My sensor is lit and I check the tire pressure. They are all at 35psi and the light is still lit. What do I need to do to make the light shut off? Do I need to take it to the dealer for faulty sensor?
You could try two things. Just run it a little longer at 35psi, mine took about 20-25 miles before it went off or air all tires up to 40psi and run that pressure until light goes out then air back down to 35, light should stay off. If this doesn't work, dealer would be next stop.
KC LE 4X4 Built 03/04, Sedona, Big Tow, XM Radio, Remote start, Billet grille, Advance bed cover, Chrome tailgate cover, '05 finned diff. cover, Armada air dam
I have the same issue right now. The first day that we had a good chill, 27 degrees, and it came on and has not cleared. I checked the pressure and all tires are at 33psi. I'll try your suggestions above and see if it clears.
__________________ If I hear the lyrics to "Macarthur Park" one more time, I swear to God I'm gonna go postal!!!
mines different. I got new wheels and after they're on the light hasn't gone away. the position sits behind the wheel face instead of the front like normal wheels so I don't know if that makes a difference.
Make sure your pressure reading is when the tire is cold. Pump them to 35-36psi, and drive it for 5 miles. If the light is not off during this period of time, you need to pay a visit to your dealer to have them reflash or replace them.
-Cyrus
This is not Titan related but it's on the same issues. My fiance's Toyota 4-Runner had the low pressure light came on this morning (temp. dropped here last night). Anyway I stop by a shop and had them put air in all the tires, light still on. We checked all the tires and put in a little more air, light still on, me and him both say WTF. Another guy came by and said "spare tire", huh? Well we checked the spare tire and it was only 22 PSI, put air in the spare and the light went away. How the heck did the system know the spare was low on air? Not sure if our Titans work the same.
__________________ Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
You think the spare. The manual says that the truck does not pickup the spare?
I could be wrong. I will check tomorrow...
Same thing also happened to me today. Pulled in to the dealer since tires were cold. They put air in the tires and stated the light will turn off in about 15 miles. Sure enough it did. That alarm scared the heck out me!
2005 LE CC 4X2
Smoke
Tow Package
ARE LSII Bed Cap
Born: 10/25/04
Adopted: 11/06/04
Yeah I'm not sure about the Titan, it's just that was the situation with the 4-Runner so I though I would throw that out.
I looked under the truck at the spare. Too much work to get the spare off and tested. Plus it is fricken cold here. I wait till my apptment at the dealer tomorrow night.
By the way...should I take out my CAI and put back my factory airbox..I dont want the dealer to itch
I went to Family video to take back a video game and the tire pressure sensor came on also. It is about 0 degrees here. I check all four tires and they were all at 30 psi. Pulled into a local gas station and filled up to 37 psi on all tires. About 10 seconds after I pulled out of the gas station the light went out. At least this time the sensors worked right.
Travis
Had: 05 Nissan Titan Smoke 4x4 SE King Cab
Loved the Titan, NO PROBLEMS WITH HER.
Traded: 01/03/06 for 06 Mazda 6 Grand Sport.
Thanks for all of your time and knowledge Titan talk members. I'll still be around.
If these are new wheels they need to be reflashed by the dealer. They reset the sensors to match the unit. Done with a computer gizmo. I got a new set of wheels and they had to be shot with the computer before this issue cleared.
