Blew mine at 33K miles "spider gears" put in true-trac no more problems.
They said since mine was lifted not covered under warranty.
love the true-trac but hate the tire wear.
__________________ 05' Titan SE 4x4 Current Mods
AEM Intake
Flowmaster exhaust
True Trac
Self made traction bars
Go Rhino Dominator II steps
NCD Upper control arms
Custom rear SS brake lines
Air Ride air "assist" bage with custom in cab controls and gauges
CST 7" lift with 2 1/2" leveling kit stacked
Crow limiting straps up front.
3" body lift
Total Chaos rear shackles
KMC XD series Rockstars 20x10
Kumho 38x15.50x20
Dana 60 with 4:10 gears from WFO Concepts
I was shocked to have mine fail 2 months ago. I have the '04 cc 4x4, off road, big tow, never towed, I do not live in a hilly area but I have done a few long road trips, canada, verginia several to upper PA area (got to play paintball). I have had my breaks taken care of for the shudder problem. I do not beat on my truck, I just treat it like a truck should be treated. I always go to the dealer for all maintainence and they did not have a good reason for me why the rear failed. since I got mine so late in '04 it already had the heat sink finned cover. I love the truck and plan on keeping it till it dies (i hope many year from now) but with the premature failure of the rear (fixed under warrenty), i do not want to have to get that fixed again in another 42000 not under warrenty.
Your Confirmation number (ODI Number) is: 10212111
hope this does us some good.
Yoda
2004 LE CC Smoke
4x4
Big Tow
Off Raod
DVD Naviation
I have added my name to the NHSTA list now. I have an 06 2WD (non tow package) with 37000 miles and my rear axle seal is leaking. Nissan is replaceing under warranty. And yes, it will probably happend again...
I Just Added My Titan To The List. My Odi # Is 10213366. I Have A 2004 Cc Le, Big Tow, Off Road W/ Locker, No Vdc, Mileage At Discovery Of Spider Gear Being Broken Is 72,000. Out Of Warranty And Nissan Won't Do Anything To Help Me. I'm Currently Pricing Out 2 Options: 1. Replacing With A Truetrak. 2. Replacing With Oem Locking Unit With 4 Spider Gears. I Don't Have The Sticker Number On The Rear Diff Because The Sticker Is Gone.
White,
Forgot To Give You The Rest Of The Info.
4x4
Towed - Yes
Max - 3500 Lbs.
Live In Hilly Area - No
Brake Problem - 2 Times
Note: Stock Size Tires And Have Only Used The Locking Rear Diff Less Then 6 Times Total. I Dont Abuse The Truck And Only Tow A Quad Trailer Occasionally.
Add another 04 se 4X4 crew cab, 117,500 miles, tow the boat and Travel travel in the summer I live in a rather flat area of NC.
No mods done basic work truck that drives the whole state of NC.
Pretty disappointted with Nissan dealer but first real problem with truck jsut wish it was not as expensive to repair...
just bought an 05 Titan SE with 34000 miles on it. I had it two weeks and the rearend just went. The used car dealer I bought it from gave me a 3 month 3000 mile powertrain warranty but doesn't the truck have a 60000 mile powertrain from the factory?
Yes 5 yrs. or 60K, whichever occurs first.
2005 Nissan Titan KC SE 4X2 Tow package, popular package, drop in bedliner, running boards, 2* advance, 18" wheels, Rear sonar, adjustable pedals, 6-disc in dash CD, full frontal brush guard, heated mirrors, head mounted driver info center, auto adjust rear view mirror, home link system, Flowmaster Super 44 hidden dual exhaust, Cobra LTD 29 40 channel CB with dual antennas, tool box w/ black diamond plate
the truck is being towed to star nissan in greensburg pa to be repaired under the factory powertrain warranty. the tech told me it is a known problem and the issue is a vent becoming clogged and starving the diff of oil. BS . Tell me if I am wrong but the only way the starving would occur is if the oil leaked into the axles via a bad seal through the seal at the drive shaft end of the diff cover itself. The gears are partially summerged in oil wether its venting properly or not. Boy this chapps my***. Thanks for the speedy reply. Great truck otherwise.
hey guys first time posting,i guess im the one to blow the rear diff. after 60,000 miles. get ready cause its gonna cost you!! $3500!! thats just the estimate if there is a recall will i be covered? or even compensated for the parts?
oh my complaint #10224270
Get a TruTrac installed for a 1000 bucks. Will last.
the mechanic said that i have an electronic rear diff.,and if i put a cheap diff. in there, my console will light up like a christmas tree.-is he telling the truth?
No, the YruTrac will work fine. Search TruTrac on this forum and get all the info you need. Also , PM some of the ones who have had the TruTrac installed, they can help you. Good luck.
Re: Nissan Titan-NHSTA REPORTED FAILURES-of powertrain:driveline:rear differential un
Complaint Filed: ODI Number is: 10231682
I noticed oil leaking inside passenger rear wheel.
From the dealers service print out after service was completed:
Cause: F
NE15AA RPL BOTH AXLE SHAFTS/BEARINGS
857 WPN
2 43252-7S200 Seal-Oil R
2 40210-7S210 Bearing-RE
2 43070-7S200 Spacer Axl
1 43082-7S210 Cage Rear
1 999MP-AH000
