Hi all. I have searched all around and cannot find any issue like this here or elsewhere. First off, I have done the Ipdm check and everything checks fine (runs through all checks). I have done the gauge check routine with no help.
Here is the issue: when I get to 1/4 tank, my 2012 Titan acts like it is starving for gas. It stalls, hesitates from a dead start, etc. This AM it started doing this on the way to work. I know I have a 28 gal tank, and it only took 19.8 gals (I really filled it till it was certainly full). Once above 1/4 tank it runs drives fine.
What would make my truck, with 8 gallons of fuel in the tank, act like it was running on vapors???
The gauge is actually accurate. Is my fuel pump floating maybe? IDK I'm grasping at straws here. Please brainstorm. The truck is under warranty, but I am about to drive 1500 miles in a couple of days on a vacation...
No check engine light. No other symptoms.
