Re: KC door wont open from the outside.
Well i stopped by the dealer today. The service rep. came out looked at the lock kinda puzzled. Said he would be back in a minute. came back with a screw driver took out the two screws pulled on the latch and it popped right back to the normal postion. Apparently this is a fairly common problem that can ocur if someone is to hard on the latch when they open the door. Its a pretty easy fix you defintly can do it yourself.
