Old 11-30-2005, 12:02 PM   #1 (permalink)
2005 rear differential failures-alloy cover?
Help-did you 2005 owners who had a rear diff failure have the alloy cover.There are about 10 of you-maybe you could chime in.
Here are your initials-names
PP
HBH
HS-a 2004 and a 2005
CASPER
RACERREX
YOMAMA
VYRUS
WYKEDTITAN
LENJ33
QUICKONE
It was suggested that all but one of these 2005's were very early 2005's that didn't have the alloy cover.That wasn't my impression,but maybe you could clear it up.My goof.Thanks.Charlie
Old 11-30-2005, 01:43 PM   #2 (permalink)
Burly's Avatar
Re: 2005 read differential failures-alloy cover?
Don't know if this helps at all, but my 2nd one that went out was an 05 with the new cover.
Had..
05 Titan SE 4x4
Color: Blizzard
Crew Cab
Have..
Burly is offline   Reply With Quote
Old 11-30-2005, 01:54 PM   #3 (permalink)
Mine was an 05, but it originally had the 04 cover, I bought the PML cover, mine didn't completely fail. If that helps.
Yomama -
2005 4x4 Canteen Crewcab SE with BT, OR, Utiltrak and Popular Package.
Ziebart rust proofing
A.R.E. Z series topper
Myron and Davis DVD for the kiddies, DDX7015 for me Kenwood amp and lightning amp on 8" polk sub. Audiovox remote starter (with satellite link)
Zoomers (No Drone) exhaust
AEM intake
Stillen Headers
2002 Hyundai Santa FE (The wifes)
2001 Polaris 700 Twin ATV
1996 28' Bayliner Cierra Sun
http://www.yomama.net
Yomama is offline   Reply With Quote
Old 11-30-2005, 02:04 PM   #4 (permalink)
My 4/05 production date Titan came with the newest (alloy) differential cover. They replaced it with the same thing.
-Cyrus
Vyrus is offline   Reply With Quote
Old 11-30-2005, 02:36 PM   #5 (permalink)
Thanks guys. Burly,I think I have you listed as the 3rd responder on the survey-I used BLY-kinda dumb,I should have just used the full "name".I show you as a 2004 4x4 OR ELOCK,2 failures,1st fail at 6000 miles,you didn't tow,and had 3 brake problems?Is that you?Thanks.Charlie
Burly-when did they replace your diff with the one that had the alloy cover?Thanks.Charlie
Old 11-30-2005, 04:32 PM   #6 (permalink)
Burly's Avatar
My 2004 had a build date of May of 04. The original diff went out around 9,700 miles and was replaced with a 05 upgraded version.
Had..
05 Titan SE 4x4
Color: Blizzard
Crew Cab
Have..
Old 11-30-2005, 08:44 PM   #7 (permalink)
Hawaiianbasshead's Avatar
I had the finned aluminum diff cover... and got another finned diff cover...
Old 11-30-2005, 08:47 PM   #8 (permalink)
What is the gear oil capacity of the OEM 2005 aluminum finned cover?
Old 12-01-2005, 02:29 AM   #9 (permalink)
sonnytimes's Avatar
My truck is an 04. The first rearend was an 04, The second was an 05 with the aluminum cover. The one that I currently have has the aluminum cover. I think it is coming apart also.
And the daily beatings will continue until morale improves.
Or until you figure out how to use their system against them.
04 LE 4X4 OR
05 and 06 Rear ends....
05 Bed, front seats, AC parts, brakes, window reg., .....
sonnytimes is offline   Reply With Quote
Old 12-01-2005, 03:09 AM   #10 (permalink)
lenj33's Avatar
Send a message via AIM to lenj33
I also had the finned aluminum cover.
'05 Loaded LE, off road, big tow, preferred package, utilitrack, overhead racks, captains chairs, DVD for my girls and Nav for my girlfriend
lenj33 is offline   Reply With Quote
Old 12-01-2005, 10:39 AM   #11 (permalink)
Thanks- Sonny-2 fails and another on the way?
Thanks guys-Hawaii-I had a hard time finding you untill I realized that you were HBH-really stupid of me to use initials,but I didn't expect 38 reports-I figured 15-20.
Sonny-I have you down as-2004-4x4-OR-ELOCK-2 failures,one at 6000 one at 8000 miles--yes you tow 3000 lbs-no hills-yes brake problems-no VDC.
Your second failure was with an alloy cover?
I'm not sure how to handle-record-replacement diffs with alloy covers.I'm guessing that there might be more to the 2005 "fix" than the alloy cover and syn-heavy lube.I hope that Nissan did "something" with the guts-better QC,better more expensive alloys whatever???No chance that Nissan will tell us, but if I were Nissan I would sure as heck do more than these bandaids.The engineers aren't stupid-they no that something is "off spec."Car differentials are ancient technology-nothing new there.If their calculations said that the D44(souped up) was enough, then failures meant that the D44 guts were defective,or they had a huge number of demented owners(buyers).
The engineers must have been working feverishly on a solution-I hope it is already installed.Thanks.Charlie
Old 12-04-2005, 12:47 AM   #12 (permalink)
LOL, demented buyers/owners... nope, just doesn't cut it. it broke before 4,000 rpms so I'm sure it didn't take 305 crank hp! nor did it get anywhere near the abuse my other cars did/do/and will take for a while more :P
Old 12-04-2005, 07:11 PM   #13 (permalink)
Yup, My first one was aluminum with the cooling fins and so is the new one.
Everything seems nice and tight now with the new rear end, seems to hook up a lot better.
QuickOne is offline   Reply With Quote
Old 12-06-2005, 08:31 AM   #14 (permalink)
Mine did not have the aluminum cover. It did not however completely fail either. Just making a really obnoxious sound at low rpm and when slowing to a stop....
The new one they are in the process of installing today has the aluminum finned cover...
Wyked
Wyked-Titan is offline   Reply With Quote
Blown Differential - New Cover cover up doctor steve Titan General Discussion 8 04-13-2005 09:59 PM
Differential cover?? Prlauren Titan Performance Modifications 4 02-06-2005 08:06 AM
rear differential 2005 WhiteMountainsTitan Titan Problems & Dealer Service 5 02-03-2005 08:55 PM
Attn: Advance K-Cover owners.....Please read Titan_TX Titan Parts & Accessories 4 01-23-2005 05:59 AM
Differential Cover thunderheart Titan Engine, Transmission & Drivetrain 0 09-21-2004 09:39 AM
