Old 10-07-2005, 09:31 AM   #1 (permalink)
Strange Noise
I have a noise that sounds like a vibrating fan that has started on my 05 CC 4x4 OR and BT. I have heard it a couple of times at low speed (parking lot). It sounds like it is coming from the area behind the radio. Whenever I heard the noise I turned the radio off, the a/c off and still heard the noise. I got out and raised the hood, but couldn't hear it outside. The noise is intermittent and I cannot reproduce it. I am not a mechanic, but I have only had the truck a month or so and want to get it taken care of. I do not drive it daily due to company car. I have noticed it after idling or driving slowly through the woods, but again it;s not very often. Any ideas?
smiley is offline   Reply With Quote
Old 10-07-2005, 09:40 AM   #2 (permalink)
hmmm...
Are you hearing a slight tick, maybe?
If so, there's a couple different possiblities. One is the purge Control Valve, which i had done to my truck months ago-solved the probelm.
The other, if you're hearing a tick under throttle, and it sounds almost like its coming from inside the dash, it could be the grounding issue. I don't know if its still and issue on the 05's or not.
Both of these items, if its either, have been well documented on this site. Do a search using "engine ticking" and see what you get.
If it's not a tick, then forget everything I just typed!
2004 Chevy RCSB 5.3/4.10/Auto/Wheately Tune/True Trac/ Intake/Exhaust /e-fans/ 2" Drop Shackles out Back and Titan Rims all around!
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD**SOLD
SOLD **2005 Titan XE KC w/ Preferred Package BLACK **SOLD
buzzkillwill is offline   Reply With Quote
Old 10-07-2005, 09:49 AM   #3 (permalink)
It's really not a tick, it's a continuous sound. I thought at first it may have been the auxillary fan up front, but I checked that first. I hate to bring it to the dealer without being able to reproduce the problem. I haven't dealt with the local dealer yet. I have a friend who owns a dealership dealing in Lexus and exotics order the truck from a friend with a Nissan dealership in Georgia.
Old 10-07-2005, 11:39 AM   #4 (permalink)
HVACman's Avatar
What he said ^. My aux fan was missing the top screws and the bottom ones were loose. It was causing a weird vibration untill I got it secured.
Titan CC LE 4x4 Radiant Silver * Born 4/16/04 * Big Tow / Offroad Package * Kenwood DVD/NAV ent. system * Infinity 6000cs Component Speakers * Infinity 7540A Power Amp * SPL Sub Power Amp * 2 10" PowerBass Subs * Tsunami 1-Farad Capacitor * JBA Ceramic Coated Headers * Flowmaster 40 Series Catback System * Sirius Satelite Radio * K&N 77 Series FIPK Intake System * Airaid Throttle Body Spacer * Really Loud Air Horns * Weld Racing Cheyenne Rims * Carbon fiber dash kit * Black billet grille * Truxedo Tonneau Cover * CST 7" Lift * ProComp XTerrain 35/12.5/17 Tires * Procomp Traction Bars * Stainless Steel Brake Lines
Wherever you go, there you are
HVACman is offline   Reply With Quote
Old 10-07-2005, 11:40 AM   #5 (permalink)
goboilers's Avatar
Got the same exact problem. I pulled the aux fan off and wrap electrical tape around the prongs on the bottom of the fan to make it more secure. The fan is now tight but I still have the hum/buzz coming from the engine compartment. Drives me nuts.
goboilers is offline   Reply With Quote
