Old 11-20-2005, 02:24 PM   #1 (permalink)
Survey-4x4's with brake and rear differential problems
If you don't mind,I would like to get a quick snapshot of the relationship between the brake problems and the read end problems in 4x4's.So maybe folks WHO HAVE HAD BOTH PROBLEMS WILL ANSWER THIS QUESTION
1) WAS IT- MAINLY FRONT BRAKES, MAINLY REAR BRAKES,I DON'T KNOW?
Just 4X4 folks with both rear end and brake problems.Just put FT RR I DON'T KNOW.
Just your best guess-which was the biggest failure-ft or rear.Thanks.Charlie
Old 11-21-2005, 10:23 PM   #2 (permalink)
Re: Survey-4x4's with brake and rear differential problems
1) FT
-Cyrus
Vyrus is offline   Reply With Quote
Old 11-22-2005, 12:14 AM   #3 (permalink)
Hawaiianbasshead's Avatar
I've never had the brake problem. Just had my rear replaced...
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 35x12.5 toyo MTs on 20x9" +18mm offset ultrawheels titan 6 black, ventshades, headlight covers, 5% tint all around and n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
Old 11-22-2005, 10:54 AM   #4 (permalink)
30th report -45 failures
Vyrus,thanks.I don't really have hig hopes that the failures are related to ABLS.
I saw our 30 report-flyguy-today.This means about 45 failures reported here.I have actually counted the failures,but we had 2 reporters with 5 each,and a couple more with 2,3 failures-45 is about right.Thanks.Charlie
Old 11-22-2005, 11:45 AM   #5 (permalink)
zachopp's Avatar
Front rotors were warped-Judder. Also the service dept. replaced the rear brake pads and resurfaced the rear rotors.
zachopp is offline   Reply With Quote
Survey-REAR END FAILURES ONLY PHOEBISIS Titan Problems & Dealer Service 620 10-25-2009 06:53 PM
rear differential update and its effect on the emergency brake?? smoketitan Titan General Discussion 1 06-02-2005 10:28 PM
Rear Differential BIGGERSTUFF Titan Engine, Transmission & Drivetrain 23 11-21-2004 05:15 PM
Rear Differential fix.......maybe CoachBoone Titan Problems & Dealer Service 5 07-30-2004 04:03 PM
rear differential Higgy1 Titan General Discussion 15 07-25-2004 07:57 PM
