Old 04-03-2006, 09:43 AM   #1 (permalink)
Problem: weird slip when pulling out
Guys,
Do you have a slip in the drivetrain when first pulling out slowly, its like a shimmy or like the driveshaft turns before the rear end and tires do. Like a slip-yoke thing. Next time you pull out of a stop, see if you feel that studder or whatever you call it. almost like you tell the thing to go, it seems like it should move, but does not for a split second and then goes, it seems like its a shake off the line or something. hard to describe it!
Chris 04
04 sedona red SE. JWT intake, full mod stereo with 10" blaupunkt sub. Flowmaster exhaust, undercover plastic bed cover, Westin bullbar, hella lights.
BIGT56PA is offline   Reply With Quote
Old 04-03-2006, 09:51 AM   #2 (permalink)
troutking's Avatar
Location: Squarefield Ca. Make a right at the budwieser brewery and just past the Jelly Belly factory.
Re: Problem: weird slip when pulling out
Yup! I noticed that a couple of weeks ago. Almost like somthing is in the front of the bed and slides to the back and hits the tailgate. Or like a lash or slop in the drivetrain. See other posts about rear end failures. I'm keeping my fingers crossed. Good luck to you.
troutking is offline   Reply With Quote
Old 04-03-2006, 09:54 AM   #3 (permalink)
Mine does that a little, especially after coming to a quick stop. Seems that tranny needs a moment to catch up. Lately i've had a clunk. Like there is more than a little slop in drivetrain. Slow down then touch gas clunk.
squatch is offline   Reply With Quote
Old 04-03-2006, 09:57 AM   #4 (permalink)
konigfritz's Avatar
Are you guys sure its not the utilibed covers on the floor. they slide back and forth and make a slight clunk sound.
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 04-03-2006, 10:03 AM   #5 (permalink)
i don't have util bed.
Old 04-03-2006, 10:06 AM   #6 (permalink)
troutking's Avatar
Me either.
Old 04-03-2006, 10:40 AM   #7 (permalink)
konigfritz's Avatar
Another thing that it may be is you rear leaf spring moving (normal) under acceleration/decel.
04' Galaxy CC/BT/OR
2* Timing Advance
Old 04-03-2006, 10:49 AM   #8 (permalink)
troutking's Avatar
I sure hope that's it. Been reading scary stuff on here.
Old 04-03-2006, 10:57 AM   #9 (permalink)
DESERTDOG's Avatar
i had the same thing going on had prg install track bars no more prob.
dude don't worry my dad's a plumber "i can fix it!"
DESERTDOG is offline   Reply With Quote
Old 04-03-2006, 10:59 AM   #10 (permalink)
konigfritz's Avatar
Yeah, There are some rear end failures, must have had major failure at once and overall there really haven't been that many confirmed cases. Mine is any early 04' and it has always (at slow to moderate) accelleration had a slight "sink" feeling in the rear suspension. good luck!
04' Galaxy CC/BT/OR
2* Timing Advance
Old 04-03-2006, 08:32 PM   #11 (permalink)
stefnch's Avatar
I get a similar thing, but only seems to happen when backing up, only on occasion though. had the dealer change to synthetic, for a little extra precaution though in the rear diff. Not sure if this helps yet, just had it done the other day.
2004 SE CC Smoke
Tinted front windows
K&N air filter
RF System
Utilitrack
Nissan hitch to complete the "little tow" package
Nissan fog lights added after purchase
stefnch is offline   Reply With Quote
Old 04-03-2006, 08:34 PM   #12 (permalink)
CoachBoone's Avatar
You need PRG's traction bars.
I'm ordering mine tomorrow, along with the Bilstein shocks, Deaver leaf spring pak and Donahoe coil overs.....woohoo!!!
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
Old 04-04-2006, 11:32 AM   #13 (permalink)
nwCWBrep's Avatar
FYI there have been a lot of confirmed failures on the Titan's rear Diff. Just read the largest tread on this site and many others like it! you will quickly realize this is not an isolated case or an example of abuse. I am taking my in today for the second. At least this time I can drive it there.
I your way too excited that yours has not gone out. It will. I am sure the slop is contributing to the failues. For example In extreem cases when towing imagine how much stress is added to the diff gears when it goes for slop to pulling 7k lbs. My recomendation is to take it in to the dealer and have them check it out. have them service the rear end. It should be under warranty. If you have an 04 there is a TSB to replace the old steel diff cover and the new fanned aluminum cover.
Consider your self lucky bud!
nwCWBrep is offline   Reply With Quote
Old 04-04-2006, 12:00 PM   #14 (permalink)
Oh...this thread is about trucks... Based on the title I was gonna recommend going easy on the KY next time.
2005 CC 4x4 SE
AKA
Chunky Ass Whore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is online now   Reply With Quote
Old 04-04-2006, 12:09 PM   #15 (permalink)
konigfritz's Avatar
Unless there is a new TSB that I don't know about (possible) I think the only rear end TSB is for the relief valve on the Axle housing.
04' Galaxy CC/BT/OR
2* Timing Advance
Weird brake problem ldmaster Titan Problems & Dealer Service 1 02-12-2006 06:12 PM
Weird, weird ABS brake problem? CoachBoone Titan Problems & Dealer Service 5 12-19-2005 06:38 AM
illumination problem (weird) software.engineer Titan General Discussion 11 08-13-2005 11:25 PM
Weird Light Problem pagerdaddy Titan General Discussion 1 07-27-2004 05:01 AM
Weird start up electrical/computer problem FLfinfan Titan Problems & Dealer Service 2 06-26-2004 06:58 AM
