Originally Posted by smokeum
I noticed today has it has some play in it. I was thinking back to a post where someone put some foam where the existing foam is at the windshield. I checked it again tonight once it got colder and found that if you move it (with the defrost vent off ) you can hear it pop when you move it. It will be seeing some more foam tomorrow in order to make it a more snug fit. You guys keep me posted and if I found something that works, I'll do the same. Thanks!
K&N Typhoon - Factory bug deflector - ATS fender flares
Flowmaster w/50 series & duals - New 4" SS turn down tips
Tinted windows - Silverstars (all 4) - Utility pkg - Off road pkg
Big tow pkg - Sorry excuse and waste of money of a RF pkg
you must have an 04 titan. mine did the same thing with the glove box.
Nissan is using bigger rubber stops now on the 05's so there is not so much play in the glove box door anymore. just thought that I would let you know.
The glove box on my 05 is sung and alot tighter fitting.
You can just pull the old one's off, and push in the new one's.
Deep.
