relays for each turn signal and the brake lights. It also mentions connecting the fuse end to the BCM. So, I figure that if there is a short in the wiring on the trailer, it may kick the fuse so that you don't have a fire situation. Sounds logical to me.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin Street Pilot C530 GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1" Rear Blocks, LED's Front, Eagle Eyes LED Tails,
2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
Old 09-28-2005, 06:54 PM   #10
rjspitz
rjspitz's Avatar
That's what I figured. Problem with me is, I've spliced into the turns signals at the BCM, and don't want the dealer to see it and tell me my warranty is void. Do you think the dealer will just give me the subharness?
Old 09-28-2005, 07:10 PM   #11
milleniamarv
Had the truck in to dealership today to replace rear axle seal and they also replaced this subharness due to recall bulletin. Per my previous post, the voltages at the 7 pin connector checked several days previous were correct.
rjspitz, concerning your concern about your modifications, might hit the dealer up about not being able to leave truck for them to replace subharness and after you personally replace it, will give them the original to prove that the recall was performed. Good luck.
Old 09-28-2005, 07:15 PM   #12
rjspitz
rjspitz's Avatar
Oh, so it's a replacement. I thought it was an additional harness between the main harness and BCM. thnx for the tip, I'll try it.
Old 09-29-2005, 08:50 AM   #13
StumpZ
Mine is there right now for the recall. He said it will take 4 hours??!
Born on date 5/04
2004 SE Crew Cab
Off-Road w/E-locker
56,650 miles - Out of warranty and scared to death!
StumpZ is offline   Reply With Quote
Old 09-29-2005, 10:12 AM   #14
IQ9
It looks like it is is only a 2 hour job based on the paperwork supplied by Nissanhelp.com. I added the factory hitch after we bought the truck so I will need to call and see what they tell me.....Here's wishing they do it.
Crew Cab,Pearl White,LE,Venture Clear Bra, Debadged, PML Dif Cover, 285/60/18 Nitto Terra Grapplers & Stillen BBK
IQ9 is offline   Reply With Quote
Old 09-29-2005, 10:18 AM   #15
StumpZ
I have a feeling my truck is the first one they have done at this dealership.
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
