Old 12-12-2005, 06:48 PM   #1 (permalink)
Brake Judder fix---not!!
2004 Titan has had brake judder problem since 3000 miles. Kept bringing it in every 2000 t0 3000 miles and they resurfaced rotors and changed pads, then in September they said they finally had the new kit to fix the problem. Installed new rotors and pads at 15000 miles. Just brought it back friday at 18000 miles---brake judder is back!! Seems this kit does not fix the problem absolutely. They turned the rotors again (the new ones) and said if it happens again they will replace the rotors again. So all you guys who think that Nissan has fixed this problem, they have not--- the rotors are just not heavy duty enough for the truck. Anyone know of good after market rotors for the Titan??
racer888 is offline   Reply With Quote
Old 12-12-2005, 06:51 PM   #2 (permalink)
Re: Brake Judder fix---not!!
I have Stillen OEM size cross-drilled rotors & metal matrix pads, O.K. for about 12,000 miles now. There are some big brake kits, but they need bigger wheels.
Old 12-13-2005, 08:55 AM   #3 (permalink)
IQ9
I have the same issue but others have said that I was lying and one called me and the folks with continuing brake issues MF'ers.He claimed to be a Nissan tech.
Crew Cab,Pearl White,LE,Venture Clear Bra, Debadged, PML Dif Cover, 285/60/18 Nitto Terra Grapplers & Stillen BBK
IQ9 is offline   Reply With Quote
Old 12-13-2005, 11:22 AM   #4 (permalink)
smoketitan's Avatar
lol yep, I swear I think Im turning into the forum bad mouther
but yep I have the new updatees,and mine have started to sqeauk here recently (which means that soon Ill be back to the shakes)
ill be going aftermarket as soon as they go bad
Old 12-13-2005, 02:09 PM   #5 (permalink)
I am getting ready to go pick mine up right now. they are squeeling and are not wearing evenly. (i have allready had the fix done).
Does everyone have a problem with the rotors not wearing evenly?
sbo76 is offline   Reply With Quote
Brake Judder TSB VShortt Titan General Discussion 26 04-20-2005 10:13 PM
Brake Judder??? fgb Titan General Discussion 5 04-01-2005 11:47 AM
Brake Judder Mike Up Titan Problems & Dealer Service 3 03-07-2005 05:39 PM
Brake Bedding a cure for Brake Judder? Squid Titan FAQ & Howto Area 24 02-13-2005 02:14 PM
Brake Judder TSB TITANTX Titan Wheels, Tires & Brakes 1 06-02-2004 10:50 AM
