Hello guys. New to the forum. Once you drive the truck around a while and you open the door, you can hear a ticking/tapping sound. Sometimes it is loud and sometimes it is just noticeable. When you brarly get the truck off idle the ticking will increase with RPMs. I have got under it and can not trace it down to the exhaust but seems to be coming from the transmission area. Any ideas?
I had the tick before and the ground wire fixed it right up. Hard to get the bolt off but after that it was an easy fix. I was begining to think I was going to have to replace the hamster wheel bearings under the hood but the ground wire did the trick. http://www.ncbr.chemi.muni.cz/~evaf/...mster/car.jpeg
__________________ 2004 TITAN CC LE BIG TOW DVD...CLIFFORD REMOTE START OEM CHROME RIMS...Z GRILLE...ARIES SS STEP RAILS...CHROME TAILGATE TRIM RETRAX ROLL TOP COVER...XENON LOW/HIGH BEAMS POWER TAILGATE LOCK....TAILGATE ASSIST PIAA REVERSE FOG LIGHTS...UNDERSEAT STORAGE BIN SIRIUS SPORTSTER... 7'6" BOSS SNOW PLOW
No matter what I do I can't get that damn bolt off!! I sprayed it with WD40 and I've tryed from the hood and through the wheel well but there is a brakeline bracket or something in the way thru the wheel well.. after many hours that bolt is STILL on! Help!! I've been using a 14mm size. My wire has been sitting inside my console forever. Is there another bolt I can put the wire on?
__________________ 2004 Nissan Titan - Cash Settlement with Nissan for Water Leak March 2008
Make sure the wrench fits real good or you will do damage to it. So if you are using a cheap set go out and buy a good socket to fit of fuel line wrench works well to. You have to keep trying.
I've put so much muscle into it I think it is starting to strip, but the 14mm can still get a good grip on it. When I try to turn it I can't get it to budge. I'm trying this from under the hood. Maybe I can get some type of shop to do it? Maybe the dealer? lol they would prob charge $50.
tip...
I used a bit of WD40 let it soak then went to town, no prob.
__________________ 2004 - SE - 4x4 Off Road Package - White Exterior:“Wincher” front bumper with Ramsey 9500 / Synthetic Rope Winch*PIAA Off Road/Fog Lights in Bumper*ProComp 35” 325/65/18 Extreme AT Tire*ProComp 8089 Series Extreme Alloy Wheels*ProComp 6” Lift Kit w/ES Series Shocks*Unity Pillar Spotlights R&L*Dual Optima Battery System w/Painless Wiring Solenoid Kit*On Board Air Compressor with 10ga tank*Challenger Series Tool Box*Banks Exhaust*Unity Night Eyes Under Carriage Lights*Overhead Rack w/Yakima Mega Warrior Basket*PIAA Pencil Beams on (front rack)*PIAA Flood Lights (rear rack)*Stillen Big Brake Kit*LED Lighting
Interior:Pioneer AV1NC Navi/XM/DVD/Back-Up Camera*Yaesu UHF/VHF Radio*Cobra CB* Uniden 100 Scanner*2-Streamlight Stinger Flashlight Mounts*Aircraft Map Lights*Prestige Theft System w/Autostart & Satellite Tracking Service*Headliner 7” Slave Monitor*Wet Okole Seat Covers
Any garage with air tools would likely be able to handle it.
Yea if you can get a good fit with an impact, that should get it.
Alright guys, I put the extra cable in just like the pictures show. The ticking is still there. I do not hear the ticking around the manifold. It seems like it is coming from the transmission. Any ideas?
And the daily beatings will continue until morale improves.
Or until you figure out how to use their system against them.
04 LE 4X4 OR
05 and 06 Rear ends....
05 Bed, front seats, AC parts, brakes, window reg., .....
Tranny mounting bolts loose?
Body to frame bushing mounting bolts loose? (just rearward of right front tire)?
