I noticed the dash light telling me I was low on Windshield washer fluid, so I bought a gallon and poured in into the resevoir. This morning I found all of it on the garage floor, so I'm guessing that my container must be leaky. Has anyone else had this problem, or do you know how to remove the resevoir?
There are 2 screws/bolts. 1 by the radiator and 1 by the LF headlight, between the grill and the core support. Both the same size. The plugs for the electrical connections are tough to deal with due to minimal clearance.
Thanks to both of you for your information. I went by the Nissan dealer to get a Chiltons repair manual and they said that they didn't carry them any more. Surprise! Guess I'll have to check the Internet.
Yes I have had this problem too. The rubber hose attaches in the back of the resevoir near the electrical connections. On my truck the hose came off a couple times until I put the hose back on and put a zip tie over the hose. Seems to be holding so far. I have also had it come off farther up. (zip ties galore on it because I hate not being able to wash my windshield). To determine where its leaking, just pop your hood and have someone hold the washer fluid thing down for a second. Should be pretty apparent where in the hose it's leaking.....
__________________ Smelly Whore™ I bring nothing to the table whore®
2006 Silver Titan K/C LE 4X4 w/Big tow, BFGoodrich All-terrain TA KO 285/65R18s, 77-6012KP K&N air intake, Volant exhaust, Stainless Lund bug deflector, Stainless billet grille, Stainless tailgate bezel, Jettech's rear leaf helpers, XM Skyfi2, Retrax bed cover, Front windows tinted at 35%, 6000k HID low beams Add Kenny Blankenship to your ignore list: it's fun, easy to do and a better use of your time
Thanks for the info. I figured it was a line that popped off. I wonder if a small hose clamp would prevent the line from coming off as opposed to zip ties?? I'll give it a try!
jpap-
2006 CC 4x4 Smoke
PRG leveling kit
18% front tint
Grillcraft grille
Volant LED's
AR teflon mojaves 17x8
Nitto TG's 295-70-17
I'm sure if you could find a small enough hose clamp, it would probably work better--I was working out on a rig where supplies are kind of limited.
