Originally Posted by MIKEY
is it normal for u joints to sling grease every where?
Which U-joint are you referring to? I had what looked like a U-joint slinging grease, when it was acutally a leak from inside the yoke at the pinion that made it's way into the rear U-joint, and then splattered diff oil all over the place.
