Old 07-13-2006, 03:45 PM   #1 (permalink)
alarm goes off when opening passenger door
We have a 2006 Titan XE crew cab. Doesn't have a key fob. When you open the passenger door with the key the alarm goes off. Dealer has said that you need to go the driver side and turn it to the left and then back to the right to disengage the alarm. Yeah right. Also said maybe has the wrong door handle from the factory. Great. Said right hand side shouldn't have a lock on them. Can any of this really be true? Help.
Denise2864 is offline   Reply With Quote
Old 07-13-2006, 03:57 PM   #2 (permalink)
jtheaverin's Avatar
Re: alarm goes off when opening passenger door
I have an '04 and my passenger side door is not keyed. Of course, it does have a lock, just no place for a key.
jtheaverin is offline   Reply With Quote
Old 07-13-2006, 03:59 PM   #3 (permalink)
baseballfanz's Avatar
That's a first I've heard of a key hole in the passenger side. It is correct you need to put the key in the driver side to turn off the alarm.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 07-13-2006, 05:29 PM   #4 (permalink)
Hyperion's Avatar
A keyed passenger side door is definitely not normal unless Nissan has made some mid model year design change (I have an 06 SE CC with no passenger side key entry). I am still trying to figure out how this could be possible. Normally only the drivers side is keyed so even if they accidently installed the wrong handle which would have to be installed upside down where did they get the extra lock core? Under normal circumstances no 2 door handles would ever accept the same key.
This isn't my area of expertise but it might be possible to tap the wires that send the disarm signal to the BCM and run it over to the passenger door so that turning that lock would send the same signal. I would assume that the lock in the passenger door is the exact same as the drivers door (since this is the only one normally installed) so you might be able to make the connection. Someone who has had their door apart and is more familiar with the service manual might be able to help more.
06 Smoke SE CC 4x4
Popular Pkg. w/ Captains, Big Tow, Utility Bed
Bakflip Tonneau, Power lock tailgate, Debadged
Born: 12/05
Mine: 3/24/06
Hyperion is offline   Reply With Quote
Old 07-13-2006, 07:08 PM   #5 (permalink)
BigRedTitan's Avatar
The XE KC doesn't have power locks and/or keyless entry. So they DO have a key cylinder on the passenger door. Otherwise, you would have to get in the driver side, unlock the door, walk all the way back to the passenger side, then open the door for whatever reason you wanted in there in the first place...which after that long walk both ways around the Titan, you probably forgot why you wanted in there to begin with.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1½" Rear Blocks, Bilsteins Front & Rear,
LED's Front, Eagle Eyes LED Tails, JDM 6000K HID Lows & Fogs, SilverStar Halogen High-beams, LED Third Brake Light, Red Billet Aluminum Oil Cap,
Red Active Tuning Grounding Kit, Body Colored Front Spoiler, 2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
Old 07-13-2006, 07:45 PM   #6 (permalink)
Hyperion, does your 06 SE CC have keyless entry? It just seems strange that Nissan would think there is no need for anyone to be able to unlock the passenger side door with a key...
Old 07-13-2006, 07:47 PM   #7 (permalink)
Hyperion's Avatar
Yeah I have keyless entry.
06 Smoke SE CC 4x4
Born: 12/05
Mine: 3/24/06
Old 07-13-2006, 08:41 PM   #8 (permalink)
That make alot of sense. I know on previous vehicle I can turn the factory alarm off with the key in the door wither driver or passenger side. Never knew that the XE have kwy holes on both side. Learn something new.
Nissan ODB2 Codes
Old 07-14-2006, 05:03 PM   #9 (permalink)
Thanks for everyone's help. Interesting solution to our problem. It turns out that while our truck came with power locks and no keyless remote, the truck actually has the keyless remote system (the receiver I guess) installed. We got the remote key fobs from the dealer and everything works fine.
Passenger seat/door rattle !!! ?? scubastud Titan General Discussion 5 07-18-2005 09:14 AM
Passenger Door Lock TitanTom Titan General Discussion 11 05-27-2005 09:07 AM
Water in Rear Passenger door DWBTITAN421 Titan General Discussion 5 03-18-2005 03:35 PM
Rattle In Passenger Door bucsfan Titan General Discussion 0 12-28-2004 04:36 PM
Door Latch Cables sawing on edge of door opening bestatchess Titan Problems & Dealer Service 0 08-29-2004 01:42 PM
