Differential experts-Explain"roll pin"4X4 article
I know we have some differential experts-knowledgable amateurs out there-maybe one-some of you would explain the differential failure that the 4x4 mag experienced.Make it detailed,but simple.I saw the picture,and it looks like the sheared pin was holding another pin in place.It isn't clear what sheared the sheared roll pin(I see a scooped out place that is scooped out to allow the pin to be driven in,but I don't see anything that would shear it off),and since the sheared roll pin didn't drop out,it isn't clear to me why it isn't still holding the "other pin-carrier pin".Did the sheared pin back out enough that it no longer is holding the 'carrier pin"??
Maybe you could start with some quick definitions-assume we know nothing about differentials other than they transmit power,and allow the outside wheel to not drag.Define pinion-ring-spider and trace the power transfer from the axle through these gears-like this-axle> etc.Thanks.Show us what sheared the roll pin,and what a loose "carrier pin" would hurt.
Would excess heat make the pin more likely to "back out"-make the hole it is driven into "expand"?This is about the only hard fact we have about a diff failure-hence the curiosity.
Big order-thanks.Charlie
