Old 11-15-2005, 06:43 PM   #1 (permalink)
Auto start issue
I just got my auto start installed by the shop. The car some times cranks but will not start. Is gets pretty annoying!!! What could be a possible solution or problem? Please advise??? it is an autopage 516 unit...
SLOW_V is offline   Reply With Quote
Old 11-15-2005, 07:15 PM   #2 (permalink)
f00dstamps's Avatar
Send a message via AIM to f00dstamps Send a message via MSN to f00dstamps
Re: Auto start issue
if the car cranks but does not turn on, then the immobilizer bypass may not be seated around the ignition. it needs to see a key in order to start.
if you car sometimes cranks but never starts, you may need to have your tachometer "learned." this is how the remote start knows that your car is started. it senses the tachometer wire.
perhaps they did not wire up the 2nd starter wire.
perhaps there are loose wires. did they use T-taps or solder+electrical tape?
2005 CC Titan 4x4 Blizzard White *** SE Popular Package w/ Captain's *** Utility Bed Package w/ Bed Extender *** Offroad Package *** Big Tow Package *** Valentine 1 (hardwired) *** Clifford Matrix RSX 3.5 Alarm + Remote Start *** Amsoil Synthetic motor & gear oil *** 20% Sun-Guard *** Weathertech front floor liners *** Truxedo Lo Pro *** Husky rear floor liner *** HID 4300k Denso/Koito/Philips *** Vulite LED taillights *** Luminarc yellow foglight bulbs *** Scangauge II *** overhead racks w/ kayak attachment *** DR coilovers *** DR rear 4x4 shocks
WANTING TO SELL: bed extender adapter for tonneau covers (i.e. Truxedo)
f00dstamps is offline   Reply With Quote
Old 11-15-2005, 07:31 PM   #3 (permalink)
2 of 3 starts the truck will not start. If I try to start it with my keys the car would crank until I unlock the doors with the non oem remote. How can I do the tachometer learned method???
Old 11-15-2005, 08:03 PM   #4 (permalink)
f00dstamps's Avatar
that is odd. the car should start just fine with the key, regardless of the remote start addition.
i could not find any information about an Autopage 516. i am not familiar with Autopage remote starters.
if the truck does not start unless you unlock[disarm] the doors then i suspect that there is a starter kill involved that is turned off when the doors are unlocked. however, your truck should not crank if the starter kill is engaged.
you will have to look in the install manual to find out how to learn the tachometer.
if you had a shop install it, i suggest you take it back to them and have them do it correctly. you paid for it to work. if you do have them fix it, ask them what was wrong.
the truck IS cranking but not turning over?
Old 11-15-2005, 08:25 PM   #5 (permalink)
Sorry, it is the Autopage RS-615.... I just wanted to know some things about the Titan with auto start before I go back to the shop. Thanks for you help!
Old 11-15-2005, 08:34 PM   #6 (permalink)
f00dstamps's Avatar
it does have a starter disable which would prevent you from starting the car from inside if the door is locked. have the shop verify this.
i believe your car is not starting because of the tachometer or voltage sensing is not set correctly. have them verify this.
don't forget to get back on here and let us know what the problem was.
in the future, only work with DEI (Viper, Clifford) or Compustar products.
Old 11-16-2005, 10:45 AM   #7 (permalink)
Thanks man...! I got it fixed. It was pretty close to what you mentioned above. It was the transponder unit not send the signal strong enough. They relocate it closer to the ignition. Hopefully, this will solve it.
Old 11-16-2005, 11:37 AM   #8 (permalink)
f00dstamps's Avatar
great. just in time for the winter.
Old 11-16-2005, 11:59 AM   #9 (permalink)
lol!! It just snow here last night. My titan was acting goofy....I had to shut off the backup sensors because there was ice/snow build up on it...sending it off when reversed...The low tire pressure sensor lit up....my washer fluid nozzle squiter frozed up...What a morning!!!
Old 11-19-2005, 07:45 PM   #10 (permalink)
DStewart's Avatar
Welcome winter..........
SOLD:2004 Nissan Titan 4x4-Smoke, Big tow, SE bed package, Popular package w/ captains chairs.Mods: updated aluminum rear diff cover, K&N drop-in filter, PRG lift, Firestone air bag kit, 17x9 Eagle Alloy 101's, 295/70R17 Nitto Terra Grappler, polished Billet grille-upper 3 piece and lower.
2005-FS2600 Weekend Warrior toy hauler
05 Honda CBR 600RR Black/Gunmetal w/Tribal Flames
DStewart is offline   Reply With Quote
Old 11-29-2005, 08:51 AM   #11 (permalink)
I thought i got this fixed...but the problem starting to occurrrrr again. The shop contact the seller/AutoPage. They tell them that 04 and newer nissan's transponder is effectiving the unit and they are working on a fix for it? Anyone ever heard of this? And is there a solution that I can tell the shop??
any advice will help...
Old 11-29-2005, 09:04 AM   #12 (permalink)
f00dstamps's Avatar
the newer nissan's transponder is affecting what? the transponder bypass or the actual alarm/remote start unit?i have never had a problem with my DEI 556u transponder bypass sending the signal to the ignition... never. also, my clifford works flawlessly.
i'm not sure how the autopage transponder bypass looks like but they may have to adjust how the key sits inside.
maybe the remote start unit isn't triggering the transponder bypass to send the signal at the proper time needed. this may be due to loose wires. did they solder and tape it off with electrical tape or did they use t-taps? soldering makes a solid connection while t-taps break the wire provide a less than average connection.
Old 11-29-2005, 10:39 AM   #13 (permalink)
This is what the shop wrote to me:
"Sorry for any inconvience, I just got off the phone with Auto -page and they assured me that it has nothing to do with the unit but the problem that we're having has to do with your transpoder key. Right now they are in the process of developing a new transpoder unit to work with Nissans.
It's not just your car but most 04 and up Nissan's are having the same problems. Right now there's nothing I can do until they come out with a new system so it's up to you what you want to do. A) sit on what you got for now until they resolve it-which will be a few weeks or B) we can disconected for now.
Like I said I'm sorry for any inconvience but it's not the unit that is bad it's the transpoder that is causing the issue so there's nothing I can do right now but wait for their solution."
When looking under the dash. The wires seems to be tapped with a clip?..
Old 11-29-2005, 10:44 AM   #14 (permalink)
f00dstamps's Avatar
tell them that you know someone that has an 05 titan that uses the DEI 556u transponder bypass and never had a problem. tell them you want them to install that one instead. they should be able to use that in place of the faulty autopage bypass unit. i don't think it's your key... your key is the same as my key.
if wires are tapped with a clip... that is a bad install. they should have never invented t-taps.
Old 11-29-2005, 11:22 AM   #15 (permalink)
Can the the auto page unit work with this DEI bypass unit? And if the shop does not carry it. Where could I go buy one? Circuit City?? How much should I expect to pay?
I just email the shop about what you suggested about the differ bypass unit.
Hopefully they can do it for me??
When does 05 start?? SHIPREC13 Titan General Discussion 3 11-20-2004 02:19 PM
Is this a Horn Issue (First issue for a newbie) lsutyger Titan Problems & Dealer Service 14 10-04-2004 05:39 AM
OMG!!! It won't start AGAIN!!!! 40-Dan Titan Problems & Dealer Service 12 09-25-2004 04:46 PM
