cracked exhaust manifold - Nissan Titan Forum
post #1 of 82 (permalink) Old 10-31-2005, 03:00 PM Thread Starter
iTrader Score: 1 reviews
Send a message via Yahoo to JASHELL1562
I have a cracked manifold on the right side , dealer said that they have seen 4-5 come back with this anyone else with this problem.
2004 CREW CAB 6"PRO COMP W/3" BODY
37'S ON 17 WELD CRUSHERS , K&N ,
NO EXHAUST YET
JASHELL1562 is offline
Advertisement
post #2 of 82 (permalink) Old 10-31-2005, 03:54 PM
iTrader Score: 0 reviews
Send a message via AIM to oktex88
Have any pics?
2004 Nissan Titan 2WD
oktex88 is offline
post #3 of 82 (permalink) Old 10-31-2005, 03:55 PM
TOK
TOK's Avatar
Hey, I haven't heard of this, but where was it cracked, how many miles on your truck, etc?
From what I've read about header installs, replacing the exhaust manifolds is a lot of work. Only car I ever broke an exhaust manifold on had a bad motor mount that let the motor move and hit either the frame or fenderwell. Probably not the case in your truck, but maybe worth checking out.
04 XE 4x4
1000 Pounds Of Crap In The Back Levelling Kit
TOK is offline
post #4 of 82 (permalink) Old 10-31-2005, 07:10 PM
RockyMtnTitan's Avatar
There have been a few Titans with cracked manifolds. Some owners that had the infamous "engine tick" were not able to fix the noise with a ground wire like most of us did. It ended up being a cracked manifold. Don't know if Nissan redesigned these or not.
I went through a set of manifolds on my '00 Tundra after only 15,000 miles. I put headers on before they cracked again.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
RockyMtnTitan is offline
post #5 of 82 (permalink) Old 11-01-2005, 09:07 AM
DeTitan's Avatar
Hi,
Can you share as many of the symptoms as possible. This way we can all be aware and listening.
Thanks
DeTitan
2005 Titan LE 4X4 Crew RadSilver
Side Air Bag/Curtain Pkg w/VDC!
MOD: Circular rotating blind spot mirror.
DD 12/30/04
DeTitan is offline
post #6 of 82 (permalink) Old 11-01-2005, 01:19 PM
Already had one replaced on mine. It sounds like I need another one because I have a terrible exhaust leak again.
Johnny Ray is offline
post #7 of 82 (permalink) Old 11-01-2005, 01:28 PM
Originally Posted by DeTitan
Hi,
Thanks
You'll usually hear a ticking sound that is usually louder when the motor is cold. Sometimes the ecu will throw out "lean" codes for the primary O2 sensor for the bank that's leaking.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Int/Ext Mods:
Factory Step Rails
17" OR Wheels
20% Window Tint
post #8 of 82 (permalink) Old 11-01-2005, 07:06 PM Thread Starter
noise
cant miss it ticks really bad , i cant see it but i can hear it , the stealer said they will replace it . no engine codes are showing . i will get a pic when they take it off the truck. thanks
NO EXHAUST YET
post #9 of 82 (permalink) Old 11-02-2005, 03:59 PM
Thats the Xterra blood in them. Almost all early xterras had their exhaust manfold crack. They also had the fuel spit back out the filler hole.
Gone2 is offline
post #10 of 82 (permalink) Old 11-04-2005, 11:37 AM
Where is the crack? How big is the crack?
oktex88 is offline
post #11 of 82 (permalink) Old 11-04-2005, 04:19 PM
TIsTAN's Avatar
iTrader Score: 3 reviews
ticking after you turn off the engine, same problem? just noticed it recently.
TIsTAN is offline
post #12 of 82 (permalink) Old 11-04-2005, 11:27 PM
I think my manifold maybe cracked as well. When you give it gas while in park you can hear a rattle at the peak rpm. My engine runs rough and will vibrate the whole truck after you let go of the gas. Also I can hear my truck whistle, even while idleing if I put my ear up to the grill. Also, the service engine light will flash for about a second when you give it gas! Anyone know the exact symtoms of a cracked one? ???????????????????????????????
Took it to the dealer and they said it's just the fuel injectors? I'm taking it to a muffler shop to get looked at, Free.
oktex88 is offline
post #13 of 82 (permalink) Old 11-05-2005, 10:07 PM
bump - Anyone know?
oktex88 is offline
post #14 of 82 (permalink) Old 11-11-2005, 07:48 AM
FLfinfan's Avatar
The older Frontiers had this problem as well. Nissan redesigned the new manifolds with more material where the cracks were happening.
2015 SL CC 4x4, power moon roof, max utility / tow package.
Past: 2004 SE CC 4x4
FLfinfan is offline
post #15 of 82 (permalink) Old 11-11-2005, 11:31 AM
Supporting Vendor
P's Titan's Avatar
iTrader Score: 4 reviews
I have alot of that to. Is this the same thing anyone ??
my mods list
USE DISCOUNT CODE FOLGER
FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
TequilaWhore™
P's Titan is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
You may post new threads
You may post replies
