Old 11-21-2006, 03:46 PM   #1 (permalink)
Hot_Titan's Avatar
Send a message via AIM to Hot_Titan
How much braking does your parking brake do?
just for reference ive probably only used the parking brake a handful of times in the 15,000 that ive owned it...so today i noticed that the parking brake will barely stop the truck and that using a pillow as an anchor would probably work better, is this normal or how much braking force should i be expecting...
thx in advance
-david
I've Moved On To Smaller And Faster Things...It's Been Fun...Stay Classy
Hot_Titan is offline   Reply With Quote
Old 11-21-2006, 04:02 PM   #2 (permalink)
Re: How much braking does your parking brake do?
thx in advance
-david
on mine i mash it all the way to the floor, and it will hold on a steep driveway. just barley though it will creep sometimes. sounds like a trip to the dealer to adjust this one.
john
jrubin is offline   Reply With Quote
Old 11-21-2006, 04:05 PM   #3 (permalink)
konigfritz's Avatar
PArking brakes are meant for that only! They generally engage the rear brakes. The rears generally don't apply as much pressure as the fronts. IT's a mechanical not hydraulic system on most cars , therefore you don't get the force generated by the brake pedal.
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 11-22-2006, 04:11 PM   #4 (permalink)
I use mine everyday when I pull into my driveway. My driveway has a slight downgrade to it so I use the brake but here recently I have noticed that when I shift into reverse to pull out of the driveway it seems hard to get into reverse and there is a big "CLUNK" when shifting into reverse. This is probably due to the pressure being put on the transmission because the parking brake doesn't hold and the truck rolls back till the transmission catches and holds the truck. I have sit in the driveway in neutral and put the parking brake on and the truck will roll down my driveway... I am going to have the dealer fix that this weekend. I will let you know what they say is the problem.
priapus14 is offline   Reply With Quote
Old 11-23-2006, 02:58 PM   #5 (permalink)
Send a message via AIM to rodney
i adjusted mine, and although it has a little slop, it holds my truck/trailer well. my old suburban was rock steady with the ebrake, when loading the racecar. the titan rocks back and forth a little when loading it.
rodney is offline   Reply With Quote
Old 11-23-2006, 04:00 PM   #6 (permalink)
The manual states that the parking brake should be full engaged with 3-4 clicks on the pedal, any more clicks and it needs adjusting. I have had mine adjusted several times. On the day I bought my truck it took 14 clicks before it bottomed out.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Old 11-23-2006, 04:18 PM   #7 (permalink)
Send a message via Yahoo to moulin6801
I do the same thing at home! I have a driveway with a 45 degress encline, and the park brake holds the truck in neutral, only after is secure, i shift to park, this way it will be NO stress on the gears when is time to take out of Park! So, my park brake holds my heavy Titan Crewcab 4x4 in a 45 degree angle.
If yours doens't, you need to tighten it up!
David
moulin6801 is offline   Reply With Quote
Old 11-24-2006, 08:52 AM   #8 (permalink)
Let me know what the dealer says because mine is doing the same thing. It is a big "CLUNK" so it sort of worries me. Thanks in advance.
cbenzon is offline   Reply With Quote
Old 11-24-2006, 11:20 AM   #9 (permalink)
David
Hey David,
I can't pass this one up without a little comment. I have a question about this 45 degree incline in your driveway. Maybe 4 or 5 degree incline but not 45 degree. 90 degrees is pointing straight up, so 45 would be half of that. The Interstate systems across the US has a maximum of 7 degree incline. Your driveway may be steeper than that by just a little but your truck wouldn't pull itself up a 45 degree incline even if you had prefect traction.
Getting back to the parking brake. I took my new Titan in to the dealer for an adjustment because I would get in and drive off with the parking brake still engaged all the way to the floor. The only way I would know the parking brake was still engaged was by the squeal once in a while from the rear brakes. The service manager gave me the line that the Titan parking brakes are not made to stop a vehicle but only to assist in keeping it parked along with the transmission in the Park position. I live on a hill and finally convinced him to tighten up the adjustment. Since then it is working great and will hold my truck from rolling down the hill with just the parking brake applied. But to be safe I also put it in park.
Romoz
romoz is offline   Reply With Quote
Old 11-24-2006, 12:05 PM   #10 (permalink)
The "CLUNK" you hear is the strain that is put on the transmission by the weight of the truck and the parking brake not holding like it should. What is happening is the gears in the transmission are bound and when you put it in reverse that "CLUNK" is the gears in the transmission suddenly unbinding. Not necessarily a good thing. The brake should hold the truck so there is no binding.
Old 11-24-2006, 12:44 PM   #11 (permalink)
The Parking Brake on a Titan is a set of Drum Brakes inside the rear rotors. The shoes are not much wider than 1". They are definitely NOT designed to stop the vehicle, merely to provide a second method of securing the Parked vehicle. I too park on an inclined driveway. Since drum brakes work better going forward than reverse, I back into my drive, apply the parking brake, allow the vehicle to roll forward gently to stop, and then put it in park. that way the pressure is all on the P brake, not on the Parking pawl in the transmission. Makes it easier to get it out of park. If parking with the rear down, I just have to apply the brake a little harder.
Oldfordowner is offline   Reply With Quote
Old 11-27-2006, 11:04 AM   #12 (permalink)
Smile Re: How much braking does your parking brake do?
Ok, to make some of you happy, I will say that my driveway is not 45 degrees, but it is no less than 40 degrees! This 7 degrees encline may be true to HWY, sure is not true to private roads, and surelly driveways.
So, drive up or sometimes i back it up. After applying parking brakes, i slowly let my car do a full stop, as it is on Neutral, after i have a full stop, than I shift to P. This way, I NEVER have a clunck when I shift to R or D !
In the beginning I use to mess it up and hear the "Clunk", but since I got it down to a science, no have no clunks!
PS: If your parking brake is not holding your truck in a steep driveway, Take it to have it fix. Don't take the Bull **** story that is not supposed to do that, because my new CrewCab 2006 does it! As it should!!!
David
Old 01-09-2007, 02:01 PM   #13 (permalink)
Justintoxicated's Avatar
Did you ever ge this problem fixed?
I just took mine to the dealership and they said parking brake is not covered under waranty because I did not do the brake services (other than having the new brake kit installed 15k ago).
So they said it will probably cost about $45 to have it adjusted.
Old 01-09-2007, 02:31 PM   #14 (permalink)
Hot_Titan's Avatar
Sorry for not posting back but i'm taking it in for the bed liner to be resprayed so i'll kill two birds with one stone I just haven't worried too much about it cause of the lack of hills in Florida...I keep everyone posted
Old 01-16-2007, 05:34 AM   #15 (permalink)
54warrior's Avatar
Originally Posted by romoz
Hey David,
I feel confident that any 2wd truck, or car for that matter, is capable of driving up a 45 degree incline without any problems.
Any problems with your parking brake? Titan-Power Titan Wheels, Tires & Brakes 7 10-08-2006 11:14 AM
Parking Brake Problem The Titan Kid Titan Problems & Dealer Service 5 11-24-2005 03:31 AM
Darn Parking Brake! MuskyHunter Titan Problems & Dealer Service 12 11-15-2005 11:00 PM
When do you set the parking brake? Gig'em Titan General Discussion 31 09-07-2004 05:23 PM
parking brake. amati5 Titan Problems & Dealer Service 9 04-19-2004 01:37 PM
