rack and pinion - Nissan Titan Forum
post #1 of 14 (permalink) Old 10-14-2006, 09:15 PM Thread Starter
TJsTITAN's Avatar
iTrader Score: 0 reviews
rack and pinion
i just took my truck to the dealer and they think that the rack and pinion is shot. there is about a half inch of play in it when it is underload and turning the steering wheel back and forth slightly. it is an 06 with 10000 miles on it. what do you think. they said that they will just warranty it out, so they arent trying to get any money out of me.
TJsTITAN is offline
Advertisement
post #2 of 14 (permalink) Old 10-14-2006, 09:21 PM
Carbeaux's Avatar
iTrader Score: 12 reviews
Re: rack and pinion
Let them do it. I haven't heard of this being a common occurrence, so I hope it's an anomaly, and have them replace. I'm coming up quickly on that same mileage, so I really do hope it's not common. Let us know if the stealer tips his hand at anything to the contrary.
Hook 'Em!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
"Be polite, be professional, but have a plan to kill everybody you meet." - Gen. James 'Mad Dog' Mattis
2016 Super Crew, Platinum, 4WD FX4 Bought by me on 01/05/16
Carbeaux is offline
post #3 of 14 (permalink) Old 10-20-2006, 06:16 AM
iTrader Score: 4 reviews
Re: rack and pinion
I have an 05 CC and I think mine is going as well. Did you get any rattling noises or was it just sloppy?
jaimr is offline
post #4 of 14 (permalink) Old 10-20-2006, 11:08 AM
714Titan's Avatar
iTrader Score: 2 reviews
Re: rack and pinion
I have the same problem (@35k mi.) and the dealer stated that this was normal and characteristic of the titan..... I think they're bs'in me as this is defintely not normal. In my case, it only does it when turning left. The dealer I had visited was Nissan of Buena Park, CA. Maybe I should take it to another dealer?!?!
2005 Titan SE Crew Cab
Popular pkg w/ Rockford Fosgate - Captain Chair - Traction - Big Tow - Utility Bed pkgs
Performance Mods:
Banks exhaust - Injen Technology intake
Exterior Mods:
TREX 1pc billet upper grill w/ bumper insert - OEM yellow fog lights - H.I.D. 6000k low beams
Silverstars high beams
Suspension Mods: (PRG'd by Greg)
CST 4" spindle - Sway-A-Way Racerunner 2.5 coilovers - Total Chaos upper control arms
PRG Traction bars - CST carrier bearing kit - Deaver 2" mini leaf spring pack
Bilstein 5125 12" shocks - 2" blocks
Tires:
OEM wheels w/ 35/12.50R18 Kumho Road Venture MT KL71
OEM Mods:
Hood deflector - Steps - Rubber mats
714Titan is offline
post #5 of 14 (permalink) Old 10-27-2006, 10:12 AM
iTrader Score: 1 reviews
Re: rack and pinion
My dealer gave me the same line of BS that it's normal wear and there's no possibility for play to occur in the rack and pinion.
So I climbed under there and inspected everything after the last visit to the dealer.
What I found is that both left and right tie rod ends were completely shot. When turning the wheel back and forth quickly, just a little ways, you could even hear them clunk. At 30k miles, that's not too impressive. The bushings that mount the rack and pinion are also showing excessive signs of wear in my opinion, but the dealer wouldn't agree.
The dealer replaced them, but gave me a hard time since I have larger tires than stock on there.
Night and day difference in how the vehicle drives!! That definitely fixed my problem. I started feeling this play with only about 7k miles on it, before the lift was installed too, and I've complained about it several times since.
I hope this was a fluke and I don't have to replace tie rod ends every 30k miles . They are pretty tiny for a 1/2 truck in my opinion... Maybe someone will come up with an upgrade.
04 Smoke Titan CC LE on 20's
redrock4x4 is offline
post #6 of 14 (permalink) Old 10-27-2006, 02:26 PM
Re: rack and pinion
Related problem...I had to replace the steering pump/assembly on my '06 XE CC at only 625 mi....then just this week, replaced again along with the rack at 15000 mi at 2nd dealership....seems 1st one screwed up....tech said he has not seen 2 go out on same truck....
TnMike is offline
post #7 of 14 (permalink) Old 10-27-2006, 02:39 PM
Yellomantis's Avatar
iTrader Score: 8 reviews
Re: rack and pinion
Take it to Performance Nissan in Duarte. It will be worth the drive. Just ask for Tim Lange. They are really stand up guys there, Tim will make things right. He takes care of all the tsb's on my truck without even me complaining about them.
2010 Dodge Ram Power Wagon
ICON sponsored, going to SEMA 2011, lots of mods
2011 Dodge Ram Quad Cab Sport
Ground Force 2/3 drop, 24" BOSS 330's, true dual exhaust with 11" Magnaflow muffler and x pipe, Volant intake
2007 Nissan Xterra Off Road
PRG Mini Lift
JBA Cat Back
K&N Drop In
CB Radio
Before you criticize someone, walk a mile in their shoes.
That way, when you do criticize them, you're a mile away, and you have their shoes.
Yellomantis is offline
post #8 of 14 (permalink) Old 11-03-2006, 12:36 PM
phillir21's Avatar
Re: rack and pinion
First time posting here, so please bear with me. I've just got off the phone with the local dealer in Phoenix to let him know that there is a ton of noise when turning left to right as well. I took a look and the rubber boots on the rack and pinion had a ton of oil on them. Only have 3k miles on it, and just lifted it worried that the dealership would come back to me and say it's since been voided because of the lift. Find out on Monday.
phillir21 is offline
post #9 of 14 (permalink) Old 11-03-2006, 12:43 PM
Re: rack and pinion
It depends, did your lift alter the angle of the steering arms? If everything has been kept at factory angles, you're fine. In otherwords if your lift included new knuckles you're probably fine.
If your lift didn't include new knuckles and you put the steering arms at a steeper angle than stock, that could be the cause of the problem and wouldn't be covered under warranty.
post #10 of 14 (permalink) Old 11-03-2006, 12:49 PM
phillir21's Avatar
Re: rack and pinion
I did (or the installer did should I say). Either way, I forgot to mention I noticed the fluid on there when I had it on the rack (before installing the lift). I guess I got a little over zealous and had it installed not thinking I might get grief for taking it in after.
post #11 of 14 (permalink) Old 11-03-2006, 01:25 PM
Re: rack and pinion
As long as your angles are correct you shouldn't have to worry, especially with that low of mileage
post #12 of 14 (permalink) Old 11-03-2006, 01:29 PM
phillir21's Avatar
Re: rack and pinion
Thanks RR, just noticed you're from SLC. Not to get off the subject, but I'll be heading to my place in PC hopefully when the resorts open up. If you see a Smoke Titan LE (hopefully with a new Rack and Pinion) give a headlight Flash.
post #13 of 14 (permalink) Old 11-23-2006, 06:59 PM
drakethib's Avatar
Re: rack and pinion
I am hearing the same clunk noise when I make left turns. Only 6K miles on the truck.
Calling the dealer in the morning.
drakethib is offline
post #14 of 14 (permalink) Old 11-23-2006, 08:30 PM
TitanBlue's Avatar
iTrader Score: 3 reviews
Re: rack and pinion
I just bought my wife an 2003 Chevy Malibu with 4,700 miles. It was my Dad's since new. Her R & P was also shot, got it replaced 2 weeks before original warranty ran out. Glad I've got a 5/75 extended warranty to transfer over for just 69 bucks transfer fee.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
TitanBlue is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Rack and pinion now leaking Herbpov Titan Problems & Dealer Service 14 08-27-2013 08:17 AM
Bad Rack and Pinion IMADOGMAN Titan Problems & Dealer Service 3 10-31-2008 10:37 AM
Polyurethane rack and pinion bushings?? Howie Kaluha Titan Suspension 3 06-07-2006 09:50 AM
Anyone have their Rack & pinion replaced lately? Satanimator Titan General Discussion 4 01-25-2005 10:37 AM
Do you have a Leaky rack and pinion steering gear? TallTexan Titan General Discussion 1 11-10-2004 07:35 PM
You may post new threads
You may post replies
