LinkBack Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 11-21-2007, 12:37 PM   #616 (permalink)
JerZTiTaN's Avatar
Re: Survey-REAR END FAILURES ONLY
Just when I thought I was OK...
1)Year-2005
2)4X4
3)BT or OFFROAD PK-BOTH
4)The Locker?-YES
5)Miles at 1st failure- 31900
6)number of failures- 1 (so far, just got it back)
7)Have you ever towed? Yes
8)Max tow weight-best guess? 3000
9)Do you live in hilly area?Yes
10)Ever have the brake problem-yes
11)Do you have VDC- NO (Just Standard ABLS)
JerZTiTaN is offline   Reply With Quote
Old 11-28-2008, 05:47 AM   #617 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Exclamation Re: Survey-REAR END FAILURES ONLY
My Titan's differential failed way too early........the spider gears that is.
Thanks for the Survey and please "keep" up the good work.
1)Year- 2005
2)4X4 or 4x2 4x4
3)BT or OFFROAD PK-just yes,or no,or both. Both
4)The Locker?-Just yes or no Yes
5)Miles at 1st failure 69,960
6)number of failures 1
7)Have you ever towed?Yes or no Yes
8)Max tow weight-best guess? 4,000 lb.
9)Do you live in hilly area?Yes or no Yes
10)Ever have the brake problem-just yes or no. Yes
11)Do you have VDC-yes,or no No
Comment on Rear-End Failure:
Rear differential failed leaving a gas station at 10 MPH with no trailer disabling driver from having proper control of vehicle with intermittent drive/power-train capabilities and distracting popping/grinding sounds of failed components in rear differential.
Upon removing rear differential internal gears found both spider gears had numerous teeth broken off while all other internal gears looked "NORMAL".
Nissan1 (Case/File#6346683) and my local Dealer/Service Manager offered no warranty replacement help after it was requested.
Repair from Nissan was quoted at $3,604.67 for complete axle assembly replacement and only offers a 12,000 mile x 12 month warranty!
Vehicle had 69,960 miles at time of defect/malfunction.
Rear differential upgraded to a Detroit TrueTrac (Limited Slip Differential) at owners expense dut to lack of confidence in the NISSAN rear axle assembly/components and reported failure cases with minimum NISSAN cooperation!
This is a known defect that NISSAN should be responsible for on all Titans. Please help!
NHTSA defect/complaint form:
http://www-odi.nhtsa.dot.gov/ivoq/
My NHTSA complaint/case/file#10250037
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac, Mag-Hytek Honeypot, HK Rear Axle Vent Mod.
ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Ultra L B, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-3rd set, Nitrogen in tires, Frozen Rotors/Hawk Pads, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and 75-90 in Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
JFK http://www.youtube.com/watch?v=J8dLHZ6jKFc
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
Old 11-30-2008, 11:36 AM   #618 (permalink)
Here's the count today.
71 cases on 04's
70 cases on 05's
16 cases on 06's
2 cases on 07's
1 case on 08's
160 known cases/complaints about the failed NISSAN TITAN rear differential components with the NHTSA.
Please make a case/complaint known here and with the NHTSA about your failed rear differential if you have one:
IVOQ - File a Complaint
Old 12-14-2008, 05:46 PM   #619 (permalink)
Here's the list of parts I used with the TrueTrac installation:
For the True Trac installation:
1 Eaton Detroit True Trac: DET913A582
2 Timken Bearings: TIMJLM704649
2 Timken Races: TIMJLM704610
Timken is a manufacturer.
For the Axle Seals, Bearings, Races replacement:
NISSAN Part #'s:
2 Bearing - Rear Axle 40210-7S210
2 Spacer Axle Brg. 43070-7S200
2 Seal - Oil Rear A 43252-7S200
For the Pinion Bearings, Races, and Seal replacement:
NISSAN Part #'s:
1 Pinion Bearing:Inner HM803146
1 Pinion Bearing Inner Race: M88048
1 Pinion Bearing Outer: M88010
1 Pinion Bearing Outer Race: HM803110
1 Pinion Seal: 100712V
1 Pinion Crush Sleeve: 430707F200
Hope this might help anyone about to install the TrueTrac.
Old 10-25-2009, 05:52 PM   #620 (permalink)
Here is another for the 2006 list.
I purchased the truck new and have been anal in tacking care of it. oil changed once a month all services done. basically very well taken care of, babied even.
Anyway, was taking a trip this weekend, left friday, got about 50 miles out of town and suddenly.... lots of noise. rear pinion seal failed, diff locked up, and driveshaft is dragging on the ground. truck has 56k and some change, only other problem I've had was the rack and pinion steering assembly was replaced at 1200 miles (bad bushing install at factory or something) and thats it. its stock other than the nismo intake, unichip ecu mod, and flow master.
1)Year-2006
2)4X2
3)BT or OFFROAD PK- tow pkg
4)The Locker?-dont think so
5)Miles at 1st failure- 56451
8)Max tow weight-best guess? 2500
9)Do you live in hilly area? no
10)Ever have the brake problem-no
11)Do you have VDC- not sure what that is
skyhiaz is offline   Reply With Quote
Old 10-25-2009, 06:53 PM   #621 (permalink)
1)Year-2004
2)4x2
3)no
4)The Locker?-no
5)Miles at 1st failure 108,000
6)number of failures 1 that I know of, 2nd owner
8)Max tow weight-best guess? 1700 pounds
10)Ever have the brake problem- yes.
11)Do you have VDC- yes
Defects investigation number 10289749
TopCat is offline   Reply With Quote
Old 11-15-2009, 09:48 AM   #622 (permalink)
Titan410's Avatar
Stung me too:
1)Year- 2005
2)4X4 or 4x2- 4x4
3)BT or OFFROAD PK-just yes,or no,or both- Both
4)The Locker?-Just yes or no- Yes
5)Miles at 1st failure- 48,000
7)Have you ever towed?Yes or no- Yes
9)Do you live in hilly area?Yes or no- No
11)Do you have VDC-yes,or no- No
2005 LE Crew Cab, Red Brawn, DVD, Big Tow, Off-Road, Truxedo Lo-Pro
Titan410 is offline   Reply With Quote
